problem with larger tires
Old Jul 4, 2010 | 04:26 PM
rustyboltz's Avatar
I have an 88 base pu 2wd 4 speed. I have been running 215-60R15's all around and have now installed 235-70R15 on the rear. I have been checking and was told that these tires will not fit on the front. The distance from top of rim to wheel well is 7". I was told I need 15". Thru checking past posts, I have found out that my torsion bars are not adjusted properly. As a matter of fact, they are adjusted very very soft probably by previous owner to get a soft ride.
I have read about adjusting the torsion bar, and I have made plans to adjust them.
Is it possible to adjust the torsion bars to get the additional 8" of height? I really do not want to install a height kit. I would really like to go to the bigger 15" wheels.
Old Jul 4, 2010 | 04:44 PM
xxxtreme22r's Avatar
be careful with the measurements and make sure your measurements are for the 2wd, because the 4wd's measurement and also the fenders are different. I have 13.5" from my 15" wheel to my fender on my 4wd. Plenty of clearance for my 31" tire which is a heck of alot bigger than those 235's.
Old Jul 4, 2010 | 04:53 PM
rustyboltz's Avatar
from the top of the 215's to the wheel well, I have 3 1/2" for the tire to bounce before hitting the fender. With the 230's, I will have about 1" of clearance before the tire will hit the fender.
Old Jul 4, 2010 | 06:30 PM
Robert m's Avatar
with the torsions maxed out on a 2wd you will clear the 235s but when you hit a big bump or turn to full lock they will rub on the wheel well/fire wall. i had to do a 2'' body lift and pound the pinch weld flat to clear them with no rubbing. however the trucks ride quality was the harshest ride i have ever felt in any vehicle.
Flying91
45
Apr 11, 2024 04:39 PM
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
