rear alignment?
Old Nov 18, 2014 | 04:17 PM
jereli's Avatar
rear alignment?
So I been researching around and from what i been reading there is no alignment that can be done for the rear. Buuut... On my 91 4runner 3.0 I can notice that my driver side rear has a negative camber.. And my rear passenger side looks pretty straight up and down. Any ideas why?
Thanks
Old Nov 18, 2014 | 04:31 PM
Erik Hinch's Avatar
Check your rear bearings
Old Nov 18, 2014 | 05:53 PM
oldblue's Avatar
Most shops give free alignment checks. Much more accurate than eyeing it. I agree with checking for play in the bearing. You hit anything? The only adjustment you can make is for the thrust angle. So either your eyes are off, or something is broke.
Old Nov 18, 2014 | 06:11 PM
JasonYota's Avatar
X2 ^^ it can be checked but no way to adjust it. Something's got to be bent, really wore out, etc.
Old Nov 18, 2014 | 06:33 PM
jereli's Avatar
Havent really hit anything to think it could have been bent. How can I check the bearing? Do I just jack up that side and see if there's play in the wheel?
For sure I need an alignment but I am worried I am get an alignment and still wear my back tire.
Old Nov 18, 2014 | 06:51 PM
JasonYota's Avatar
Originally Posted by jereli
Havent really hit anything to think it could have been bent. How can I check the bearing? Do I just jack up that side and see if there's play in the wheel? For sure I need an alignment but I am worried I am get an alignment and still wear my back tire.
^^yes. If the bearing is bad enough to make the tire tilted you should have a very bad vibration and oil leaking. Are you parked on a level surface? Equal tire pressure?
Old Nov 18, 2014 | 08:23 PM
scope103's Avatar
Originally Posted by oldblue
Most shops give free alignment checks. Much more accurate than eyeing it. ...
Actually, checking camber is so easy there's no reason not to do it. Get a $7 24" level from Home Depot http://www.homedepot.com/p/Stanley-2...-468/202317053. Use it to find a level parking spot. Use rubber bands to attach a pair of drywall screws point out to the side of the level, as far apart is the edges of the wheel rim. Hold the points against the rim with the level vertical. Is it plumb? It should be.
On front tires, you often want a little camber, so you just tip the level until it's plumb, and estimate the distance from the tip of the screw to the rim. Use the formula to compute the angle in radians. (1/16" over 12" is 0.25°; you can measure with great precision)
okamikai
Apr 30, 2018 10:19 PM
Athansinis
Jul 27, 2015 08:38 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
hangtown88toy
Jul 10, 2015 02:33 PM
