Air conditioning fill problems
Old Aug 29, 2011 | 03:26 PM
Jayson_22re's Avatar
Hey, I've recently put a system on my 92 pickup from an old 90 pickup and everything went on fine and hooked up with no problems. BUT when I went to put my gauges on the compressor, they wouldn't fit!! The diameter is right because I had to buy these quick connect adapters that screwed onto the valves for each section. But with the quick connect adapters, the one on the right in the picture is too tall and doesn't let me get the hoses quick connect adapter on right to lock it in place.
What can I do??
I attached a picture for reference.
Old Aug 29, 2011 | 03:41 PM
Sensei's Avatar
Dude, I'm sorry but your drawing is not working. Can you take some pics and post them ? Was the system you installed originally an R-12. Should have been since it came from a 1990. If so, then you installed R-134 adapters onto the R-12 fittings on the compressor. Which gauge line are you having trouble connecting; red ( high pressure) or blue (low pressure) ?
c0ugar69's Avatar
I had the same issue so I bought a 90 degree adapter that screws on the original so it points forward. so far its working out. I got the adapter at autozone
Old Aug 29, 2011 | 04:50 PM
dntsdad's Avatar
That is by the far the worse drawing ever.
Old Aug 30, 2011 | 12:52 AM
from the picture you can see its the blue line I'm having problems with. The 1990 pickup had the system updated to r134a fittings on the compressor. The quick connect adapter hits the bottom section of the EFI and won't fit onto the compressor threads.
Thanks a lot, is that what you bought?
http://www.autozone.com/autozone/acc...ntifier=326484
If so, that's exactly what I am looking for.
Old Aug 30, 2011 | 04:17 AM
blake.nemitz's Avatar
im sorry for your troubles but that picture HA HA HA
Old Aug 30, 2011 | 05:29 AM
c0ugar69's Avatar
Yea i think thats the one, then i put the adapter on that part ane i can get my hose on it.
Old Aug 30, 2011 | 06:00 AM
awesome man, I'll stop by there today and see when they can get it to me. Thank a lot if this works
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
