- ISO factory service manual for an 86 4Runner
- Transmission is not shifting while, driving, only in park???
- Bolt ID
- Charging Issue
- questions about clutch release fork
- Hard Starting Problem With A Twist..
- Send Help: Rough idle and flashing check engine light after oil change
- Undercarriage rust removal
- $50 bounty for this pin-out (96 t100 5vz into 91 pickup 3vz)
- Here's a new to me issue (timing related)
- 87 4Runner suspension advice. Gurus needed
- Weber carb and Idle adjustment
- Air Fuel/Vacuum/Timing
- Parts Suppliers
- Newbie needs 22RE help... 88 p/u
- Reving instead of accelerating while driving, gears 2 thru5
- Questions about pressing out UCA bushings
- Intermittent stopping while running and then difficult to start
- Can you identify gasket brand?
- Click Click goes the key
- What do you think?
- 1990 Toyota Pickup 4x4 Fender Mouldings
- 1 ton dually rear end
- Low Resistance on Sparkplug Wires... Bad?
- 22R Ignition Control Module and Ignition Coil GM Swap. Wishful thinking or possible?
- '84-88 pickup deck lamp lense discoloration
- Rough idle, dieing
- intermittent miss 3vze
- Vacuum outlet at the top of the Intake Manifold?
- Transmission Problem?
- Swapping Transmissions 90-91?
- 22re gm alternator swap problems
- 1993 3.0 choked and wont restart
- Have a couple question
- Cam bolts installed by the hulk.
- pedal assy rot help
- Transmission or rear differential going bad???
- The Lowest compression the 3VZE can run on?
- Im having a bad week
- rear drum proper adjustment questions
- Wanted, seat cover supplier
- Help with electrical problem toyota truck 3vze 1991
- Please help asap
- Cold Start Injector Time Switch
- Oxygen sensor wiring issue 88 4Runner
- Need Help With No. 1 Idler Pulley
- Slip yoke spewing
- Accidentally Ruined my New Rebuild?
- 1992 4Runner 3VZ-E Click no start issue!
- 3.0 vz---Sounds Like a Stuck valve, but????
- 95' 4Runner advice
- 1986 22r Pickup TWINCHARGE PROJECT
- 94 4runner egr system code, bad emission test
- Driver Side Kick Panel Fuses -- 90 Short Bed Deluxe
- 93 pickup - leaking windshield clue
- 87 4Runner I'm picking up
- Causes for 3vze to run bad?
- Compression test howto question
- Clutch help
- Power steering help
- 95 Yota PKUP 5 speed shifting problems
- 88 22re running rough and throwing codes 25 and 26
- 1992 SR5 4WD shakes in 4 wheel drive
- Headliner in pickup
- Distributor ORing placement
- AC conversion
- Looking for folks using SDS-EM4 on a 22re!
- Front brakes dragging?
- Fuel Injectors
- 1990 Toyota Pickup 3.0 Coolant
- 1987 Toyota Custom Cab
- Checking in/ Door compatibility
- 2nd Gen SR5 EXTREME WHISTLING NOISE at 35+ mph
- air locker Q
- Seeking opinions on upper vs. complete engine rebuild on 3.0 V6 with 210K miles?
- Need Help with Wiring for door relay
- LED headlights and light bar.
- 22RE Alternator Bracket
- EFI system, no start
- Alternator rattle?
- Check Engine Light on-Runs Rough, Sputters. No Codes to Read
- 92 IFS "walking/binding" when driving up incline
- Yet Another Smittybilt Tube Bumper Question
- 1988 2WD 22R A/C help
- 91 4runner speedometer not working
- Still wont run
- 1988 1-ton 2wd pickup - auto trans upgrade options
- Rear differential, axles, rebuilding.
- CV axle wobble
- 1988 Toyota Truck Fuel Injection System Removal
- Sway bar links on 4" lift
- having cold start issues?????
- Interior color code
- Things to check when getting a dilapidated vehicle back on the road...?
- 1995 4 Runner 3vze - Where doe this part go?
- Best supplier to order new tailgate/fender
- 1988 4Runner vacuum line
- Glove box light
- Steering Column won't attach to main dash support
- Engine won't crank
- 91 22re in 88 22re truck?
- Reverse works fine, drive barely moves!
- 93 Toyota pickup - lost all lights???
- Seatbelts
- 22re Oil for winter east coast.
- How to wire to running lights?
- Idle Surge Diagnosed; Next Steps
- Please help at wits end...
- runs rough, clicking noise, runs fine.
- 94 pickup CV axle shaft replacement
- manual locking hub lubrication
- "significant steering play"??
- First post. Repair and possibly super slow rebuild.
- Suspension replacement recommendations please
- Weird Code 51 and 52
- Visor Insert
- Headlamps allow water in
- Need advice! 92' 4runner v6 sr5 2wd
- HELP: starter not activating, solenoid clicks
- Loose Wheel Bearings
- my 4runner 92 black smoke
- 1991 4runner sunroof motor
- Pic request: 22RE Cruise Control cable to throttle body
- 86 pickup loss of acceleration while driving.
- Oil Concerns
- Bad Front driveline vibration
- Toyota 4Runner 95' fuel injectors replacement
- 93 22re won't start after pumping gas
- 1988 22r timing
- Oil pressure gauge not responding
- Help in Binghamton , NY Area
- In need of EWD for 89 pickup
- New ball joints worn out after 5 months?
- Question on 22r build.
- Shopping for a Topper
- 87 pickup clutch
- Killed my headgasket on my 22re, quick question.
- 94 pickup 22re hard starting
- Need troubleshooting help, fresh ideas needed
- Help brake problems.
- Stupid Quick Question: Rear Fender Liners?
- Buzzing behind dashboard
- gas in oil? Too much fuel pressure?
- driver rear camshaft cap leaking...after repair
- Reverse wire, near cab
- What specific manual? Or where can I get info?
- Possible clutch problem?
- Too much backfire
- Parts Truck
- bad u-joint. Companion flange is not tight
- Drivers door issue 91 surf
- Filling diff through breather?
- 93 Pickup Floor Pans
- DOH - Vibration problem SOLVED (always check the simple stuff)
- Hey, I'm the new guy in town, and my 22r needs help
- Rolled pickup, what now?
- 87 Purchase Help
- 88 4runner vacuum problem
- Did I purchase the wrong repair manual??
- 1994 pickup 4x4 22re measurement
- '87 4Runner Manual Transmission and TF: Troubleshooting out of the truck?
- V6 Surf wont idle when hot/warm
- Add a factory 3rd Brake Light
- 22RE Top End Work
- My 4runner wont start sometimes
- I'm guessing my voltage regulator is going out?
- 1987 toyota pick gets hot going uphills
- Intermittent Idle Issue with 3VZE
- Need help with 88 pickup overheating
- Changed Heater Core, now truck won't start.
- Tail lights not working? This might help!
- PS leak from cap...why
- Grill swap
- Hissing sound passenger side -- broken hose?
- 3VZE Where does this hose go?
- Testing the ECM for power - do I have this right?
- 92 pickup 3VZE into 95 SR5 4runner
- rear end movement
- Igniter repeatedly shorts out
- Flamethrower Injector kit pintle cap question
- need 3VZE valve shims
- Considering 1st gen 85 that needs 3-4 major spend items - worth it?
- Timing and distributor ?s
- barrel-key door locks
- Torque Wrench for Dummies 3VZE plz help
- Valve cover gasket question 3VZE
- 22re won't start after head gasket replacement
- 93 Cold Start Issues/ Cold start injector removal
- 1990 3.0 4runner swap 1995 3.0 pickup engine
- 1993 Toyota 4x4 front drive train
- Chasing a ECT Ghost
- Differences in T/O Bearing (Forward Shift vs Top Shift)
- My new 1995 4Runner project
- Clear tails for a 93 4runner???
- Found the knock!
- Buzzer relay bypass for domelight?
- Crown Port services sticker
- locking hub/disk brake removal, help needed
- What year is my truck REALLY? (Conflicting info)
- Just Got a 1988 4x4. What do I need to do to make it last till my son drives?
- is it OK to drive truck when speed sensor is not working
- Anyone like upgrading?
- AagghHH! Someone please help...
- big screw on intake
- 95 lifted 4runner, 33's rear bearings loose?
- 93 22re injector problem
- 86 rear driveline
- 3.slow power problems
- Another one followed me home
- Ignition Coil Test - Test-light turns off while cranking?
- Timing v6 3.0 1995
- Toyota pickup front pipe replacement
- 88 22r 4x4 won't idle cold or hot
- Will 31in tires give me problems with my 4:10s?
- Zuk... gears good or bad?
- 91 4runner 3VZE will not start after head gasket and timing belt
- Idle Problems
- Where to get 22RE Oil Pump Dowels?
- Back window help
- Vaccum Hosees on RH v6 3.0 1995
- The name that sensor game!
- 1990 3vze high idle
- New Member with questions, please
- Sudden drop in speed
- Clogged EGR Valve = Poor Idle 3VZE
- White smoke prevails after new head gaskets - 3VZE.
- Cowl Vent Covers - keeping the leaves out
- Repairing interior on 92 4runner
- Crossover steering rubbing leaf springs
- 3vze blown head/worth fixing?
- Replacement o2 sensor - engine light
- Lifespan of 1986 SR5 with 22RE
- fuel injector rebuild
- 22re and v6 gear ratio and more !
- What makes 2nd gen 4runner special? If it is..?
- Camshaft seal?
- 93 Toyota Pickup 22RE Will not Idle
- bed bolts 88 pickup
- 4.56's from Automatic '90 into Manual '95 w/ stock 4.10's?
- Speedometer Cable Jitter Bugging
- Please help with 1992 22RE Flooding issues
- Im back!
- Need help with part #
- 86 pickup with uncontrollable bump steer.
- Should Cold Start Injector always receive signal?
- 92 V6 Valve Cover Gasket and Intake Questions
- No go in gas pedal
- New AFM, Timing Issues
- 1990 4Runner v6 wont start when warm
- Dash Carpet - where to find?
