- pulling the 22re
- No idle after replacing intake manifold gasket
- quick power steering box question
- clicking popping coming from front of truck
- Squeaking/screeching sound in reverse
- 3VZ Hydraulic Tensioner
- lighting Problem?
- Adding Cruise Control ?.
- How Does a Roof Rack Mount to a Can-Back Soft Top?
- ECU Diagram for 1988 3VZ-E
- TJ spring lift
- 95 4runner short right turn
- ignition timing issue
- No Power to A/C
- Turbo R 151 F
- need bracket for caliper core?
- Head Gasket FINALLY Done!
- Cost of going from R12 to R134?
- not sure what to do with the runner now, looking for opinions
- Engine almost starts...I could really use some trouble shooting help.
- Front diff welding
- Exhaust Manifold Cracked - Advice Regarding Options
- HELP::Toyota measurement needed
- Any custom painted 2nd gen Runners?
- Unplugging the TPS in my 92 22re
- AC constantly needs to be re-charged can not find leak or cause
- Dang it Toyota!!!
- Quick coolant loss/head gasket question
- V6 master and booster swap.
- Really Frustrated - Engine Knock / Misfire
- Alright Gentlemen!
- 87 p/u paint project - urethane or enamel?
- loud clunk in 4wd
- 1st gen 4runner air condition problem
- fuel pump 93 quick question
- Built my custom tailgate
- Reed Valve 86 22r
- 86 22r Missing, Hesitating
- 1990 A/T Problems
- air intake problem
- 87 pickup broke frame
- TPS Termainal identification help
- Converting a front shift to a top shift
- Custom paint job idea. Need input.
- steering shimmy with lift
- 92 4runner rear seal/bearing
- EGR pipe removal
- 87 O2 sensor experts?
- MY BEASTS 1988 and 1992
- What is this and what does it do?
- 22R-E head SWAP 1988 to 1992 ????
- Need help with Bikini top...
- I need a bracket for a '94 22re A/C compressor +some other OBA Q's
- W56 Transmission Noise
- Will an 84 22R round port head fit on an 86 22RE?
- Will fenders and hood from 1st gen p/u fit on 86 cab and frame?
- Sunroof interchange
- Fender and hood swap
- Rear window won't go down - on a bind or rusted
- Alignment Question
- 2nd GEN 4runner tailgate window
- a/c help!!
- Finally found 2nd gen 4runner fiberglass bedsides!
- 90 4Runner Low power and gas Millage...Ideas?
- Carbon issues...Tried everything under the sun...I think
- Truck Alarm
- Front end re-build: Questions
- 3.0 starter fix
- both signals on at once??
- whats the part number for VSS (94 4wd auto, 4runner)
- Reverse lights are not working properly...
- Where to get piston rings?
- welding front diff
- No High Beams!!! 93 pickup...Why?
- stumped, R150f question please help
- 88 and 86 4runner parts interchangeability
- door glass comes out of track on 88 4Runner
- Tranny fluid mystery
- How can I test if my Fuel Sending Unit and Pump are bad / good?
- axle swap & conversion build-up
- Inclinometer
- upgrading the armor on my '95 4Runner.
- Temp Gauge Jumpy....
- Is the ECU supposed to do this?
- Shakey 4" Bracket Lift
- 4x4 not working
- SAS Shakedown Run
- 1986 22r carb
- No power. Clogged catalytic converter? ..Very long post with details..
- Will it last - HG?
- Recommend alignment shop in Walnut Creek, CA
- Temp guage bouncing around?
- 1990 4runner v6 auto tranny shifter
- A43D tranny problems and questions
- Clutch after swap issues Help!!
- A/C conversion R12 to 134a help
- 22re, 22r, 22rte Cylinder Head Differences
- Problem with bj spacers after install
- powersteering / abs help
- Rear Axle Leaking **PICS**
- Front valence removal.. pic request
- 1988 4runner 22re ~ Gas leak
- 3.0 dual oil filters installed
- 22re Rough idle after warmed up
- i need some part numbers
- t and e1 terminal help
- how to manually engage electric fuel pump?
- I Keep breaking front differentials
- strange power problem
- Remove '94 4Runner steering stabilizer
- Bracket Lift + BJ Spacers??
- water damage
- 86 P/S gear box Interchange with??
- Just did a Zuk Mod...
- Is Valve Noise My Problem??
- EGR Blockoff plates... stock ones.
- Can't peel out in dirt, power problem?
- Free (I think.....) 90 2x4 parts!!!!!????
- Pros/Cons of Rebuilding vs. Junkyard Swap
- No start after TPS adjustment
- 91 22re to 94 22re swap
- 3.0 engine knock from exhaust
- 87 22R running rough.
- '87 22R PU Horn Button Repair
- Compression test results..... Not so good!
- 22re Fuel Injector Wiring Issue
- Cleaning the inside of 3VZE upper intake????
- Newb, Need Help with Dads Truck
- front cross member and bolting
- Is this third member information correct?
- 86 4x4 Pickup Canister
- 88 4x4 rear brake keeps self adjusting
- My cat converter got stolen today :/
- 94 Pickup No Power, dies when throttle is pressed.
- 22rte swap
- a/c woes - expansion valve?
- The magic dip stick....
- It just stopped running
- Rebuild Time: Which option would you take?
- Stearlership opinion.....
- pictures of Kayline soft top mounted on 1st gen. 4runner
- moter turns over and has fuel but wont start
- 22re Timing Chain, ut oh, where did this come from?
- Random Questions. Help me finish my supercharger!
- Recent Tune up: Now it runs poorly
- Broken Emergency brake ratchet
- 91 baby runner wheeling photo's
- 1986 4runner starter issues
- stripped 22re exhaust questions
- 95 3.0 4wd AT help ! not shifting out of 1st
- Timing not changing in diagnostic mode??
- GM to V6 Alternator help
- Is MSD worth it on 22R??
- tranny noise
- '87 4runner Zuk rear spring mod installed - w/pics
- 22re spit/sputter
- Front diff offset
- Coolant Boiling....help!!!
- think my tps sensor is going bad
- anyone with 5 inch rough country?
- 1988 3vze Help
- New Steed Speed manifold
- 3.0 Low Idle When Stationary
- What year Extra Cab Pickups have rear seat?
- SAS'd the SwampThing3
- getting a deal on 1993 pickup
- 95 3.0 High Pressure A/C Line...
- 3.0 power loss help???
- Low Idel when warm
- ANOTHER oil pressure gauge question
- Ford EDIS4 crank trigger question to 22R pulley
- Complete loss of power in 95 4runner, possible problems?
- needle valve question ?
- toyota 4runner 87 problems
- Dropping the Oil Pan... opinions? (88 22re)
- Power Brake booster replacement questions.
- Exhaust replacement- Cat back
- 1990 4runner will not idle, fuel presure ?
- 3.0 help
- w58 transfercase question...
- Engine bogging down
- Fake Sonoran Steel Early IFS Truss?!
- 1st Gen 4Runner spoiler and roofrack retrofit
- Pre-oil valve cover gaskets?
- Surging Idle and No-start when hot
- Locked up wheel bearing?
- 94 4 runner brakes
- Removing lock tumblers from tailgate window switch?
- take off your top! wooooo!
- Won't start!
- Tow package from runner to truck?
- mystery tranny problem
- Injector spacer removal
- 2wd axle swap questions
- 1994 22re Pick-up Doesn't Like Heat Wave
- High Idle after engine swap/mystery vacuum lines
- code 51 and small miss at ideal poor acceleration
- problem with larger tires
- Budbuilt IFS Skid
- 22re Coolant tubes
- rod knock or exhaust leak?
- 22re mpg's
- Need some brake help/ideas.
- Help identifying FG fender and bedside
- EGR cleaning with head intact
- 87 22re dumping gas into engine......HELP!!!!
- speedometer reads faster than im actually going.
- Help please code 6
- Crazy fan speeds
- Engine problem - Fuel Injector?
- 22re sudden mpg drop
- How to Remove Sticker from Door Jam?
- Timing is off.... how to fix it?
- Time to start building
- Help....I broke the throttle cable!!!
- 22R and 5MGE alternator identical?
- major engine problem
- Life expectancy for 86 auto tranny?
- 1988 3vze 4x4 Pickup - Inc work, Advice?
- just bought 94 22re. slight ticking noise in the top end. any ideas?
- just fail smog test in cali.........
- Any results with a big bore throttle body??? 22RE
- SAS Completed...A Few Questions
- 93 brake setup replacement
- Rear Leaf Springs?? 2wd 4wd difference? interchangeable?
- Tail light Fuse keeps popping
- gutted out the yoter.
- my poor 95 4runner
- Box sides
- Some pics of a '95 4Runner work in progress
- Please recommend adjustable shocks for 94 pickup
- oxygen sensor test?
- Possible Head gasket ?
- replace CV axle & slight upgrade for IFS maintenance
- poly body mounts
- pouring oil. 86 22re
- 95 4Runner V-6 won't start-
- 1990 Toyo 4x4 Throttle body ???
- 88 4unner missing and backfireon acceleration
- 22re fuel leak
- Weber Carb problems - 86 Pickup
- '87 4runner shift problem - solenoid or tps?
- Shifter spinning around on the 5th/reverse side
- Suspension/Brake Troubles.. Thoughts?
- Splitting t-case from trans, input shaft bearing
- Weight Distribution
- How do I get codes
- UTP Ultimate performance chip to the Mass Air Flow Sensor
- Custom coil lift 4-5" ???
- Drive shaft play
