PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Where can i buy a the fuel line can't get at autozone?
  2. Front Vent Window Replacement?????
  3. Gets hot and kills engine
  4. Turn signals quit!!!!
  5. 22re hesitation
  6. 4x4 vibration and pull
  7. Newby to this site, 3vze overheating, troubleshooting, please help
  8. rollbar compatibility
  9. rear heater not working
  10. VSS wire grounded on TPS??????
  11. Changing axle boot, need help!
  12. OBX header on a 88 22re
  13. New 3vze heads are in, few questions
  14. Locking Brakes
  15. Droopy Doors? Easy Fix! On a Budget!
  16. Setting torsion bar IFS suspension
  17. Found some bucket seats!
  18. Electric fan to mechanical
  19. 86 22R Weber 32/36 issues
  20. Can eng and tranny come out at once
  21. 88 22RE timing chain guides
  22. Engine sludge, to flush or not to flush? (22re)
  23. 3VZE Denso plug wires part #
  24. Fuel injector connector plug part #
  25. 91 Hilux Diesel Conversion
  26. Transmission not shifting, electricial probs?
  27. Dissabled egr, Questions.
  28. I cant get my 22re to disconnect from the transmission
  29. New to Toyotas, intermittent starting problem
  30. Where did I put that pinout diagram?
  31. 3.0 starts then stalls
  32. Slave Cylinder issues
  33. 91 4Runner mysterious suspension creak
  34. camping in a 1st gen 4runner
  35. 93 22re no compression on cyl 1&2
  36. Rear End Roaring
  37. Crankshaft Gear Removal
  38. Automatic Transmission rebuild advice
  39. 1st/2nd gen 4runner driveshafts?
  40. clutch Release bearing about to go after 20k miles
  41. Swapping a 91 3VZ into a 95 4Runner
  42. I need a Cluster Visor for my 94 pickup! anyone?
  43. 94 4runner, front half shaft replacement
  44. Keyless entry
  45. 3 VZE sparatic rough idle... could it be coolant temp?
  46. 91 3vze pickup missing on two cylinders, help me diagnose
  47. What is this wire go to? (Ground Wire Plug)
  48. Can a 3vze intake manifold and plenum be used on a 3.4 v6?
  49. AT Transmission Woes and a weird CEL
  50. tire clearence problems
  51. Finally Flopped the truck!!!
  52. air bubbles in clutch master cylinder reservoir
  53. hot dang! 3 22r builds in a year!!!!
  54. 3.0 rebuild
  55. 1st Gen 4runner: Top put on today, rear window won't move...
  56. Basket and Brush Guard Added!
  57. testing the knock sensor, OHM meter and continuity?
  58. 22re low idle when started warm
  59. Driver side door handle problems, need help please!!
  60. 89 Runner No fuel at Cold start
  61. no speedo/odometer 92 toyota
  62. Codes 41 & 51.! 3vze wont even crank... HELP!!
  63. 87 22re wont rev over 2200rpm????
  64. Rebuilding options
  65. 22re eating o2 sensors... lost
  66. 1992 4runner no power
  67. Simple MOD to check fuel pressure
  68. No Spark - intermittent...ish
  69. Shock rubbing
  70. Possible head gasket problem?
  71. Unusual blowby 22re at least I think it is blowby??
  72. stock 89 toyota rims...questions.
  73. Rebuilt 22re will not turn over....is my disto or timing chain off?
  74. 92 toyota 4x4 22re new clutch,new motor Ect any advice?
  75. Optima battery?
  76. ca smog help
  77. Noise in gears 1-3
  78. No Warm Idle---3vz
  79. 91 4runner clutch problems
  80. 3.0 Hard start when warm
  81. Idle surge problem 22re
  82. Random Idle - 88 3vze
  83. 1,2,3,5 good but 4th is slipping
  84. Coolant temp sensor connector
  85. Missing Plug
  86. Not the TPS.... Maybe I'm missing something
  87. 89 3.0 is puking coolant
  88. wanted....windshield visor for 92 pick up
  89. glowing cat
  90. intermittent sputtering...electrical?
  91. Electrical / Sensor Quirk?
  92. when replacing the timing chain, be sure to get the gears on the right way
  93. valve shims?
  94. Steering Wheel Lock Removal
  95. Painted the Yota last week.
  96. 22re shaving the flywheel!!! anyone do this?
  97. Cooling idle down
  98. 2003 Tacoma rims???
  99. noisy exhaust after accident
  100. '89 4runner-Tranny fluid bubbling and burping out of shifter hole
  101. Bi metal valve
  102. manual boost controller
  103. Part Number Request: "Fuel Pump Tube"
  104. Tighten door handles?? '92 DLX Pickup.
  105. what is this part?
  106. “fuel cut RPM”? Motor Lopes @1600 to 2000
  107. parts sources for used parts/bumpers/parts etc
  108. alternator wiring: 94 4runner v6
  109. Seal for steering column
  110. Oil viscosity... synthetic or not, in 3VZE?
  111. plastic fender protection piece
  112. All Pro's new bumper for 3rd gen trucks
  113. anyone know any reputable shops in so cal, inland empire?
  114. Will Not Start! 22re 1990 truck.
  115. my first accident...89 pickup questions
  116. i need to jump the fuel pump
  117. High Idle=More use of gas..Need advice
  118. Dent Dilemma. 1987 4Runner
  119. 3.0VZE intermittent stumble and longer crank to start
  120. 1988 Toyota truck clutch question
  121. kinda high idle than normal
  122. Unhappy Sunroof Issue
  123. Idea on way to pypass the PCV and other breather
  124. Cant Find my CLS check Engine Light
  125. 3.0 vs 3.4 trans 5spd..
  126. 94 4runner body swap
  127. Cranks, Sparks, No Start: Who's Pulled Their Fuel Tank?
  128. code 14 distributor or igniter missing at low rpm but smooth above 1300
  129. sun roof not catching
  130. 2nd Gen 4runner 3.0 intake options
  131. turn signals quit
  132. Aussie locker
  133. cold high idle fluctuation with weber question
  134. 93 toyota truck please help!
  135. 3.0 to 22re conversion - what is needed
  136. 89 4runner motor jumped time? clueless
  137. light bar
  138. Exhaust Bracket / Clamp, what years?
  139. Spindle Bushings/Replace?
  140. Hot start issue...head gasket???
  141. Weak window defroster
  142. A/T temperature light
  143. 88 truck die randomly then runs rough and hardly starts.
  144. Fuel Pressure Leak
  145. 1990 3vz-e
  146. anyone change a heater core on a 91 4runner?
  147. 88 3.0 v6 problem
  148. Fuel Pump Electrical Issues
  149. Painting 1st gen 4Runner top
  150. loss of power when it rains????? HELP
  151. Will 2nd Gen Running Boards fit a 3rd Gen?
  152. Is This Idler Arm Rebuildable?
  153. New Shoes!!!
  154. 88 22r Fuel pump problem.
  155. 86 P/U 22R low rough idle, almost dies on decel and backfires
  156. A/C Bracket and Compressor differences
  157. Body Lift Help
  158. gasket sealant needed?
  159. Knock/Clunk Noise coming from IFS?
  160. Engine codes: 71, 52, 27
  161. Failing flywheel...
  162. What's this part called & why does anti-freeze leak from it??
  163. Manual hubs/spindle bushings/a couple o' questions...
  164. Looking for stock body bushings
  165. weird vibration help
  166. New Cup Holder Idea.
  167. Trailer Connector Problem
  168. 89 4runner v6 won't start after water pump change
  169. Flopped.
  170. '93 V6 with starter trouble
  171. lockrite problem "clunking" "jerking" jerking need advice
  172. Starting issues, very weird
  173. Tailgate issue: 91 4runner
  174. Positive battery clamp snapped
  175. Fuel injector R&R 3vze
  176. blown head opinions
  177. O2 Sensor wiring ?
  178. Timing mark jumping around
  179. Runs rough then dies
  180. T-case selector popped loose
  181. Spartan locker not disengaging! please help
  182. Rubber bumpers, fuel and drivers door
  183. 3.0 vze piston rod caps torque?
  184. 1994 vacuum diagram
  185. Idiot figures out answer to HG no start. Film at 11:00
  186. easy way to loosen crankshaft bolt?
  187. Got a new truck!!
  188. tell me where these plugs up to
  189. 1987 4Runner passenger side window power motor install
  190. 93 2wd auto w/ 87 5spd 2wd rearend?
  191. Does anyone know anything about transmissions?
  192. Resistance question VAF
  193. cant get this 87 to run right!!!!!
  194. '95: how many o2 oxygen sensors?
  195. strange leak around thermostat area? block leak?
  196. ome leafs one side lower than other
  197. New 3VZE... may have an issue.
  198. Sludge in the diffs??
  199. Mechanical Water temp Install Question
  200. 93 4runner fuel tank in 91 pickup?
  201. Coolant line or vacuum line...I don't know?
  202. 95 4runner hesitation
  203. 22r head on 22re block?
  204. 95 Auto Transmission leak
  205. Which Aussie??
  206. Holley tuning.
  207. Cheap 3.0L build help
  208. A/C, what potential problems?
  209. Holes on the inside of the 22re TB
  210. Compression ##s?
  211. Transmission mount smoked? and questions..
  212. 22ret with blow by?
  213. URGENT: Fuel pump compatability?
  214. will O/D light flash if speedometer cable is broken ??
  215. Crankshaft Pulley
  216. Old Toyota Out-Pulls New F-250~
  217. 3VZE down on power
  218. Truck wont start in the morning.
  219. I cannot find the horn relay on my 1991 Toyota 4x4 pickup.
  220. 88 22r Backfire and Bogging
  221. aftermarket cam, valve adjustment?
  222. rough idle wants to die any ideas
  223. 3.0 in the rain
  224. help on my front end
  225. dirty fuel from fuel filter
  226. gm 350 engine swap questions.
  227. HELP! I wrecked my 1988 pickup! Need advice!
  228. 95 4x4 pickup 22re with rv cam/power issue
  229. So after doing my timing belt, water pump, knock sensor and wire
  230. 3.0 Timing
  231. Another Winter, Another Toy
  232. rear tube bumpers and towing
  233. 86 4runner-throttle/kickdown cable assembly
  234. For Sale 91 4runner 3.0 5spd
  235. cost-benefit advise needed for headgasket repair
  236. Weird possibly electrical problem?
  237. 3v cams
  238. tech help engine swap
  239. Running on broken water pump belt = death?
  240. Strange starter issues
  241. Trouble with dome light turning on for door
  242. fuel pressure relief
  243. No spark on 91 v6
  244. I relocated my knock sensor and...
  245. Cel codes 21 and 52 But with a twist..cel go off after warm up...
  246. 1991 3.0 Head gasket Repair advice
  247. Valve adjustment.
  248. Power Steering Box adjustment or rebuild?
  249. Which cam (poll)
  250. Tachometer doesnt read at idle when cold?
