PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 [197] 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. decals?
  2. Curious Antifreeze Leak
  3. Control Arm Bushings
  4. Speedometer stopped working
  5. wheels and tire question.
  6. 30 spline 5 on 4.5 axle?
  7. Axle type?
  8. transfer case slips in 4wd
  9. 3.0L exhaust note
  10. Two questions...body and electrical
  11. High Idle...........at times.
  12. leaf springs!
  13. power steering leak (repair-replace)
  14. throw out beaing clip
  15. throwing a code 41- advice please
  16. where does this vacuum line go???? PIC INCLUDED
  17. Lookin at toyota with linkage problems
  18. Companion Flange Vibration Issue
  19. HElP PLEASE CLUTCH PROBLEMS
  20. Thinking about moving to Fort Collins
  21. what size tires?
  22. Motorvac & Fuel Filter
  23. Yota Winch Mount
  24. Drain hole exits for sun/moon roof
  25. Downey intake failed. Installing LC dual row chain and Engnblr Street/RV head
  26. 1994 4runner sputtering problem..help!
  27. Ethanol Problems?
  28. 88 pickup a/c
  29. Correct Bilsteins for Downey Springs
  30. Time for New Tires
  31. how often (if ever) do you think about selling your truck
  32. power steering... yay...
  33. 22re electric fan
  34. Rear seats
  35. About to defect to Jeep...
  36. 22re valve adjustments
  37. 87 4 Runner Transmission Problem
  38. one last 22re transmission/clutch question
  39. Ok so my engine blew out
  40. turbo motor
  41. start of my 1st gen 4unner build
  42. little smoke coming from engine
  43. Pickup soft top and roof top tent.
  44. AC blows hot after 10 minutes
  45. 4wd issues
  46. engine swap!!??
  47. Craigslist Deal - $850 for a 4Runner
  48. Best site for parts breakdown?
  49. 134a a/c low side pressure
  50. Bobby Long's 5th Steering Arm Bolt
  51. Quick a/t solenoid question
  52. Air Conditioning - Peters out
  53. Early 90s Hilux Surf 2.4T Questions (BC, CANADA)
  54. bed shimmy from 50 to 60 mph
  55. Future ideas for the '86....
  56. Turbo 4runner 5speed swap
  57. How did I break my Tach??
  58. in need of assistance
  59. TC's nightmare/rustbucket A-ARM swap....
  60. leave the C Clip out?
  61. rear main seal problem
  62. Killer Toy Top Review
  63. Interesting 1989 4runner...
  64. engine help
  65. i could kill!!
  66. Marlin Crawler + Body Lift
  67. thoughts on pulling 3.0L out
  68. Muffler From Another Mother
  69. stuck for reall
  70. 1995 22rec Scan says "repair Rich"
  71. I Need A New Bumper!!!!
  72. A/C switch problem.
  73. Thinking about doing an exhuast cutout, have some questions
  74. 87 4Runner auto > 5spd
  75. 22r Overheating only at highway speeds
  76. 87' Startup
  77. 1st gen Runners w/sunroof
  78. 3.0L woes
  79. Feelin these good vibrations? or bad...
  80. 3.0L rod knock repair
  81. Leveling things out!
  82. want to thank all of you that have helped!
  83. What do ya think bout this lift?
  84. OME 881 / 906 Setup
  85. trouble codes
  86. Rear Coil Spring Tricks?
  87. Killlllllllllllllleeerrrrrrrrrr
  88. Well I Did It Now.....
  89. help im stuck
  90. ECU burned up
  91. Have code 71 so I..........
  92. '86 22re starts, dies
  93. Power steering pump questions
  94. 1992 Toy. 4runner Catalytic Converter‏ compatible w/ a 1996 TOY. 4RUNNER?
  95. Charging light/AC problems
  96. My ball joint spacer writeup
  97. Cowl removal
  98. truck hesitates and back fires 22re
  99. Front end noise when wheels turned
  100. Quick question about bj replacements
  101. Need help next week while troy is gone till May 27nd- availablre all week! Need help
  102. ? for super charged 3.4 owners
  103. cup holders
  104. synthetic brake fluid for 2nd gen
  105. Have code 71! yeah I know its the EGR
  106. A/C Techs Help Needed
  107. where can i find a suspension lift for 95 2wd t100
  108. 3VZE Fuel Leak
  109. Anyone have a 5spd 4WD shifter surround pic?
  110. will a front V6 diff fit a front 4cyl diff?
  111. Leaking fuel injector 89 22re
  112. Tires for 86 long bed
  113. The SwampThing2 - ITS ALIVE! Almost...
  114. I'm at a loss, help please
  115. Seat Swap 2nd time around
  116. '89 with ZERO brake pedal pressure
  117. Who has the best STASH SPOT in their Truck
  118. Any one have links for the 4runner Head Gasket Recall
  119. Visor Mods @ 2nd Gen
  120. Driver's side mirror?
  121. had some fun with the sawzaw 2day manypics
  122. A question!! Clutch
  123. 5 speed swap speedo question?
  124. '95 4Runner Payload & Cargo Bay Idea
  125. Twice in 2 nights...
  126. Downey T-Bars, WabFab rear springs...
  127. slipping out of 4WD?
  128. Front Axle From Hell! Need Cleaning Ideas...
  129. lucas oil+rear differentials
  130. Wanted Parking Brake Cable '85 pickup extra cab
  131. Need some parts!
  132. Can't bleed front brakes
  133. Please Help Asap Radio / Amp Issues
  134. 22re supercharger
  135. Turbo 4runner 5 spped swap
  136. The worst words...
  137. Help - PS Pump Bracket to Block Bolts Size.
  138. auto to manual trans conversion
  139. Air filter recommedations K&N, Trueflow, Amsoil etc
  140. Valvetrain noise...
  141. Ahh, door hinge help!
  142. The government stimulated me today
  143. transfer case servicing
  144. 33x12.5 rub?
  145. Parking brake light
  146. A/C switch?
  147. engine builder performance head
  148. a/c conversion
  149. 1994 3.0 starter
  150. Front 3rd member
  151. My new truck.
  152. How tough is your truck? Watch this...
  153. hydro locked 93 pickup
  154. 1991 4Runner SR5 - won't turn over...
  155. IFS rebuild
  156. 1988 22re rough idle, #3 cylinder missing.
  157. 3.0 exhaust question
  158. 22R & 22RE Question?
  159. 22re Cold Idle Adjustment
  160. Post your ISR Mod Pics!
  161. Replacing or Reparing the Dashboard Top
  162. help with marlin crawler clutch throwout bearing
  163. engine vibration?
  164. ? on front end, balljoint?
  165. Body Bolts Length Question
  166. weird take off lift.
  167. Short bed vs. long bed measurements.
  168. 1988 22re coolant leak
  169. Left cv boot
  170. will an r151 bolt into my truck
  171. 43" or 47.5" OME springs?
  172. marlin brake upgrade question
  173. auto locker gear oil
  174. speaker volume on new HU
  175. New Head Gaskets, Now No Spark???
  176. Virbation -- not sure if its normal
  177. 22R aftermarket air cleaner
  178. Anyone else have a bogging sound? 22re
  179. Body Mount Life Expectancy
  180. Softopper for 1st Gen 4Runners on Ebay
  181. sunroof drain tube exits...WHERE???
  182. Auto trans questions
  183. Hub Help
  184. vacuum ports rusting on intake manifold
  185. Hood/Windshield mounted lights (Post pics)
  186. Pizza Cutter Options
  187. 3.0 o2 sensor wiring
  188. heli coils
  189. Okay 3.0 guys. I need some help again
  190. CV boot torn, replace axl???
  191. Rusty Rotor -- Understatement?
  192. Hydrogen fuel cell for better gas mileage
  193. Old man emu rear coils????
  194. 1994 SAS rig with 2RZ-FE/R151F=244:1 coming soon
  195. cannot clear engine codes
  196. Noise noise noise!
  197. How to remove and replace the Catalytic Converter on 1995 Toyota 4Runner?
  198. Add a roof rack?
  199. 87' 4R rear key lock/window switch stuck
  200. Need 94 4Runner auto tranny and T-case, DFW area
  201. saggin in the rear
  202. Toppers
  203. TVV broken, holding up rebuild
  204. 22re Build
  205. howling noise??
  206. Timing Belt Broke?
  207. 16" rims
  208. 89 toyota 4x4 grabbing ruts bad
  209. Key Code
  210. Clutch died =/
  211. So my buddy just got a Surf...
  212. Where can i get rear window parts?
  213. 4 adn 6 cly sr5 clusters the same?
  214. help with COdes 42, 43, and 71 anyone?
  215. Not a nother help question?!
  216. hurting 4 runner
  217. Clutch problem. Won't go into any gear!
  218. difficulty of HG/Timing Chain on 22RE?
  219. hood latch cable
  220. 89 pickup pinion seal
  221. Replacement rear seat(s) for an '86 4runner
  222. Cup holder for 86 SR5 Pickup?
  223. '93 truck stumbling on take off. (Long Read)
  224. 3.4 in D.C. area (Craigslist find not mine)
  225. been looking cant find exact info? 15 x10
  226. Swapping grille's?
  227. how to test...
  228. transmission pan question
  229. A/t filler tube question
  230. Want to understand EGR?....here ya go!
  231. Valve Timing Specs
  232. fuse box help
  233. 91 pickup electrical problems
  234. i need your help
  235. i need your help
  236. odd thing happening during warming up
  237. Tires & Gears
  238. Interior bulb numbers
  239. T-Bar mess up ... Help
  240. Transmission pops out of gear
  241. Is a 8" Lift to Much?
  242. New springs... but the rear is still a hair lower than the front. What's up?
  243. rebuilding IFS
  244. just lifted 91 4runner
  245. Do Charcol Canisters go bad?
  246. almost freshly purchased 86 yota
  247. 91 4runner got some problems
  248. fuel cell
  249. It Runs!!
  250. Recent Mods!
