PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. The Famous Starter-NO Click
  2. Vacuum Hose Routing on 3VZ-E
  3. no brake pressure at all....
  4. 93 4runner failed emissions, need help!
  5. 3.4 underpowered??
  6. cross pin shaft removal
  7. Jungle Fenderflares Preview
  8. Idle (Keep Reading) With Foot on Brake
  9. 86-95 FAQ Section: check here 1st, your answer may be here, consolidated stickys
  10. Instrument lights/dimmer problem
  11. fuel pump issues....
  12. Stabilizer Bar
  13. CEL after 200miles on a new long-block
  14. The best aftermarket manual locking hub
  15. Check engine light issue
  16. 1" Body Lift Not Enough for 33" MT-R's?
  17. 1987 4runner exhaust help
  18. rear axle
  19. 91 4 Runner running rough
  20. slip yoke, interchangeable?
  21. headlight issue
  22. 1991 Toyota Pickup blown headgasket maybe
  23. Grinding/whining noise
  24. 86 Pickup Radio Wiring
  25. New Member hello and questions
  26. Installing Powering Steering
  27. Machine shop/ Engine work??
  28. Misfire after rebuild
  29. not your average miss on 2 seperate cylinders! feed me feedback please!
  30. windshield sprayer problem
  31. no horn
  32. downey off road donahoe racing 4runner
  33. U Joint Removal HELP!
  34. what did you pay for machine work?
  35. ARB winch bumper install help needed, got directions?
  36. Source for valve adjustment tool, misc other stuff
  37. Help Identifying 2 Plugs 3.0
  38. Question for u ZUK modders....
  39. U joint play
  40. timing belt q
  41. box year innerchangibility
  42. intermittent starting issue
  43. Hidden intake manifold bolt
  44. warning lights comes on from cold start
  45. Head Crack likely on 3.0?
  46. ADD (Automatic Differential Disconnect) is NOT Auto Hubs - Explanation and Details
  47. 3vze pinout help!!!!
  48. Inner quarter panel replacement
  49. LCE for your 3vze
  50. steel timing chain guides?
  51. Popping after motor rebuild
  52. 3.0 V6 issues
  53. 86 22r head swap to diesel? possible?
  54. Missing Bolts......
  55. electric fan vs clutch fan
  56. Where do these connectors go? 22RE
  57. Is this an ignition switch problem?
  58. 22re missing unless disconnect egr
  59. Interior swap
  60. Rear main seal
  61. Valve seals/timing chain 86' 22re
  62. 92 pickup cts
  63. Shock Question. Pick-up vs 4Runner
  64. peculiar rebuilt 22re issue
  65. 22re sick when wet, sick tps, sick timing advance
  66. Ideas on How to Connect 3.0 Starter Wire
  67. Stock height coil springs
  68. EPIC FAIL!!! your gonna love this
  69. will someone take a picture?
  70. I finally found my smoking problem
  71. Repair manual ?
  72. First Gen door fitting
  73. difference 91 3.0 and a 95 3.0
  74. Truck not starting. Solenoid issue?
  75. put in 4 inch bracket lift, front driveshaft wont hook up
  76. HVAC control function doesn't change
  77. who makes a 6 inch suspension lift??
  78. Trying to Remove a 22r Intake Manifold
  79. electric fan time!
  80. Vacuum system Help!
  81. 1987 22re Ex-Cab Parts Diagrams Online
  82. A different broken TVV
  83. Gear swap question v6 - 4 cyl
  84. 91 yota 4x4 rear antilock?
  85. just replaced clutch, now noise in 5th gear
  86. Trying to figure out oil leak
  87. 92 4runner rebuild and the curse of the motor mounts
  88. 86 Turbo 4x4 auto trans issue
  89. check main and rod bearings or not
  90. code 3 always and code 10 (new) and sometime code 6
  91. Sas yota
  92. acceleration problem
  93. Sudden Jolts
  94. The ECT Power Button
  95. rear diff
  96. I thought my truck was made in Japan until.....
  97. 22r blue smoke bad !! Good compression !! Please help
  98. Spindle nut preload
  99. ujoint help ..
  100. 3vze 4runner coolant leak after new radiator install
  101. 91 4runner 22re smoking on deceleration
  102. 3vze crank seal... and oil pump?
  103. IFS suspension changes.....
  104. 1990 pickup won't start
  105. 1987 4runner Smoking from PCV Valve
  106. Replaced my center console out of my 92 4runner with Tacoma one
  107. New to me 90 4RUNNER
  108. 4runner hvac blower switch question
  109. Impact gun on exhaust manifold studs?
  110. Plow setup questions
  111. Alternator does not charge on a hot day
  112. 2nd gen to0 tall
  113. Factory receiver and tube bumper
  114. Hood pins... Where did you mount them?
  115. Oil Temp Gauge - always in the middle
  116. No idea about the load sensing proportion valve
  117. Anyone cut a fuel pump access panel in their hilux?
  118. some time spent $$$$$ on turbo runner mods
  119. I need to know the name of this part......
  120. idler arm fa5040
  121. I have a dumb TPS/Timing question
  122. Changed carb and now white smoke please help
  123. Fuel Pump/Sending Unit help
  124. possible rear main seal leak
  125. Speedometer
  126. 22re running rich and lean?
  127. Help with speedometer cable issue
  128. upper a arm not realeasing??
  129. Part number for exhaust studs, 22re
  130. Good to be back! And a timing chain question...
  131. Transmission Help!!
  132. 3.0 v6 coolant leak
  133. rough starting
  134. question on a rear tire swing for 86 PU
  135. 22re and an elevation change, do I need to adjust anything?
  136. Three 02 sensors, and not one will give me a reading
  137. stalling after intake install
  138. All-Pro roll cage into exo cage?
  139. 22R engine noise
  140. boost at stall speed?
  141. Alterations for 33's
  142. 1990 2 door
  143. 22RE Solenoid Resistor ohm readings
  144. Ball (???) fell out of intake when removing head to investigate knocking noise.
  145. Post Pics of Your Roof Baskets On Your 2nd Gens!
  146. 4x4 not working
  147. running rich
  148. Which clutch do you like for a daily driver?
  149. Freshening up a 3.0 with 245,000mi
  150. Where does your Temp needle ride?
  151. 86 22r oil light
  152. Engine RPM's going up then down, then up and down by itself
  153. Misfire Help?
  154. 92 P/U new long block many trouble codes
  155. Cant get the Caliper's back on?????
  156. Replacing Engine, What Else to Get?
  157. my truck gets emotional and sometimes starts
  158. Pop sound when going into reverse
  159. 91 4runner wont start, injectors not working
  160. '88 4runner overheating - cracked head??
  161. Pop and Dead - No Start
  162. Anyone ever removed Radiator/Core Support
  163. Terrible, annoying squeak...
  164. No break lights, Dash, Markers
  165. Bogging Down While Turning or Applying Brakes
  166. dash lights out and electrical box unplugged in engine
  167. Swapped out my A/T for a M/T
  168. in the middle of working on my truck...how does the belt tensioner go back on
  169. AISIN carb trouble's
  170. Smoking Crack
  171. Frame problems need expert help please
  172. 22RE Vacuum adjustment
  173. cargo/camping system for a 92 short bed pickup (dialup beware)
  174. 91 toyota engine over heating
  175. 94 V-6 Transfer Case Help
  176. Pics of spare tire tool storage
  177. 1986 pickup tire question
  178. 22re dies in drive! help please
  179. 3vze oil cooler
  180. Low fuel light stuck on
  181. 1st gen 4Runner air helper springs
  182. bedliner fitment question
  183. HELP!!! Not Enough Back Pressure at EGR???
  184. Dying interior plastics
  185. Help with Bilstein 5100!!
  186. no crank, 87 4runner 22re
  187. W56 got hungry.
  188. 22RE noice.. help?
  189. Fuel Pressure Regulator comprehension
  190. what percent is front and rear brakes
  191. 3.0L V6 1990 4x4 truck door jam says 10/89 made in japan HEADGASKET COVERED????
  192. which radiator do i need?
  193. Electrical/idle problem
  194. Leaking waterpump, what all needs to be replaced
  195. 1993 Toyota 4Runner Slipping
  196. What does this wire connect to?
  197. 3vz fuel rail bleeder
  198. Ball joints replaced now clunky?
  199. Differential Stud Elimination, Pinion & Inner Axle Seal Replacement
  200. Fuel system issues with ignition error code 14
  201. Anybody know a good source for tailgate window switch?
  202. Can't Clear Codes
  203. milkshake possibility 1994 4 runner???
  204. 22r in place of 22re
  205. exchangeable parts
  206. Calling the carburator pros
  207. Riddle me this...waterpump?
  208. CLUTCH/START/CANCEL button
  209. Sliding glass rear window on my '93 pickup
  210. Help! mysterious (to me) electrical problems
  211. Fuel injector fitting
  212. Miss Fire on #3 Injector? really?
  213. Timing Chain Cover
  214. can you put manual windows in power doors?
  215. Got my addicted front bumper today!
  216. 22re rebuild Q's
  217. No more mutant exhaust
  218. Which factory air box is better?
  219. 1988 22RE TPS IDL-E2 problem
  220. will this starter swap
  221. The same but different Click but no start
  222. westjohns build thread 87 short bed, cammed
  223. 1992 pick up compatible seat belts
  224. 22re muffler question
  225. A good 22RE engine rebuild manual
  226. Key just clicks
  227. 22re Missing Sometimes?
  228. What's a 3rz with a spun bearing worth?
  229. TPS works better when not set per instructions
  230. Rear Diff.... HELP!!
  231. weber carb info
  232. Carb problem, or something else entirely?
  233. TPS why is this happening
  234. bad vacuum leak where to start???
  235. Just bought a 87 4runner 22ret and have ?s
  236. Rear brake hard line replacement questions
  237. Completely LOST Transmission giving me HELLO!
  238. 1stgen 4runner moon/sun roof latch question
  239. No start after valve cover gasket replacement: code 41&51
  240. CEL/3vze codes
  241. Please Help Diagnose: 87 4Runner Tranny sounds *violent* now
  242. 3.0 throttle body hose routes
  243. alternative to a bob?
  244. first toyota ever with a list of problems! :)
  245. 2nd gen rear bump stops
  246. 3.0 valve adjustment in N. CO?
  247. 87 4runner sas, finally starting the build
  248. 22re engine removal out of a 1993 pickup with manual tranny
  249. Possible engine swap this winter, need some advice from you gear heads.
  250. HOT turbo
