- Console lid question
- Died While Running, No Start
- 1st Gen 4Runner vs FJ80
- Restoration parts?
- Thermostat question
- Clutch & Brake Pedals Freeze Simultaneously
- 22RE Valve Stem Seal Replacement
- auto trans noise
- Another 22RE to listen to (vid inside)
- 4:88`s
- first Gear won't engagr
- 1st gen 4runner Amber dash bulb swap (with pics) - $10 mod!
- Marvel mystery oil for unseizing engine?
- Removing Spare tire carrier
- 94 22re wont start.
- Ground Strap
- 22re replacment
- Remounting sleeping deck
- Fuel Line Replacement
- Cold Air/Supra AFM Mount (dial-up beware)
- Aftermarket V6 motor dealers in Canada
- Brake line leak ...
- new tires
- 22rte BOV ?
- .020 over 22rte running lean
- New 4Runner fender Flares(photos inside)
- TPS part deux
- Change AC belt - Pulley Bolt broke - HELP
- High NOx, EGR working...
- Spun harmonic balancer
- Possible to pressurize fuel system
- 2nd Gen 4Runner Rear Spoiler?
- need help cranks put wont start !!
- starting problems
- Clear Tail Light Covers
- Surface Mount LED Backup Light Install - Lots of Pics!
- "whisteling" through a straw noise???
- Engine Electrical Connector Identification
- Creaking/Squeaking in front left side.
- Shock Absorber Bushings
- 91 3vze 'runner - timing advance?
- can modifying the t-stat cause overheating?
- what exactly is this part??
- 89 stock rims fit 31x10.5?
- What does it take to put a '93 auto motor in a 94 manual 4runner
- 1989 22r carburetor
- 22re Plastic Guides VS Metal Backed Guides
- Injecting/Starting problems
- ome springs
- leaf spring flaring
- Might be the end for my Runner
- Blown Seal Help
- Engine noise opinions ( w/ Video )
- Overheating Problem!
- Crankcase filled with fuel!!
- Advancing timing cures misfire...What to check?
- 1991 IFS swap to late 80's 4x4 frame?
- Strange electrical problem.
- Stretched E-Brake Cable Fix
- Will a 90-95 Smittybilt front bumper fit my 1990 4Runner?
- Transmission vent
- 1988 5sp Trans problems
- difficult to shift back to 2H
- 86 custom cup holder build?
- Another speedo problem.
- DIY Paint on the 4Runner.... it begins
- Radio Blew ? Fuse ?
- 89-95 Windows track rubber
- 3vze aluminum valve covers
- I have a HUGE favor, need the back seat rear covers measured.
- Trouble getting 3vze running after headgasket replacment! Any Suggestions?
- starts but dies when put in gear
- Gas leak and pulsation
- 86 22Re oil filter photos
- help fuel problem
- 91 4runner power loss
- Is this Normal RPM Speed
- wheel bearing socket?
- 22re help!!! wiring harness from 86 into 85
- Another starting issue...Its NOT the starter
- lost dash lights
- aisin clutch kit
- optima battery
- Clarification on Oil pan removal...
- SASsafrass and custom dash
- Why can't I burp the cooling system!?
- Hello and Tranny shifter question
- Broken bolt - lower arm to ball joint - 105 lbs torque?!
- CV Boot replacement - Toyota or not?
- Removing rear wiper arm 1992 4Runner
- I broke something in my rear Dif.
- Gauge Cluster swap 93 to 92 4X4 pick up
- Stupid Idler arm and A/C question
- 94 PU 3.0L- sourcing a rebuilt, pull/install questions, etc...
- overheating when at idle
- vibration 45-60 mph
- Supra AFM swap...better all around
- A/C not as cold since timing belt change
- Replacing the fuel filter on a 95 3vze yota?
- 88 4runner SR5 Map light Bulb
- not near truck at momment need 89 frame measurement
- ac blowing bits of foam in my eyes
- New Ground Causing hesitation: Calling all Electrical Genius
- time for a new battery, which one to get?
- 3vze 95 runner overheating
- Tailgate Cupholders?
- low idle/sluggish...alternator?
- Complete 87 4runner SR5 interior remodel
- Please Help Appraise this 86 Toyota Pickup 4x4
- Will Transmission and Engine work from 4 runner?
- Marlin Crawler bumper bent in half
- Speed Problem with my Toyota pick up
- Screwed up front of head gasket installing timing cover...
- Idle Air control valve.
- Starter replacement lead to clutch problem....Help!!
- seat swap 88 truck
- 95 4Runner Fender Flare Options
- 4-runner quick lift question
- Weird transmission problem
- Ignition Timing issue!
- Flaky pulsing voltage at fuel pump
- 22rte running lean/ squeeling
- 87 SR5 interior lining instead of carpet?
- I need some starter advice please.
- 93 22re Running REAL rich.....Help Please
- 3vz-e Overheating/Bubbling coolant...?
- Replacement Fenders for 1st Gen 4Runner
- location of temp sending unit
- pinging
- does anyone know if toyota 4wd mud flaps are still available?
- 91 T4R 3VZE Crossover pipe install ? Possible ?
- locking hubs not fully turning
- 87 Front Axle Side Gear Shaft Oil Seal
- Fuel pulsation damper screw
- 22RE Low power, rough idle when hot.
- Slight power loss problem
- Exhaust leak question
- another crankshaft pulley bolt thread
- Changed PCV valve, no more oil consumption
- Rear axle bearing question
- Pulling when braking, IFS, etc
- Electrical Problem. Need Help!!
- 1990 22re 4 speed manual transmission?
- What is this thing? '86, 22r
- fuel issues
- No Ignition Lights/No Start
- 94 pickup 22re timing chain
- new radiator??
- Seal packing on cam bearing caps 1 & 5
- Weird vibration noise from drivetrain
- Weight of a 56w transmission
- 86 22 re starting problems?
- Mounting an ARB bumper
- battery or alternator?
- Bizarre miss firing problem
- What the heck is this hose and where the heck does it go?
- 91 4runner 3.0 alternator burning smell
- Hose underneath Oil Filter
- clunking noise from cv's when driving in rough terrain
- '91 V6 4x4 Pickup Shuddering/Vibration
- (84-88 4runner) Radio Bezel Area - what's it supposed to look like?
- Aftermarket Guage Advice
- What transfer case will work for a turbo 4runner?
- 1st gen rollbar: bolt sizing request
- Timing Tensioner questions
- 86-89 rear bumper compatability
- Lift kit aftermath worries
- 89 pickup v6 5speed transmission stuck in reverse
- procomp AALs installed- PISSED
- shuddering in 2WD drivetrain on takeoff
- 22re Fuel Injector Wiring
- 22re Timing Kit
- high speed vibration when coasting
- Who's installed a power inverter in their truck/4runner?
- 1stGen 4Runner tailgate door switch mod
- My Flowmaster 40 side pipe exhaust build.
- 2 Piece side window
- SOS!!! Brake line won't screw in or out!!
- Pacesetter and Automatics
- Oil pressure-help
- FIRE!!! / PS Pressure hose
- failed smog. changed o2 sensor now high HC and Co2. why?
- Pulling an engine???
- 3VZE timing problem
- Fuel regulator: Do I need it?
- Most common check engine causes
- Need to know where ADD sensor connects under hood ASAP
- Power Steering Reservoir Tank: '90 3.0 v6
- 22rte guys come in- wideband?
- dash lights/electrical badness
- Overheating Advice
- did a tune up today
- Shock fell off
- Front Differential Ring and Pinion
- Sluggish Engine (22re)
- Owners Manual. Who's got one!?
- 1990 toyota pickup 5" IFS eliminator
- Do I need to adjust my Panhard bar?
- Will these Door Pannels Fit??
- Trying to obtail CARB certification?
- 86 22re will not crank
- 89 pickup leaning to the right.Why?
- Auto - 5speed conversion. 3.0 v6
- 88 3VZE no timing marks...help
- Used Engine
- 22re off to machine shop, did I forget anything?
- 91 22re pickup code 14
- MS 22re PnP 42 pin Nippon Denso PnP
- 22R rough idle, miss at idle, carb?
- free truck... needs engine... now what
- 22re rough idle/ vacuum hose problem
- Timing Help plz asap.
- 1994 4Runner wont stay running
- Gotta get a new Transmission for Tippy - 85 22re/Auto
- 3.0 CEL codes/suggestions?
- VSV or TVV in EGR system?
- installed 3 gauge pillar pod (pics)
- front end
- 3.0 timing belt marks 1/2 tooth off
- Which aftermarket Tranny Cooler for a 95 4Runner?
- Seating Options
- subtle vibration after replacing pinion seal
- rear axle seal help
- long arm Blazeland and 4 inch ifs lift combined?
- 93 4runner speedometer issue
- rough/missing idle with no code
- Any 1st Gen 4Runner 22RE Autos with a header?
- Pushed rear wiper back up and now the window won't move, relay clicking
- bed repair or fiberglass?
- Anybody had a 3.0 drop a valve seat?
- build it or part it out?
- 1st gen 4runner rear window problem and driveline harsh metal squeak
- 1986 22R Engine Swap Cost
- Transfercase shifter hits center console
- 90 pickup evap core is the same, 22re or 3vze, then why doesnt my ac hose fit?
- The "SupraLux". This lift just may make you rethink going to SFA.
- power windows/locks
- exhaust pipe question
- Help with carb problem?
- 3VZEto ford 5.0 swap, who has done it???
- How to remove spades from fuel injector connectors
- Removing tire mount/ TOYOTA vinyl
- Rough Ride with Old Man Emu?
- 3vze oil pump mistery
- JDM Auto Is it the Same
- Valve clatter then skipping
- Auto to standard swap
- New Tires! :D
- Question about 87 Frame?
- Solenoid Location on transmission
