- Emissions help
- Another no start Runner? ,3.0 diag advice plz...
- Do I have a spun / spinning bearing?
- Brand new engine make "wrong" noise
- Need help confirming ride height measurements
- Bellhousings
- Replacing a Rocker Arm
- hard starting all the time
- Tcase/4wd engage "brakes" vehicle - is the Tcase ruined?
- white smoke...Im confused
- bump stop clearance?
- Unusually high compression 180-190 psi = Carbon build up? Possible head replacement?
- 4Runner dash lights issue
- problems with lifting my 94 its on jacks i cant drive it till i fix
- cold start injector fuel line ?
- New exhaust,now boost creep on 22rte
- LED tail light bulb problem! HELP!!!!
- Terminal wires question
- Question about 80a AM1 GLOW
- Ring and Pinion Jig
- HELP!! brake problem
- I seafoamed my 3vze
- Power steering idle up valve thread size
- Smell making me nauseous and eyes burning
- Interior question. rubber floor liner?
- no heat on passengers side
- supra LSD into the 4runner
- R150 tranny ticking noise
- Issues after the Trans Swap
- New ProComp rims
- 22re Head Gasket job
- Ringing noise @ 2000 rpm
- $runner 4WD light
- Many questions about rebuilding a 22RE
- 94 Runner pings badly only when warm
- rear end sag
- Trouble with timing
- 4wd squeek/grinding noise
- 22r with weber 34 dieseling and has extended crank while warm
- 22re No Idle and surging at 1700 RPM
- Adding AC to a 94 22re. Need list of what I need!
- Anyone know the oem part # for a 94 toyota 4x4 leaf spring pack?
- Rock exhaust manifold gaskets (popping noise)
- So I reverse jumped my truck tonight....
- Wiring Harness & Transmission/Transfer?
- 3.0 V6 Radiator Issue??
- Head rear plate gasket or FIPG
- continuosly rotating timing mark ???
- Contemplating a cab swap this summer...
- Engine Stalling Mystery
- i love my Addicted Offroad bumper!!
- name this shifter part for 1989 4runner..please?!
- Crankcase Vent. questions
- Replacing Valve Cover Gaskets
- Bad gauge cluster?
- 81 Toyota 4x4 door panel removal
- Inner axle seal replacement
- possible head gasket
- clutch fork wont move!! help!!
- DAKOTA bench seat?
- 85 rear seat
- Component name needed
- Rear end noise?
- 22r still overheating
- cooling system full of rust
- 94 Pickup, is radiator seal replaceable?
- 95 4Runner automatic transmission shot?
- Rough starting and sputtering out of exhaust
- possible blown rod bearing
- Having brake issues.
- error code 52 fixed!!!
- Looking at picking up this engine and boosting it!
- 3VZ-E low comp. on cyl 1
- tuning ideas
- Replacement for broken leaf springs
- 2wd axle shaft question
- EGR Valve Gasket?
- 91 22re no start
- Questions Before Swapping Differentials
- stutter at 45 to 50 mph
- Front Drive Shaft Binding
- 93 4runner 3.0 motor/tranny questions
- any custom long travels out there?
- Corbeau bucket seats
- Replaced Timing Belt Problem, wont stay on marks
- LT IFS wheeling capabilities?
- Rough Idle and noise coming from fuel pump
- Does anyone make bolt on exhaust for the 3vze?
- DISTRIBUTOR doesn't fit anymore!!
- 22re deck warpage
- Air in take hose hitting coolant hose after body lift
- Oil leak, 3VZE, pass side, oil cooler?
- quick help w/ transfer case fluid please
- My very first truck. (Pics)
- Clutch/Trans issue
- Help on Speedo Repair
- 4WD Clunk! Help
- Anyone had a cam gear with missing teeth?
- 93 3.0 can't get rear drum off...
- '88 Rear bump stop length
- injectors
- A.c. Idle adjustment?
- No more Brush Guard! =D
- 3vze fuel pressure vsv.
- Manual hub unlock on the highway?
- 1988 distributor cap problem
- PS Pump on the way out? Fluid in vacuum switch hose...
- Thorley 22re headers
- Silly question: A.R.E. topper on a 1st gen 4runner?
- 91 3.0 just replaced HG- now coolant leak and thin white smoke
- overheating after front end collison
- 93 22re oil leak & engine code help
- 3.0 rebuild help
- 89 22r to a 86 tranny that had a 22r on it
- remove gas tank 94 4wd
- Clutch Replacement Recommendations
- Change oil no oil in filter
- coolant temp sensor from hell
- 3vze with high idle and slow acceleration
- Slip yolk stuck
- 3.0L V6 auto 4runner problem at highway speeds
- maybe another headgasket :(
- How much is missing off this tchain cover?
- Ways to carry kayak
- Spark Plugs Gapped Too Far
- EGR valve replaced,now idling and running rough
- need labeled engine pic?
- Strange cooling system goings on (22RE)....
- Oil in distributor
- side trim removal help
- Brake booster master cylinder info for 1988
- no power maybe too much fuel
- 22re hard to start when engine cools
- 22re keeps blowing header gasket???
- Modify Extra intake?
- How long should I break my motor in for?
- 3rd and 4th dropped out today (transmission problem)
- Mud in the Frame!.. Help
- Opinions: 22rte mpg & gearing
- Rough idle and runs rough after warm up???
- Rebuild Supra LSD, blew mine out wheeling
- Hydraulic or mechanical clutch issue?
- Headlight problem (Fixed) – Low beams don't work, but high beam indicator is on.
- 2nd gen wont shift when cold
- 89 sr5 ext cab seat swap
- Sensor in front of oil filter 1991 3vze
- Front Fender Removal - '89 4Runner
- 3rd generation rear leaf spring help
- 22re head with kungfu grip
- bed is leaning back
- Starter Heat Shield a must?
- Identifying 3vz Connector
- 22re Factory Air cleaner housing Differences?
- why does my tach stay at 3500rpm
- 93 4runner 2wd auto transmission help
- Quick Slave Cylinder Question
- 95 4runner 3.0 head/engine removal
- overdrive solenoid
- egr
- Rear brakes refuse to work...
- Replacing 22RE LB - What else?
- 91 4runner 22re Rough idle when warm, No Power
- Hood mods (scoops/cowls)
- hard to start but runs great
- Water dripping on rear right passenger seat / under seat.
- Bypassing Door Control Module
- What else should I consider doing to my rear axle? Zuk mod?
- 95 3.0 high idle
- Timing Gear Thread Pattern
- Body swap Question
- 94 3.0: replaced heads, runs poorly-misfires
- question about bed.
- 87 Rear Tailgate Wiring
- Rear truss with diff drop kit installed
- trail gears 23 spline input
- need help spindle seal
- 87 toyota pickup restoration
- Oil Pan Removal and Eventual Top End Rebuild
- Idle slows to much when hot
- Oil in coolant but not coolant in oil.
- Is 44psi fuel pressure too high on 22re?
- 4Runner 1st gen to 2nd gen dash swap possible?
- my massyfurgeson gray under $50 paint job
- 95 Pickup problem
- 1990 2door runner wont stay at idle
- Engine Problems/Questions
- Wrong spindle bushing??
- Rough idle on brakes but not when in 4wd
- A good use for the ac button
- problem with my 1990 4runner
- 1st hand input on exhaust size?
- Rattle after rebuild
- no spark from distributer?
- Coolant change on a 1993 22R-E . . .
- 22r / 22re build up... possible hybrid?
- transmission swap
- transfer case drain bolt fell out
- 93 4runner runs for about 15min and dies
- crank window regulator cheap fix
- Fuel Consumption Issues???
- 91 pickup door skins
- Blown 3.0 what to do?
- Anyone know where this was connected to
- 22rte to 22re
- Tranny shifting issues
- 22RE with good power low and high, sputters in middle
- could a new pcv cause high idle?
- 22re rebuild pictures
- Oil pressure gauge question
- reed valve and fuel filter
- 22re wireing headach
- Nochange in idle even after setting the tps, help
- 87 to 94 rear clip frame swap
- keep going through starters
- amber dash light swap...extended
- What is this part? Brake related?
- Load distribution, roof rack, 89 4runner
- Knock ->rough idle -> Spun rod bearing sad day (pic heavy)
- 1999 Honda Prelude Seats
- How can I get a btter ride out of my 87 4runner?
- Made in Mexico torsion bars?
- 1988 4runner wilwood proportioning valve install
- New here with a question.
- Weatherstrip for 1988 4runner?
- 3VZE "STOCK" Cam Timing
- home made body lift shifter extention
- EFI factory settings?????
- What is the second oil filter looking port on blocks driver side
- Wasn't someone making/selling knock sensor pig tails.
- 91 22re Idle surge at startup, low heat from heater
- 3.0 coolant leak and injector questions
- Foamy power steering fluid?
- Oil in the throttle body
- Random Tail Light Flicker??
- my 22r head rebuild
- Rock Headgaskets
- TPS setting/testing
- Heater Switch - No heat, I'm cold.
- 22re Wont Stay Running
- smog deal
- Can't fix temp gauge overshoot
- 22re diagnosis
- truck died, oil light on with plenty of oil
- 91 Pickup 1 - 2001 Galant 0
- Oil pan clearance
- Repair IFS or SAS
- rogue wire. anybody know where it goes and what its for?
- V6 3.0l wont start!!!!!
- Which Weber.
