PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 86 pickup heater fan motor or resistor??
  2. any EBAY Radiator experiences?
  3. seatbelt receiver needs a Viagra pill
  4. Crank no start
  5. Looking for a few parts.........
  6. W56 C Transmission Rebuild Cluster / Counter Shaft Play
  7. 22r Timing
  8. not goin into 4th gear
  9. 88 Chinook Camper Conversion, Brake Question
  10. Cap or vacuum line on this VSV opening?
  11. 1992 4Runner 6 cyl 4x2 AT Auto Transmission Compatibilty
  12. WTB 84-88 right fender well apron patch
  13. Budget build 95 4runner
  14. Plastic paint for interior? 86 Toyota Pickup
  15. Another… 3.0 VZE Crank- No Start
  16. Trouble installing SR5 Wheel Caps
  17. Best Aftermarket Power Steering Pressure Hose
  18. 89 First Gen 4Runner - 3.0 Rebuild
  19. Truck was running and then all of a suudden died
  20. ECM + Wiring Harness Question
  21. Need help changing valve cover gaskets. Can't get plenum off.
  22. Choke trouble
  23. Power Windows Electrical Diag - Circuit Breakers?
  24. WHAT are these holes for?
  25. Anyone know where this goes?
  26. AC Diag
  27. Steering Dampener - to replace or not to replace?
  28. 1986 22r head & cam questions
  29. 3.0 Radiator Recommendations
  30. Share Your Biggest Truck Problem and Win an Innova 5610!
  31. New Engine or ?
  32. Fuel Pump not getting power when turn key on
  33. Early 89 4Runner Rear window regulator & door panel Part
  34. replacing locking hubs w/ one stuck in locked position
  35. 22RE Timing chain(again)
  36. Power Steering Pump Failure?
  37. Valley Coolant Bypass Pipe
  38. 92 4runner manual swap questions
  39. 94 4x4 below-deck maintenance
  40. PLEASE HELP! No start on 93 22re no injector pulse
  41. 1988 4Runner SAS Questions and Parts Hunt
  42. Third member caught up HELP
  43. No start on 86 Pickup 22RE
  44. Looking for Part number for these inserts
  45. Passenger side door lock
  46. Oil Pan Gasket question
  47. brake master cylinder reservoir Grommet help
  48. A340 Automatc Transmission won't engage in Drive
  49. A340 Automatc Transmission will not engage in Drive
  50. Need Help. Changed KS now no power can’t go over 40mph
  51. 86 Toyota SR5 Loose Wire Red With Yellow Strip
  52. 3vze water outlet sealant
  53. acceleration problem
  54. feels like im in 1st gear
  55. Battery and Brake Light Anomoly
  56. Troubleshooting Speedo/Odo issues...
  57. Strong Exhaust Fumes in Cab 89 4r 22re
  58. Intermittent play in steering wheel
  59. 1993 4Runner high beams no low beams
  60. new leaf springs for 94 pickup
  61. Dashcam - anyone have one installed on their older Toy?
  62. 1988 4runner v6 exhaust pipe- who sells?
  63. Replacing DLX Dash Bezel with SR5 - Will it fit?
  64. 1986 pickup, lifted, with "steering column" issue
  65. Nothing wrong with stock wheels
  66. Steering Knuckle Wear
  67. Knock sensor harness to wiring harness
  68. Yota1 3vz crossover delete
  69. 3vz Code 52 replaced and tested everything (confused)
  70. 22r Carb 1/4 throttle
  71. Crank no Start Problem
  72. Seal in type windshield instead of glue in
  73. Power window switch
  74. How to go about selling my rebuilt 22re engine and related parts
  75. Where the heck does this go?!
  76. ARB CS019R Springs + & 0
  77. Land Cruiser Mirrors on a 1st Gen 4Runner
  78. Rough Running, '93 truck: Random, Intermittent over Long Mileages
  79. 89 pickup blown engine???
  80. 88 4Runner 3VZE crank, no start no injector pulse
  81. Misfire cylinder 2
  82. 1995 4Runner W56 clutch shifting troubleshooting
  83. 87 4Runner new power window switch
  84. AI posts
  85. New Head Gasket, TDC set, Dizzy set, will not run
  86. 1992 4Runner truck issues. 3vze, auto
  87. 1990 truck windshield gasket
  88. Shops in the Midwest for Engine Swap
  89. Anyone know what hose this is? 1989 22re
  90. 90s toyota Elocker wiring install
  91. 1986 Pickup RWD Power Steering Gear Box Grief
  92. Heater Core Hoses + Coolant Burping
  93. Torsion Bar Adjust Bolt Discontinued Part
  94. Sudden severe misfire - 88 22RE
  95. 1991 Pickup DLX 4cyl Automatic Transmission Neutral Safety Switch
  96. Any Tailgate Experts Out There??!
  97. Timing belt shredding
  98. 89 4Runner 3.0 Auto Transmission Rebuild A340H
  99. G57 Stripped Gears
  100. Random loss of power while driving
  101. 97 4runner shifting issue
  102. 88 22R Pickup newb
  103. Transmission Swap Questions
  104. Charging and brake light on but alternator is charging.
  105. 88 4Runner 3.0 water bypass question
  106. Bubble Vent Guard For 94?
  107. 1988 4Runner | Clutch Adjustment Issues
  108. O2 sensor extension !?!?
  109. 93 ecm correct ecm
  110. Help
  111. Exhaust diagram 87 2.4 22re
  112. Exhaust diagram 87 2.4 22re
  113. 1st Gen 4Runner rear 6x9 speaker brackets
  114. 93 22RE wont start
  115. Asking to be certain - '94 pickup voltage regulator (2wd).
  116. 86 Toyota SR5 Throwing Codes While Driving
  117. front body swap
  118. W56c question
  119. 1st gen 4Runner rear cargo light T connector
  120. The Mystery of the Lost Horn...
  121. 92 pickup speedo bouncing
  122. Is this the knock sensor...
  123. 22RE occasional idle bounce
  124. 1988 22RE Engine Block Crack Repair Update Video
  125. Steering gets stock when breaking
  126. 92 pickup parking light question
  127. 1988 v6 3.0 4Runner Limited RPM when in gear
  128. 86 22r
  129. 93 extended cab v6 4x4 (exhaust) search!?!?
  130. 95 22RE 4x4 IFS pickup shocks
  131. battery light/ battery at 12.06v at idle
  132. Lost Idle 1987 PU 22R carb
  133. O/D codes
  134. Need alt or '87 22R
  135. Help with 84 20R head on 87 22R block
  136. B+ jumpered to FP: constant sound of running fuel?
  137. Driver side window
  138. 4Runner Front Seat Comparison
  139. O2 connector backwards
  140. Oil Pan
  141. Update on Horrible Gas Mileage 91 Pickup V6 3VZE
  142. 4x4 Not Working Throubleshoot Help
  143. 3vze sluggish and motor lug until you put gas in it.
  144. No A/C after head gasket replacement
  145. Advice to swap or not 1987 Toyota 4Runner
  146. No noise from fuel pump
  147. 1990 Pickup Electrical/ECU Headaches
  148. Idle Fuel Cut Solenoid Diagnostics
  149. 1986 SR5 rear axle.
  150. Ran fine. Shut it off for 30 minutes. Crank, no start.
  151. 32's on stock gears
  152. Floor Mats
  153. Mice control
  154. CT20 To Garrett GT25R Turbo Kit For 22RTE
  155. Bellhousing bolts rattled off...?
  156. T731 Distributor doesn't match size of OEM
  157. Exhaust drips black
  158. 95 4Runner Code 52 after cutting off connector
  159. delay wiper problems
  160. 92 pickup stereo wiring help?
  161. tailgate hangers
  162. 22RE leak,Please Help
  163. Transmission issues-Tucson area Mechanic?
  164. '91 Pickup 22re Overheating Only on Hills
  165. Unable to find part.
  166. 4Runner runs for a second then dies. SOLUTION!!
  167. 94 V6 truck surging at 2500rpm and smog fail
  168. 22re runs terrible on warm starts
  169. 22R with 33s and 5.29s
  170. Computer / ECU
  171. Code 25 with new K&N air filter
  172. Best fitting upper ball joints 93 v6 ext
  173. E-brake light
  174. 22re bogs when accelerating but revs up fine after 1500 rpms
  175. Cylinder Head Cracked at Manifold Mount
  176. Thanks for the help
  177. Temperature gauge
  178. 3 1994 Toyotas front end noise
  179. Jake brake kind of sound when I slow down
  180. Exterior Chrome Molding
  181. 1984 Toyota 4Runner headlights won’t turn on.
  182. 2nd Gen 4Runner 3.0 SR5, Graphics?
  183. High hydro carbons/intermediate misfire 2500 rpms
  184. power steering 1991 pickup
  185. Cargo Bags that attach to your roll bar
  186. Another A/T to M/T swap thread.
  187. Mystery oil pressure loss
  188. Los photos
  189. 22r-e stumbles and dies when hot
  190. Oil Pressure issue 3vze rebuild motor from Shop
  191. Heavy duty starter needed.
  192. Poor MPG
  193. 22re No oil to filter ??
  194. '88 Emissions Parts Needed
  195. 92 Pickup wiring gremlins...help please!
  196. ADD relay location
  197. 1992 pickup clutch master and slave cylinder
  198. Unused interior electrical connectors
  199. 89 3VZE 5sp cold start circuit dead short
  200. AC Replacement Options
  201. no pressure building in brakes after MC replacement
  202. 89 pickup 4wd 22RE blower motor not working
  203. Blower quit working 93 toyota pickup
  204. A WIW thread
  205. Crankshaft pulley bolt flew off
  206. Transmission module wiring diagram 1986 pickup
  207. 1991 4Runner 3vze Auto Intermittent Starting
  208. Dual Transfer Case Options
  209. Anybody Used Xtreme Performance Transmissions?
  210. Charging System Issue (test results included)
  211. 1991 Toyota pickup
  212. 87 pickup stalls when clutch is let up
  213. Intermittent slight vibration from front drivers side wheel.
  214. Headlights Dim in High Beam
  215. Searching For: Black Front Grille + Turn Signals for 4Runner That Actually Fit
  216. 94 3.0 4x4 auto wiring harness compatibility?
  217. Door hinge creaking
  218. 1995 4Runner vacuum question
  219. 1990 4runner auto transmission kickdown issue
  220. Pickup sunroof removal
  221. Should my t-chain guides look like this?
  222. Consolidated ADD defeat Info
  223. 93 22re truck mystery oil disappearance
  224. Windshield molding replacement
  225. 88 3vze fuel pump wiring issue
  226. 92 pick up starting issues
  227. Rain water inside cabin ( Passenger Footwell)
  228. Trying to finish my Marty McFly Truck!
  229. Rear wiper wiring plug schematics for a 1992 Toyota 4Runner
  230. Truck stopped vibrating and 4wd not working
  231. Torque of front brake dust shield/Backing plate on 1988 Toyota 4x4 truck
  232. Temperature gauge low/not registering SOMETIMES
  233. 3vze 93 4runner: 4wd high not engaging
  234. 93 Toyota Pickup
  235. Noticed weld on chassis! Advise please
  236. Auto to manual tyrans swap.
  237. '88 22RE auto 2wd truck, 6 months into the same 'lectrical gremlins
  238. Seat belts
  239. 1988 22re issues
  240. Cowl louver removal
  241. Rear lift
  242. Need Help fixing a Code 22 and Code 52
  243. Chassis paint advice
  244. Engine fuse block diagram for 1986 22re 4runner
  245. In Need of a new Radiator ( '88 V6 3.0 4x4 5 Spd Manual)
  246. 89 4runner engine dies after driving for a short period
  247. Speedometer/Odometer operating sporadically
  248. Transmission for a 3.4L swap on an ‘86 4Runner
  249. California smog for pre ‘95 after 2025?
  250. Same problem 3VZE truck starts but stalls immediately
