- blown head gasket help in v6 3.0 liter
- Need help on 3.0
- Help! I'm immobilized.
- rebuilding engine?
- HELP ASAP brakes
- starter probs...
- 95 4Runner oils/lubricants and capacities.
- Lower valence, '90 Runner
- Faulty Fuel Pressure Reg.
- Whats this part? ASAP
- Ignition Timing (Problem?)
- Stock Intake Manifold ?.
- '88 4Runner 4x4 v6 Starting Problems?
- 1st Gen 4runner rear corner panel protection now available!
- 22RE code 41 and 42, rough idle
- How much is your truck worth?
- Need Brake help ASAP!
- Fiberglass or used body panels
- Where to buy rebuilt 3.0(Motorworks?)
- trying to get more fuel eco...
- 2nd Gen: Door panel plastic plugs/clips
- high idle 89 22re
- 86 front diff into a 94 4runner
- Replacing crank seal?
- where is the coil/solenoid in a 2nd gen 4runner
- '94 4runner power problem
- About Propane injection...
- 3VZE exhaust 'tick'...
- safari rack 88 runner
- bang bang fire o
- r150 into an 86 22re
- 86 Stumble/Missfire
- EGR code 71
- Bolt in end of cv?
- smt6 2nd gen
- 22RE Knock Sensor help
- Looking for wheelspacers.....used
- Opinion needed - rear oil seal
- Timing Chain Fears
- Volt meter in a 86 runner
- '90 4Runner Electrically Dead - Briefly
- manual or auto
- bumper
- Driveshaft question
- will 90 4runner doors fit 93 std cab truck?
- 90' Toyota 4wd V6 - troublespots?
- 22re Parts For Sale!!!!
- 35's and camoclad MAX-4
- High idle..... still need help after search.....
- 2001 taco center console scored off ebay!
- suspension/gearing advice (found some parts)
- camburg stainless battery tray
- Whats the best way to get out oil/water from the block/pan ?
- 22re timing issues
- Wiring Harness
- spring over conversion for 2wd
- Truck won't start now??
- Good Canada located part source?
- Unusally bad gas mileage?
- Idle adjustment on AFM
- Sparco Seats in a 88 4runner
- What could do this damage?
- Shock help
- 86 Front Diff Q. Help!!
- LCE Pro Flow Exhaust.
- oil pan removal
- 89 runner top
- How much damage is OK for ring gear install?
- Front Bumper/ Radiator-Support help
- Dana 60 install,, wheels?
- Is my truck a 1-ton?
- Better gas mileage!?!!
- Running my $runner on HHO(water) update
- 22RE crank pulley
- Engine swap options
- Shop manual
- strawberry milk in tranny!!
- where is knock sensor do i need it
- Turn signals wont work
- Jet Chips Power Programmer
- Interesting.. 22RE fatal symptoms
- new engine now wont start
- 1995 spoiler fit on a 1992?
- Herculiner $25 rebate until 4/30
- My Very Used Runner
- oil light under high rpms
- 87 runner bikini tops
- ome 901 and air bags put to test
- Need help getting cam gear on
- Tortion Bar turn
- Power tailgate lock? '90 SR5 'Runner
- so when did your motor blow any replies
- 89 3.0 no start has spark havent changed anything
- level lift kit 4runner
- What starter? 4.3 with AA bellhousing
- 3.0 Head gasket life span?
- Need help with a decision
- A/C issue. Need advice.
- How many bolts?
- lockers front and rear
- My New Bestop Supertop is On
- Smaller Tire Diameter?
- 1994 toyota 4x4
- 1988 Toyota Pickup
- Is my idler pulley bad?
- What Header to buy?
- 3VZ-E hot starting issues.
- mystery efi fuse blowout
- master cylinder 94 yota HELPP
- failed smog! god california sucks!
- Coils & Torsion Bar Recomendations
- Fan removal
- I need your BEST spark plug recommendation
- Changing water pump??
- Does anyone have a product they use to clean/blacken the plastic exterior trim?
- OME rear springs?
- Senior Project
- Fixing the speedo cable noise
- 4.30's in a 5spd
- Sizing shocks after coil spacer install
- Is one radiator just like another?
- Fan tried to exit through the hood-need a part!
- ProComp Lift question
- 22re high idle and low idle
- 88 yota pickup 4x4 need input on how to get more HP
- I'm starting to dislike this truck...
- Leaf spring question
- Need some suggestions
- Tubing the fenders... How much for <x> size tire?
- 22re motor differences
- Speedometer making noise--22re
- thrown gauntlet
- PS Pump
- factory paint color
- WTF AFM!! the 3.0 doesnt suck it can't breathe!!
- Just Orderd a winch...
- Steering recall and alignment.
- Transmission flush question / concern...
- EGR swap
- Body Mounts: How To Check ??
- 22re battery intake swap
- 22re dual row timing chain
- AFM Question
- Fuel Pump Circuit Opening Relay Testing
- 3.0 header question
- spark plug connector grease !?!
- connecting rod socket
- This darn Toyota.....
- rearend and frontdiff q's
- Update on my HHO project
- 86 SR5 windshield replacement?
- Changing rear ends
- Good day for my yota
- 22rte intake on 22re
- track bar bushing
- Suspension/steering component Questions
- Valve knock? I hope!!
- 1990 4runner Electrical Problems
- where to buy?/who to trust?
- 87 inclinometer install/removal
- another bumper thread
- Engine Swaps????
- Truck stalled, started after some funny stuff
- CV shaft trouble help me!
- Next money pit
- Best oil?
- 89 Pickup Wont start
- Fuel Leak Need Help!!
- Ignition timing advance/retard(ed?)question
- help identify parts 94 4runner 3.0
- 87 22RTE pickup dying
- fiberglass or metal replacement bed sides
- mech temperature gauge install
- Rear Shock problem !!help!!
- IFS Lower Control Arm Bushing SLEEVE
- Someone Stole My Catalytic Converter
- Suspension Question
- trick hilux pickup
- 33/9.50/15's Do they even exist????
- Question on 63" Chevy Spring Swap
- Should be a simple question, 1992 Toy Pickup receiver same as 1992 4runner?
- pickup seats
- Half moon gaskets
- Water leak!?
- do the T-case and Transmission share oil?
- Painting Box
- made a little mistake need help
- Rough idle on 91 3.0
- 3.slow valve chatter --- bad
- Rear End??
- my 91 4wd PU 22re...
- temp sender
- 87 4runner weird starting problems
- truck won't start
- 22RE I.A.C. Valve?? Where is it, and what's it look like??
- 22re high mileage oil
- 91 4 runner sunroof, inny or outy? lol
- marlin crawler bumper ??'s
- 22re dead hole?
- Please Help with electrical 10A engine fuse blowing in kick panel '90 3vze Runner
- Photo Needed - 1st Gen Steering Stabilizer
- NWOR header 22re
- Question About Low Fuel Light on SR5 Cluster
- inner rear view mirror removal?
- Piston size question on 22rtec
- Gear advice. 86 4runner with 32's
- Retro Fitting a 3rd Brake Light onto my 91.
- Project just about finished...
- '99 Locking Diffs Swap
- Weird clunking noise from front end
- Reed valve problems pics
- ISR on high miler
- 4wd Binding
- Wiring Harness - Engine harness differences from manual to auto transmissions???
- cold mixture heater or air/fuel mixture heater question
- need help finding parts?
- shackle lift numbers
- 4Runner dead in the water
- Bolt pattern? and yes suspension! I know!, search , but cant find exact info!
- Anyone need rear bumper mounts?
- IT RUNS!!!!!!!!!!!!! Finally!
- timing problem
- 1-2'' Rear Shackles ('88 4Runner)
- Yakima Racks
- 2" lift with 31 inch tires?
- My New Tool Box!
- What did this guy do?!?!
- Ash tray noise off road
- Rattle sound coming from front suspension when hubs unlocked
- 84-88 bumper on 89-95?
- Horrible Valve adjustment????
- In The Middle Of Engine Removal.. Question
- surf pick up.
- warn m6000
- Rebuilt my auto trans...Holy schnykies!
- Should I install manual hubs?
- Intermittent starting problem after tune-up - related or coincidence?
- Quick Question (Doors)
- Looking at getting some AllPro springs to get rid of the rear sag...
- I know its been Covered... but Removing a 3VZE without taking the Transmission out???
- The linked FSM's
- Valve covers on 94 Runner
- camper top or not??
- My New Custom Tire Carrier
- Another " I got a noise" thread
- 22RE Throttle linkage parts
- looking into lower gears
- Installed new engine, now no clutch pressure & slight vibration
- coolant loss?
- Question on Cali 22RE O2 sensor
