Coolant change on a 1993 22R-E . . .
Old Feb 14, 2011 | 11:10 PM
Aron9000's Avatar
So I'm going to do a coolant flush on my sorely neglected 1993 2wd with the 22R-E.
Any tips or recommendations? I've done brake jobs, oil changes, spark plugs on a ls1 v8 camaro(PITA!!!!), stereo installs, but never really worked on the cooling systems.
I've read about how you have to run it with water after you drained the coolant, then drain and run some more water through it. I plan to add some Prestone radiator flush after I drain the coolant, god knows the last time it was changed.
So should I use the flushing chemicals or not? How many cycles should I run water through it? Is tap water okay?(its municapal water where I live, its not hard, rusty or otherwise funky).
Old Feb 15, 2011 | 07:22 AM
spokane.yota.man's Avatar
Drain. Fill with distilled. Run. Drain. Fill with distilled. Repeat until it looks like only water, then add antifreeze to make 50 to 60 percent concentration. Only use distilled water and make sure heaters are on so you get the coolant from the cores. make sure engine is fully warmed between flushes.
the1998sr5
15
Jul 14, 2020 08:35 PM
Colington
Mar 8, 2020 09:51 AM
WellsR
12
Jul 31, 2015 03:27 PM
PlayAwhile
Jul 20, 2015 11:36 AM
the1998sr5
Jul 16, 2015 06:20 AM
