PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 [255] 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1993 3VZ-E PVC filter location?
  2. T4R off-roading in the NW
  3. Anyone else have problems with leaky injector pipers after HG?
  4. Pic of where the camshaft sits. Check it out!!
  5. 86 4Runner Rubbing Issues
  6. Steel fuel line question.
  7. Great Project Truck on eBay Now
  8. Bad door dent while on the 2006 Razorback rumble
  9. a 340h tranny filter
  10. 2nd Gen engine swap for new 4.0 V6?
  11. rear window
  12. replaced 22r water pump, now oil leak
  13. 914runner blues
  14. milkeshake 1988 4runner
  15. new shocks/air pressure questions
  16. Vibrating when coasting?
  17. Time to buy a 3.4 Motor...
  18. Convert electric choke to manual choke? 1985 22R 4X4
  19. ARB compact compressor in place of Intake Silencer?
  20. 2 LT rebuild - howdy , new guy
  21. Header Flanges 5VZ-I have searched
  22. 3VZE Intake Question
  23. 4 wheel drive issues
  24. dif. between 22re and 22rte
  25. 3vz runs rich?
  26. Vacuum line - where does it go?
  27. A couple more tire questions
  28. Air-Lift systems
  29. Water injection
  30. 95 4runner hard to start
  31. what is a 4xforce edition 1994 toyota mean?
  32. anyone have a genuine 94runner service manual
  33. Need Advice: new 89rnr, blown headgasket
  34. Cam options for a 22RE
  35. engine removal time!
  36. NEw to yota tech and 22re trouble
  37. Sound Deadning, 1995 4Runner pics
  38. Mechanical Fan Clutch Free Spin?
  39. truck smokes during first 1/2 mile in the morning
  40. exhaust on a 1989 4runner v6
  41. first gen L trim install
  42. MPG/tire size... Am I doing this right?
  43. where are the 5.5" coil springs?
  44. Fuel Pump Life
  45. 3.0 distributor replacement
  46. BJ spacers or HD Torsion bars?
  47. no starty, (not starter)
  48. advice-dealers screwing me? 92runner timing
  49. Searching over on 4x4Pirate about NWOR headers for the 3.0L
  50. Fuel lid catch
  51. Ignition switch dilema
  52. timming help (i know, i know)
  53. Found old pics
  54. more lift question
  55. Running rough after HG Job 3.0
  56. Custom Paint Schemes (Ext-Cab Pickup)
  57. black on black?
  58. Ext-Cab Chrome Bling Trim?
  59. Do I have my crankshaft pulley on right?
  60. Where to check for faulty CEL. 90' Runner 3.0
  61. OEM Toyota skid plate
  62. Rear window problems on 1990 4Runner
  63. 1995 4runner has no power between 35 mph and 55mph
  64. Auto to manual conversion 92 P/U 22re help
  65. Rotary Engine Swap?
  66. losing a little oil after HG work
  67. Rebuilding ifs asian hubs
  68. My 94 runner 3.SLO project. acckkk!
  69. Whats Wrong With My Motor!!!
  70. alternator Q's
  71. BJ Spacers HELP!!!!!! AHHH!!!!
  72. Front side gear shaft play and noise
  73. Starting at elevation/altitude
  74. Fair price for Spindle Bearing Replacement
  75. 4runner rear window roll down
  76. Ignition Wiring Question
  77. Looking for 3.0 Intake results
  78. How to prelube oil pump before starting engine?
  79. Where would YOU buy your 4 cylinder head from?
  80. Flex-A-Lite Gone, Return of the Mechanical Fan, But Belts???
  81. Gas tank holes
  82. good 33's??
  83. 86 sometimes burn oil and sometimes it doesn't?
  84. Lift Question
  85. Charcoal canister making really weird noises...
  86. Gas Mileage '94 toyota p/u 4x4 22re
  87. water in vacuum lines
  88. OME Shock question!!!! Quick help needed!!
  89. engine rattle
  90. winch on a brush guard?
  91. wheel well cover question
  92. discolored cat...problem?
  93. 22re Engine refresh questions.
  94. the definitive answer as to if the 22RE is an interference engine... (lol)
  95. rear window nothing but click click
  96. Transmission oil cooler.
  97. High Idle/Throttle body help
  98. Hive mind, check in!! What do I do with this cylinder head? Pic!!!!!
  99. valve clatter help 89 22re (post searches)
  100. '88 3.0 v6 problem
  101. Is a 3.slow a Zero Clearance Motor?
  102. 91 3.0 major oil leak
  103. how to prove CEL works
  104. Power Slider Rear Window
  105. Fuel Line replacement
  106. Problem with rear main or the crank????
  107. Rear window track roller
  108. 175psi on a 3.0. should I be concerned?
  109. Hawse or Roller Fairlead?
  110. Exhaust
  111. bumper bull bar fit
  112. leaf springs for an 88 4runner
  113. Outer trim piece
  114. New project runner
  115. please help!code 51
  116. jumpy accel and deccel
  117. 1990 4runner pulls right while braking
  118. Transmission cooler mounted behind grill (pics)
  119. tranny leak
  120. kill switch help needed
  121. Finally....
  122. Replaced knock sensor...still code 52???
  123. 4runner theft prevention help needed!
  124. So I was cleaning up my engine bay today...
  125. Clutch grinding when pushed in
  126. 88 Instrument Cluster ?? 3.Slow
  127. Rear Cargo Seat, anyone have one?
  128. Question about installed spool
  129. Transmission Shut Down
  130. V6 Performance Chip/Module
  131. Idle mixture adjustment?
  132. Rear anti lock and cruise control
  133. Fan not working....
  134. 4WD question
  135. '94 P/U Stiff Gas peddle - Clogged cat?
  136. transmission questions
  137. 1991 4-runner Str8 Axle
  138. 3.0 Rebuild & Oil Consumption
  139. O2 sensor colored wire question
  140. code 71
  141. Looking for 95 4x4 Grill Guard
  142. replacing the tranny
  143. Should Oil pump be replaced on 3.0
  144. a/c idle and engine idle question
  145. Is a 1 inch body lift worth it?
  146. air intake swap
  147. Rear window
  148. Need new distributor for 3.0
  149. 3.0 Engine Rebuild?
  150. Ball joint replace
  151. 1991 4runner, 10w30 or 10w40 synth motor oil.
  152. Fan Clutch: Retrun from Flex-A-Lite
  153. Maf??
  154. Hand making a soft top... bikini top?
  155. should you care that idle goes up using accessories
  156. getting fuel injector to seal
  157. Tow package question
  158. does toyota make a factory repair manual?
  159. What maintenance should I do on my 145k runner?
  160. Metal shavings in front differential...
  161. Got a new toy
  162. Downey shock mounts. 2x wheel travel?!
  163. ever burnt a yota starter up?
  164. front end rattles on any bumps...
  165. what does this pipe attach to?
  166. Bumpin' Yota is down!! BY is down!!
  167. Can't get a pulley from toyota, they say it doesn't exist.
  168. Does Sunroof Pop Open or just slide into headliner
  169. '86 4Runner Fuel Pump
  170. Gas guage question
  171. Auto hub resale
  172. emergency brake light never goes off??
  173. My Truck has turned into a Lada! (Won't start!)
  174. Sunroof Question
  175. warn manual hubs coming this week
  176. anyone know where this bracket goes
  177. Beefing up 2nd Gen Rear Upper Links
  178. Weird Problem with passanger side IFS
  179. Eletric fan
  180. Electronics...BLAH!!
  181. homemade fipk
  182. A340H fluid
  183. project monster ifs
  184. Headers back exahust
  185. '87 22R truck won't idle
  186. 3 dummy lights on
  187. Little fan???
  188. brake load sensor bypass
  189. Anti-Freeze Leak
  190. Unsure on what happened to my motor...
  191. differential gears??
  192. Sunroof Wiring
  193. touch up paint
  194. Flex A Lite, Boil Over and the search for the Mysterious Stumble/Jerk
  195. brake lamp fix
  196. Header worth it?
  197. Non working speedometer
  198. Dash lights dont work
  199. Fuel Filter Location
  200. Setting record straight on IFS
  201. power window conversion
  202. downey offroad rear disc
  203. 2JZ-GE + turbo swap
  204. 4wd Wont Work!!!! Need Help
  205. take out jump seat?
  206. LCE Header install ??
  207. Thottle Position Sensor replacement.
  208. Poor Mans Air Locker
  209. Engine jerk.
  210. new head castings?
  211. Question on 94 3vze engine
  212. Aisin hubs on my 4runner...few ?s that havent been answered
  213. What is done when an injector is serviced?
  214. 3vze maintenance
  215. Kicking in rear brakes?
  216. Well, got the wires all stowed away....pics
  217. Swaybar removal
  218. Vacuum Hoses with pictures... don't know what is right or wrong...
  219. Easy or Fast way to find "short" in wiring??
  220. Full weekend of wrenching, looking for additional insight
  221. Removing timing gear from crankshaft
  222. Weird Idle, I searched
  223. Overheating issue/fuel pump
  224. Water pump goin out? 1st gen
  225. 1994 steering stops
  226. need a white bezal
  227. Engine knocks when starts
  228. Rear window blues...
  229. Any way to "fix" a cluster before buying new?
  230. 22re running rough after water
  231. instrument cluster question
  232. Pulsation Damper or Pressure Damper
  233. Tranny Removal
  234. MPG after BL and 33x12.50 tires
  235. sas vs. long a-arm kit...opinions?
  236. MAF cleaning disaster
  237. Illegal Cb Antenna Install??
  238. loss of power 22re
  239. less unprecise speedometer?
  240. Time to brag...
  241. 3VZE Air Pipe Refurbish or Replace?
  242. The Runner Fixed!
  243. Best 02 Sensor
  244. Tool Box
  245. How do you test the knock sensor?
  246. Rebuilt the whole darned thing and now it just clicks when I turn the key.
  247. lunchbox locker
  248. What would you choose - 4runners??
  249. Rebuilding Brake Cylinders
  250. To SAS or not to SAS that is the ?
