- 1993 toyota pickup starting problems
- rebuilt 22re recommendations
- Meet Brutus
- A340H Frankenstein Transmission??
- 1993 toyota pickup 4x4...is it worth it?
- 22re oil in coolant
- 4runner soft top.......has anyone done this before?
- 86 4runner Rear Seat Help
- Winch w/ stock bumper and header gasket questions helllpp!!!!
- Battery drain, found the issue but now what?
- 93 pickup electrical problem
- Carb kit manufacture question
- Door Parts
- 95 runner not starting
- 3vze idle rpms...
- IFS stub shaft will not lock with c clip
- Clicking noise 93 4runner SR5 4WD
- CEL flashing
- 22r fuel mileage problem
- ac clutch not engaging
- identify leaking parts? (91 4runner 3vze)
- High beam delay
- My engine shuts off randomly
- throttle return spring.
- 95 toyota pickup haveing serious problems
- Dash/instrument lights not working. running lights work correctly.
- timing marks
- 1992 Pickup electronic speedometer burn cuircuit board question
- Think I have some serious issues 3.0V6
- Speedometer sensor
- Fixed my Speed O on my 86 4runner
- 3vze runs poorly, dumps fuel into engine
- Couple of 2nd gen questions
- alternator problems
- '88 4Runner gremlins
- A340H, tell me how to fix it.
- 91 Toyota Cylinder stuttering
- Auxiliary Gas Tank Group Buy
- Alternator upgrade to 88-4R?
- Driver's seat tear? replacement upholstery?
- My starter problem has become a nightmare. Help needed. Badly.
- 89 Pickup Wiper Blades
- Downey header smokin' pretty bad.
- drive with no ifs diff
- Ignition
- Tacoma roll bar in 89 truck bed?
- What sensor is this???
- Automatic reliability
- Blown up
- Auto to manual
- generations
- tire question.....
- 88 pickup 22re stalling
- Headlight trouble
- 93 4Runner Won't Start After Trying to Jumpstart Truck
- Manual transmission fluid
- '95 4Runner, starts hard, runs good.
- Rockerarm assembly
- 1991 Lifted Toyota truck steering problems! PLEASE HELP
- washington
- 88 2wd
- hard to get into 2 wheel drive
- Question about locking hub
- 1994 4Runner Wiring Harness
- TRAIL GEAR Alternator Swap PROBLEMS
- 3vze timing set to zero?
- Leaky Windshield
- 86 4runner fuel issue
- 4 runner transmission,transfer case
- Cleaning upper and lower plenums
- anyone running NWOR idler brace?
- Battery
- !!!!!!!!Need help with head gasket kit!!!!!!!!!!!!!!!!
- a few 22re/22r questions
- In Serious Need of Help with 22RE
- Can't find the flasher relay to save my life ('90 4Runner)!
- Alternator compatibility
- Parking Light Not working
- pitted 22r block
- Bed rail caps?
- Stock rear suspension idea
- 3vze overhaul PS in air resonance chamber and H20 bolts
- 94 3.0 slowly overheating at ~30 minutes.
- 91 toyota fuel pump bracket
- 22RE Vacuum Line Help
- Thrown Rod
- 91 4x4 manual transmission swap help!
- 86 toyota pickup 22rte codes
- Embarking on a HG journey...
- Water on floor of passenger side (1987 22R)
- Brush Guard
- Truck died ECM dead?
- oil smells like gas.
- 3vze build
- Code 52 and terrible gas mileage.
- Tire carrier swap question
- 87 vibration
- Head gasket question
- Choke doesnt close until after first startup
- Coolant in the chamber after rebuild
- 91 4runner engine issues
- 4.3 transmission options
- Electrical gremlins on the tail light circuit
- Turn signals dont work but hazards do
- Non OEM fuel filter failed after 1000 km.
- Pics of 4" Lift with 33 tires
- Someone tried to break in with a screw driver.
- Grill options for 89-95 trucks ?
- Need some auto transfer case help
- 22re Fresh Build Rough Warm Idle
- Has any one lost power steering without any symptoms?
- Location for a Thermal Fan Switch
- 4runner startup Issues
- Diagnosis question
- 1993 toyota 2wd 22r-e pickup Emissions Results
- Tons of white smoke on start up
- Clicking noise from electrical short??
- Anyone know what the 3VZE fuel injector spray pattern should look like?
- overheating!
- Fuel Injector Woes
- Long distance driving
- 3.8 l67?
- Water Bypass Manifold ID Help please.
- Leaf spring bolt sizes?
- not your typical rough idle
- List of all light bulb types?
- 22re Spark failure??
- 2 piece throw out bearing vs 1 piece
- Identifying Performance Cam
- 3.0 V6 Head Gasket Replacement Interval
- Toyota Fun Runner by leisure odyssey
- Quick question about floor mats
- How to make a 3.0 v6 faster
- Need help with my 94 sr5
- Think i did it think i blew the front seal on my tranny
- Auto to Manual 4X4 wiring Questions 2nd gen
- Flatbed tail light question
- 93' 22re Bad ECM??
- Clutch/Transmission Help
- 91 toyota pickup 22re need help!
- gearing question
- 2wd chevy 350 swap with th350 for street
- What could it be
- 1987 22rtec #3 injector problem?
- What manual transmissions will fit a 4wd 22re
- Metal timing guides
- swapping ring and pinion
- Help with 95 3vze into 88 4unner
- 22re performance head vs engbldr head or any other
- No compression in cylinder 5 or 6
- 88 Toyota overheating no leaks
- 86 4runner SR5 Cluster Speed Odometer not right
- 1st gen 4Runner 86 exhaust.
- Another bucket seat swap thread... '93 reg cab pickup
- Front axle gear question.
- 3vze help with high idle at start up.
- 91 22re, won't stay running,Code 14 persists!
- Fuse box cover
- '90 hilux Restoration questions
- Run a VIN check for me?
- stuck drum brake adjuster
- Emergency brake sensor
- What does this vacuum switch do?
- Help :/ 94 runner sputter... Yet another horror story
- 60/40 Toyota Bench Seat Covers
- California ECU Compatibility
- interesting idle problem.
- 92 4runner Flexplate bolt
- Rear bolt in shock options
- Where to Start on my 95 4runner?
- Camper Shell Fit ?'s for my '94 Pickup
- 86 Toyota Motorhome w/22RE making some undiagnosed sounds under the hood
- heater control valve
- E-locker full axle swap?
- Throttle lock for winching
- Smog Problem
- Need: 94 V6 - Cold Start Injection Fuel Line
- Need some severe help Code 52
- Loose flywheel bolts binding clutch?
- Part # for window crank handle
- 1994 22re charging issue
- Question on an excerpt from the "Toyota Bible"
- OEM Bug Deflector?
- Check engine code help
- Top End Rebuild
- Birfield wont go back into new differential
- Leave your hubs locked in?
- Electrical connector needed
- 1993 22RE DIED from puddle
- 1991 4 runner v6 manual trans 3.0
- 1986 toyota 4runner 22re fuel hose
- 22re high oil pressure
- 1992 Toyota 4wd extra cab 22RE
- Won't start after running
- What tire sizes are you guys running?
- timing and backfiring issues, please help!
- What front end grease are you using- Ball joints etc
- Redline MT-90 Tranny question
- help identifying two (possible ground) wires
- 89 4Runner SR5 V6 Power Steering Pulley!!
- Trail gear high pinion differential wont fit in the axle housing.
- tank type coolant heater on 3.slow
- anybody have a parts truck?
- 4Runner Om617 swap
- 93 4runner Annoying squeal
- hvac issues
- help car won't pass 3000 rpm
- Stuck Rear Drums- Is this a common problem? How to prevent?
- 4x4 shifter problem staying in gear??
- w55 transmission shifter seat part number
- power steering
- CEL Code 21 (Main Oxygen Sensor Signal) and Other Problems - 22RE
- 95 4Runner won't start
- 22RE Idle Surge with codes 2,6
- testing egr by mouth...
- Steering bind/pop
- Front Hub health
- 92 with 22re when put in gear truck vibrates bad
- Noise and bind
- timing issues..
- 1992 wiper linkage
- transmission help
- Need some help with fixing my Rig
- The new Guy - Negotiating for my first 4 runner
- 95 Yota 4WD Brake Caliper Parts Number Check
- ADD Delete
- Front diff leaking on Passenger side
- E-brake solution to rear disk swap??
- What should I do to my motor while I have the head off? engnbldr head or no?
- Fuse blows under hard breaking
- 1986 Toyota Pickup Starting Issue
- HELP CE light on after oil pan gasket change
- 3.0 #6 Cylinder cut out suddenly.
- 1993 T100 3vze revs to a certain point then cuts out
- 3vze air fuel ratio problems
- Possible for Vacuum Leak to cause sulfur exhaust smell?
- 94 Pickup 22RE Water Leak
- 87' Runner.. front driveline stays locked?
- OME lift questions
- 1994 22re into 1986 wiring problem
- Poor acceleration and crappy sounding engine
- Rear clunking noise
- Cylinder head squelch area spec
- 92 Pickup 3vze Crank no start
- water in fuel?
- Have I missed anything to swap 22R engine from 1985 2x4 in to my 1987 22R 4x4?
- Intake air temp heat soak causing hard starts & low start idle?
- E-Locker motor voltage?
- Idle surging at startup
- Fuel Filter, fuel pump, or catalytic converter? Or something else?
