PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Need help with this electrical connector!!!
  2. Toyota 22RE ECU compatability?
  3. CVs making noise even with hubs unlocked?
  4. 3.4 swap into 94 runner
  5. 91 4Runner Driveshaft/U-Joint Issues
  6. Rear main seal dimensions for 3.0
  7. Radiator Fan Shroud Screws
  8. temperature issues.
  9. new 22re running issues
  10. engine rebuild 22r
  11. oil in coolant - could it be something besides HG?
  12. A340H transmission
  13. egr temp sensor plug ?
  14. 22RE issues
  15. brake line routing for abs system removal question
  16. 89 22re Intake Manifold
  17. 2ed gen Tailgate issues, Help!
  18. Factory Bumper w/Winch (pics)
  19. 22re Rich Condition, Black Smoke
  20. Check Engine Light - O2 Sensor Code
  21. 94 22re TIMING CHAIN GUIDES
  22. Please help! Running rich
  23. A/T won't downshift out of OD
  24. timing cover cracked. low compression.
  25. timing cover cracked. low compression.
  26. Fuel Line Part Number
  27. 22re lack of power... injectors?
  28. 22RE No Oil Pressure after oil pan gasket replacement
  29. Body swap guide
  30. quarter panel q's
  31. 94 4runner LF CV replacement
  32. New engine wont start
  33. Need help ordering parts for replacing leafs and BJ spacers
  34. coilover conversion
  35. Carr Lightbar Wiring - Xtracab No 3rd Brake Light
  36. Guess What Showed Up Today - Inclinometer
  37. Rear door will not unlock
  38. 3VZE valve cover gasket
  39. Flushing Auto Transmission-Sealant Suggestions?
  40. Auto Trans advice needed please
  41. 94 4runner 3vz rebuild overheating
  42. 94 pickup electrical issue
  43. Will These Shocks Work With My Set Up?
  44. Diagnosing 3vze issues.
  45. Zuk mod questions
  46. 90 p/u 22re codes 25 26 41
  47. Clutch pedal pressure
  48. Bad starter?
  49. Misses or bogs down 40-50 MPH 92 22re AT
  50. 3vz-e biting dust...any used motors out there?
  51. Rear Drum Dragging Bad
  52. 3rd member question
  53. Diagnostic code 12. Knock sensor?
  54. 4x4 light flashes on and off
  55. t-case locked in 4H
  56. Does this 22re block look still usable? (rust)
  57. pics of 86-88 pickups with trimmed fenders (i.f.s)
  58. New To Me 95 PU 3.0 BAD MISS- HELP?
  59. Idle drops when A/C is on.
  60. trying to set the timing.. jumper on te1 e1 doesn't change idle?
  61. 91 PU - Build Input
  62. Cold Start Injector Troubleshooting
  63. Remanufactored Fuel Injectors ... Any Good?
  64. 1993 4runner 3.0 will crank but when you give it gas it bogs down and then back fires
  65. Blown exhaust valve 90 22re
  66. G52 oil capacity
  67. Engine quit, wont start bad sulfur smell.
  68. trans question G58 to W56??
  69. Replacement Catalytic Convertor & Rebuild
  70. 1986 22rte issues with pictures
  71. How-To: LSPV delete
  72. Sluggish/Timing problem
  73. how to remove charge fuse under the hood ?
  74. gasket for iac valve body
  75. ratcheting sound in the freeway
  76. Source for vinyl floor 1st gen 4runner
  77. A340H Pan Gasket question ?
  78. Idler arm loose, do I replace whole part or just bushing?
  79. 93 PU hesitates after warm up
  80. crank no start?! Video Inside
  81. Volt meter goes too high should I worry?
  82. 1993 pick up extended cab interior removal
  83. wobbly shifter...automatic transmission
  84. Voltage gauge dropping and truck losing power. Alternator?
  85. torque converter question
  86. bad injectors = surging
  87. 22re clutch assistance needed
  88. 86 22rte cold start issue
  89. 88 truck 5spd help
  90. Amp/fuse for A/C on 22RE??
  91. Cold Start Vacuum
  92. Reman afm for 22RTE
  93. Timing Gear WILL NOT COME OFF!
  94. Front valance and skid
  95. tranny slips in reverse
  96. Transmission test, advice needed
  97. Scary Video of my 3VZ-E Oil Pressure
  98. HELP!! ARP head studs hitting valve cover? 22ret
  99. Replacement Exhaust 93 22re
  100. Vent/return lines? Which is which
  101. A/C problems @ idle
  102. 86 22RE A/C fuse?
  103. Exhaust Manifold
  104. '99 4Runner 3.4L acts like in neutral after braking hard
  105. Control Arm Bushing Theory
  106. 88 4runner TRE hits frame and pitman arm
  107. Please see if you can identify this part (images included)
  108. 1991 Auto Tranny Not Shifting into OD unless restarted
  109. 1989 Toyota Pickup New Clutch chatter (2wd)
  110. Odd Starting Issue - 1986 22RE 4Runner Auto
  111. refilling power steering fluid
  112. shocks on a budget
  113. AFM Static Test - Results Analysis
  114. Front crossmember replacement (another rusty truck question...)
  115. exhaust manifold studs
  116. Stock U bolt size for my 90 Pickup
  117. Blown Headgasket - 22RE Engine Builders in Western WA?
  118. 94 truck will not crabk after timing kit replaced
  119. 94 toyota pu , code reader , is there one
  120. odd quirk when starting
  121. New lower control arm bushings...anti-sieze?
  122. Help on Changing Head Gasket
  123. 22r carb problems
  124. 1st Gen 4runner sr5 alarm?
  125. Replacement Hoses?
  126. Where does this 3VZ-E connector go?
  127. 87 4runner transplant from 84 celica
  128. fuel pressure regulator?
  129. Start up videos?
  130. What to do with my toasted 22RE
  131. 265/75/r16-884runner
  132. Need some info on headers for 3vze
  133. 86 22R no power. gets worse when warms up. Timing chain guide failure.
  134. Auto transmission problem
  135. 22RE surging acceleration with tps hooked up...
  136. Fuel Pump Wiring Harness
  137. 22RE starter grinds in cold weather
  138. How to manually wire a toyota fuel relay
  139. 93 4runner high idle and drives poor and overheat
  140. just installed a street rv head and 261 cam
  141. O2 wire harness routing help -- 22re 4wd w56
  142. 93 v6 starting problems
  143. +B on the DLC1 is not getting power
  144. Tricks for relay rod?
  145. 86 4Runner clutch noise?
  146. '91 Pickup, No acceleration, No Codes
  147. Pic of my broken flex plate that i thought was rod knock.
  148. 3VZE - Stumped bout Spark
  149. knock sensor location
  150. Lowering Front Diff troubles
  151. Starting 340h to R150F swap, speed sensor question
  152. 88 3.0 crankshaft gear
  153. Factory steering wheel swaps??
  154. Pics needed: 22RE vacuum line
  155. 22RE hard starting in the cold
  156. I could really use some help figuring out some driveability issues...
  157. Swapped blocks and now my 22RE isnt getting Fuel.
  158. Toy drinks oil
  159. Temp gauge fluctuation
  160. Fog Light wiring
  161. poor idle
  162. New to me '87 xtra cab.
  163. 91' V6 Auto Driveline Problems
  164. 88 V6 fuel damper
  165. 14 vs 18 inch magnaflow
  166. Crankshaft pulley removal tool
  167. Battery Slowly Drained - Do these amp draws seem normal?
  168. Power Steering pump compatibility
  169. need help with broken rear axle shaft
  170. manual vs the automatic wiring
  171. transfer case oil
  172. extending steering shaft
  173. 90 4 runner
  174. Help with radiator swap
  175. Question about combining BJ spacers with thicker torsion bars
  176. '95 4runner IFS question
  177. Hey guys im back! With a new truck
  178. Fuse Keeps Blowing!
  179. Warn bumpers with pics!
  180. Truck pulls to the left after driving over rail road tracks
  181. Swimming with electronics
  182. 22re from a 2wd in a 4x4?
  183. substantial voltage jumping with headlights on (video inside)
  184. More engine trouble - post hg repair - 3vze
  185. Oil leak, need help!!
  186. Intermittent starting problem with 22RE!!! Help
  187. Rear leaf swap question
  188. Radiator fan....
  189. Parking Brake Cable Replacement Question
  190. rear axle stock or upgrade
  191. 91 Toyota keeps popping 30 amp fuse....why?
  192. Driving with ECT sensor disconnected
  193. 94 22re 4x4 pickup w56 trans. will a 3.0 bolt right up?
  194. Will 93 p/u fenders fit 93 4runner
  195. Some Info For Anyone Looking to buy Sway-A-Way Torsion bars
  196. 86 Pickup 4x4 22re
  197. Never Been Removed Top ???
  198. 3 VZE valve clearance
  199. 93 V6 Auto 4X4 A/C Compressor Replacement
  200. 1987 22re 4x4 auto yota
  201. Four wheel drive issues
  202. Bad u-joint solved the noise in the drive train
  203. UCA and LCA aftermarket.
  204. Corrosion on 3VZ-E Block
  205. Brake pad job turned into a caliper job on both sides..
  206. Coolant Temp Sensor size??
  207. Freshly Rebuilt 3VZ-E, No Oil Pressure
  208. Basic question about CEL
  209. Rancho stopped working...
  210. Rebuild a 22RE head?
  211. A343F Tranmission and electronics
  212. Buzzing Right turn signal ?
  213. Idle Screw AND Air Mixture Screw???
  214. Ignition switch trouble
  215. 1.5 BJ Spacer + Zuk Mod Shock ???
  216. Transfer case clocking
  217. aftermarket or stock air intake?
  218. Steering Column Horn wiring
  219. Deck Lamp Button
  220. Truck loses power after driving 1 hr+
  221. My 1987 4runner needs a ect for the computer
  222. Center console different with rear heat?
  223. No Start Condition: Have Spark & Fuel. I'm So Stumped. '95 'Runner 3VZE
  224. Removing the Crankshaft Pulley Bolt Question
  225. Head Gasket Help 22re
  226. my 88 4runners history...?
  227. Steering column and key setup, WEIRD QUESTION!
  228. Knock on acceleration
  229. 91 Pickup 22re bad MPG, Codes 43 & 71
  230. IFS ring and pinion install into 2wd???
  231. About to embark on the BHG trail (or trial)
  232. Rear Suspension '87 4runner
  233. Ball Joints!!
  234. 93 Toyota Pickup 22re - Rotor button is scrapping inside of cap?
  235. Exhaust pipe hanger? Or shipping clamp?
  236. knock sensor? 92 yes 89 no?
  237. 35's no lift
  238. 94 2wd pickup bed dimesnions
  239. no start please help!
  240. I hate to start ANOTHER thread about my 22re that wont start but....
  241. Fresh trail armor, for me! :)
  242. Help!! I broke a sensor while trying to fix ECT.
  243. 3vze overheating when towing or sitting in traffic
  244. Where do you guys buy control arms for your 4x4 Pickups?
  245. Weber 32/36 on 87 Toyota
  246. Newbies first rebuild and started! NOW I NEED A LITTLE HELP!
  247. head gasket,timing chain video
  248. New TPS and o2 sensor now it runs bad
  249. HELP with motor mount....
  250. Fender flares, 1st gen runner (did a lot of looking, nada)
