- 88 yota help needed please
- Alignment problems with bracket lift 2nd gen 4Runner
- transmission swap 5sp to auto
- Running like a chevy
- Strange sound from Clutch
- 88 v6 not transfering enough torq to trough front diff, think diff is slipping??
- CV Axles and Joints IRS
- Ac compressor not being called on
- Headliner removal and install?
- virginia emissions
- Complete Upgraded Headlight Wiring Harness?
- Possible new dd/ project
- Rear Tranny Output shaft play
- Since we're on the subject of nerf bars...
- Fuel pump bracket part number?
- Upgrading some stuff on the yota.
- Will 89-94 Truck nerf bars fit 87 4Runner?
- power to manual mirrors
- Timing Chain and Valve Noise
- castle nut slipping on pitman arm - relay rod
- Starter throw problems
- A Mouse/Mice Decided to Sqat in my Intake Valley
- Back in 4WD My new 88 extracab
- Tach not showing correct idle speed
- A/C electrical "fun"
- 22R no power
- 89 Toyota PU leaf springs
- 22re idle speed in gear
- uggghhhh...front diff?...
- Just sold my 3.0 and bought a 3.4
- Oil leak not at valve cover, worse
- Hid's in a 1995 t4r?
- what is this noise in my engine comp?
- 22re valve cover gasket
- Sr5 tach wire
- What Tachometers are not compatible?
- oh boy... the 3.0.. 3.0 4runner vs 3.4 4runner on one tons, drag race at the track!!!
- Stabilizer Bar replacement question
- Tacoma rear end
- 20R head onto 22R, or bore out 20R?
- 92 reg cab sas question
- 22re Head Question
- IFS rebuild
- Total Chaos Idler question
- 1992 4runner shifts randomly help
- At vs Manual ECU
- Fuel pressure regulator
- what is this?
- where is your CB radio mounted?
- 2400 miles done. Thank goodness for gears and the Zuk mod.
- Smell
- 92 4runner rear axle to 1997 4runner?
- issues to look for in potential 4runner purchase- not running well
- 22re mileage theories
- Shocks for 1989 toyota pickup?
- '91 3vze no torque
- Power Steering Fluid in Intake - :eeek:
- What causes pitting like this?
- Advantages/Disadvantages to setting idle speed and ignition timing differently
- RHD manual transmission swap
- Relay box-gate window
- HELP: elocker issues
- Removal of Pin in leaf spring?
- new hole in the trans?
- Where to start with this bench seat?
- 1988 4runner front windows not working
- 88 Map Light install question ??
- Need some advise
- Strange clutch problem PLEASE HELP!!!
- 22re High Idle
- 22RE and 22RE-t Intake/turbo Swap
- finallly did it
- What axles do I have?
- Which Weber to buy......
- Is engnbldr.com worth it?
- Gas Milage Problem? Transmission Shift Problem?
- What do you guys think of this complete head? (22RE)
- can i see some pics of some 4runners with bushwacker cut out flares?
- steering wheel front end shake
- For those of you with flowmaster 50!
- Coolant in my oil, any ideas?
- Oil leak from air compressor?
- hauling more weight
- 1989 22RE Help getting ready for the season
- metra power antenna problem
- Traded my way through the world
- blue puff of smoke once in a while
- need help with a noise
- Lo-Buck Magnaflux/Zyglo
- Rheostat / Dimmer frustrations hey 4Crawler or XXX
- 1990 windshield compatibility question.
- cylinder pressure issues
- sputtering on acceleration
- Bad headgasket..good compression??.. stumped!
- 6-7 inch rear lift on ext cab pickup need longer driveshaft?
- My sister hit a bear with my Yota, then a electical pole then a 12x12 fence post
- help!! i can't get my driver side rear brake drum off!
- 1986 pickup brake problem
- bushwacker fender flares or 3vze doug thorley headers?
- 22R seems to be rich ?? Advice appreciated
- Rear Bumper Bracket - Rusty Bolts
- SR5 Gauge Cluster Improvised !!! Be truthful
- 22RE - Auto- Tune Up Q's
- what does your 22re rev at?
- Clutch fork rubbing?
- coolant leak points on backside of 3vze
- One power lock not working
- 22re will barley idle all of a sudden
- Charging issue NEED HELP
- New Toyota Project!
- 33s, went from 4.10 to 4.88, mpg stayed the same. Aaagh!
- coolant leak behind thermostat?
- Loud Driver's Side Power Window
- 3vze...... Really could use some help
- W56 tranny fits which transfer cases? And which clutch?
- To rebuild my self or buy a rebuilt one or buy a new holley....that is the question
- Help deciding
- Aftermarket Gauge Wiring Question ??
- 22re. any of you have this happen?
- downey springs fitment question
- 22re and seafoam!!!!
- 3vze... need I say more?
- '90 3VZE 4Runner Distributor Question
- Headlight Switch Issues
- Exhaust Manifold??
- What are these?
- stumped wiring problem
- What is it with the cigarette lighter outlets?
- Help! 22re 5th Speed won't work
- Rhythmic hum on 95 4x4 pickup
- T-Case / Tranny Noise???
- 3.0 to 22RE swap
- truck cranks but wont start!
- machined down flywheel clutch plate
- 22re timing chain rattle
- gonna part out 89 v6 4runner, figuring what can fit an 87 22re 4runner
- Installing OME torsion bars - 88 4Runner
- Compression problem
- just painted my 86
- Universal Joint Plastic goop?
- 3.0 wont run @ *10 BTDC
- 1994 toyota hilux overheating
- Supercharger Maintenance
- 86 pickup starts but will not idle
- Air Conditioner Not Cold When Not Moving
- Anyone Running Airbags?
- New pictures for your enjoyment...
- a340h transfer case service manual
- Brake System Issues
- Engine WHINE.....
- 3VZ-E Timing Belt Replacement check
- heater hose?
- V6 Caliper upgrade on IFS
- 22re Running Lean---No fuel in return line???
- high mileage suspension. How to keep the height but lose the stiffness?
- will a 96 driveline carrier bearing fit my 91?
- failed smog, i need help figuring out why
- Freeze plug locations on the 3.0 slow.......
- Open or Closed Loop
- Only firing 3 cylinders?????
- Opinions on cross-country traveling with camper
- Opinion: Broken Valve/Piston Replacement
- Install Factory AC
- breathers in the engine bay
- Cold weather prep for the 89 4runner?
- I need a quick answer! 5spd and auto speedometer cable
- another...3.0 Blown Headgasket! Whats worst case?
- 87 runner 11 years not fired...
- Bottoming out Bilstein 5100?
- CC for truck with duals/turbo tranny
- 91 4runner, can't control steering above 35mph
- Replacing tranny
- When you reen Ireen
- Acceptable wheel bearing heat
- 1987 4Runner Rebuild/Resto
- Bad exhaust leak from manifold??!!
- Need answers. Changed my Rod bearings, but started knocking again 2 days later!?
- Driveline Vibration
- Fuel Issue
- '87 Runner Where is the circuit opening relay
- Whats going on with my 22RE 2x4 1993 truck, Video of truck running and photos of plug
- a340h loss of torque!! All out of ideas??
- Sun visor '87 Runner
- 1990 4Runner Cruise/Horn Wiring.
- 86 pickup bench seat swap question
- Towing Capacity
- 1995 T4R Heating and A/c Proplem
- Putting on fender flares...
- 22re Injectors and more seattle area
- SR5 gauge swap into 22RE AUTO feesable?
- differential leaking..? (hilux '89)
- 1990 4runner compatible with 1995?
- what clutch
- 3VZE Idle Issues
- Degreasing tips please?
- 3VZE Head Gasket fix ??
- Chevy Leaf springs front and rear?
- 4wd woes
- HELP: driveshaft/pinion flange
- 86 DLX Fuel Gauge Issue
- How to remove seized torsion bar adjusters
- Did I burn up my head? (highway speed w/Advance disabled)
- 1986 22R Bad Timing and Bad MPG
- Failed smog with a vengence, please help
- Cutting up the Hard top
- 1991 Toyota Truck Won't Start
- how much does it take to hydro lock
- front lockers or front axle popping and grinding on hard left...
- Heater controls
- LOUD 22r noise (video)
- Proud Papa!
- Complete front spindle/cv axle swap?
- Fuel sender repair in AU
- 1987 Rear Brake Line Blues
- 86 4runner tired, poor acceleration! Help!
- 2nd Gen Power Steering Belt Jumps Off After New Pulley Install
- 1990 4runner A/c works but bogs engine down
- Adjusting the timing chain on my 87 4runner
- no power after seafoam :(
- New Rod Bearings Full of Holes
- hard shifting... ideas?
- Got some miles on the 5.29's... so far so good (FUN!!)
- woo check engine light post!
- '90 4Runner Winter Project Advice Needed
- 22R Carb Help
- just got a zuk mod
- 94 Pickup 22RE Idle/Start Problem
- '92 manual trans fill plug
- 1991 pickup SR5-4x4 coolant leak front of engine
- transmission removal
- sputtering/engine light stays on
- Headlight Adjustment for NC Safety Insp. on 1992 Pickup w/ Frontend Damage
- 88 pickup injectors
- 3vze mystery miss
- 95 4runner misfire, horrific mpg
- 1987 turbo head
- Vaccum Hose Locations
- 87 4Runner, Driver seat is TOAST... help...
- Installed new Fuel Pressure Regulator & Pulsation Dampener
- SR5 arm rests interchangeable/removable?
- Need FSM Temp gauge resistances '88-89 V6
- 100k mile maintenance
- fuel filter replacement... relieving fuel
- Return fuel lines??
- Gear lube leak
- Temp Sensor Question!!!!
- Any difference between tilt lock cyl. & non tilt lock cyl.?
- Help !! Charge and Brake light-- Did research still lit
- Air conditioning fill problems
- 92 Slow blower motor!
