PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 [242] 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Front diff not locking
  2. Feeler on value of 3.0 engine
  3. Low mileage '95 4Runner!
  4. engine ticks for unknown reasons
  5. i need help with 22re(turbo) tick!! asap
  6. Herculining Rocker Panels (pictures)
  7. Tranny Crossmember
  8. 3.0 Idle problems solved.
  9. 3.0 knocking at idle
  10. Is the ISR mod a good or bad idea
  11. Any body have the repair manual
  12. Loss of power then it comes back to life
  13. Overdrive in and out/on and off (random)
  14. Shutter at 40mph
  15. Center Console controls etc.
  16. Fsm Link ?
  17. dreaded speedometer squeal...
  18. Recommend shocks
  19. Heater isn't working very good.
  20. 5.29's and 37's questions
  21. cold start injector
  22. do/don't replace engine cooling fan
  23. Is there a way to put a locking glove box latch in 1st Gen 4runners?
  24. any LT 2nd gen 4runners?
  25. cruiser coil/bj spacer
  26. First generation 4runner console mod
  27. What would you do about my exhaust leak?
  28. Rateling noise in my 89 v6
  29. Anybody have any experience with these cylinder heads?
  30. Brrrr....cold ticking in my 93
  31. tube rear bumper
  32. 4Runner transmission weight??
  33. Truck wont start tried a few things
  34. 3.4 swap completed- dyno #s
  35. Center bore and tread type
  36. cup holder mod/ 4runner
  37. 22RE water pump leaking after top end refresh
  38. 12mpg?
  39. 88 22re Overheats with heater/defroster on
  40. Extended Cab room ?
  41. 94 runner rear sag, suggestions?
  42. engine codes
  43. how high do you rev your 22re?
  44. Bumpers...
  45. Chirp Noise
  46. 4runner tailgate problem
  47. why does my 22re ping?
  48. CB mounted (1987 single cab) *pics*
  49. 90 22RE Lost fuses
  50. cruiser springs?
  51. 3.4 Running rough and taking it in tomorrow
  52. CPU crossover
  53. gauge cluster question
  54. Front End Problems
  55. HG Replacement Camshaft Pin
  56. Ceramic coating or wrap headers?
  57. Cams -- Is this a problem
  58. Pickup/4Runner guys....need a measuerment
  59. Axle Housing issues on swap!
  60. Ghost truck
  61. What other seats work as a replacement?
  62. Saving Gass Question?
  63. 92 Tacoma 3.0
  64. fan bracket help
  65. Rear gate/window/wiper not working
  66. Rear Leaf Blocks
  67. My Weekend Mods
  68. Gasoline in Oil
  69. Sankei industry aka three 5
  70. Alternative Fuel in 3VZE = BAD
  71. Zuk Coil
  72. new turbo is here!
  73. What should I know before going from old Jeeps to an 80's 4runner?
  74. What is the easy way to replace my timing chain?
  75. Quick 3VZE Timing Belt Question
  76. Extending your brake lines....When?
  77. Truck overheated, now won't start
  78. 3.0 Headbolt Washer Question
  79. Not Moving!
  80. Shifter boot
  81. New O2 sensor, now not starting
  82. elctric fan mod for sale
  83. Mounting lights on the bumper
  84. Anyone change your shifter??
  85. Rear passenger side window regulator
  86. starter advice and interpretation
  87. Auto tranny rattling!!
  88. Lift problem
  89. Got my map lights working!
  90. Driveshaft Issues
  91. power steering problem
  92. No Electrical Power Help!!!!
  93. Write-up\Website on pulling motor
  94. 22re valve stem seal change....easy job?
  95. Aaaargh! Stripped camshaft bearing bolts
  96. 3.4 swap 99% compl- pics
  97. more flex
  98. Water pump, Aftermarket or Original?
  99. What should i do???
  100. Steelies to soothe the soul (PICS!)
  101. A little forklift flexin
  102. Do manual Hubs increase MPG?
  103. Frame Swap Questions
  104. Evil noise from front end
  105. 33x10.5s vs 12.5s OFF CAMBER
  106. bumper bracket bolt removal
  107. Auto 4runner shifting weird when cold
  108. ARB/TJM mounting after SAS
  109. 33's on my 1989 4runner
  110. Which cylinder head?
  111. Seat cover opinions for my '89
  112. I want to herculine the rest of the interior, but???
  113. 3.0 blowing smoke
  114. Spraying oil
  115. Alternator Brushes
  116. Wiring diagrams for rear wiper switch.
  117. Shock Removal on a Spring Replacement?
  118. Gah! Problem re-installing rear Axle Shafts
  119. Idler arm bushing- quick one...
  120. Coolant leaking from 88 V6
  121. 2" whell spacers?
  122. 86 4runner center consol/ grey.
  123. Snapped exhaust Header Bolts
  124. CB in your 80's yota?
  125. Truck dies when I stop
  126. Roll Bar and Incilnometer
  127. MegaSquirt
  128. OME901 Springs or AllPro Offroads?
  129. Stretch's 3rd Gen OEM Lift
  130. want to upgrade suspension on '95 4runner...advice?
  131. 3VZE Head gasket problem
  132. 22r reliability, specifically carb questions
  133. Painting hood - What color?
  134. 22RE A/C Comepresser on 3.0
  135. Muffler/Exhuast Set Up
  136. 94 22re, Hard starting.
  137. another gearing question.
  138. Passed CA Smog but still have a small problem
  139. LCE Throttle Body? Worth It?
  140. 22R/22RE Blocks Interchangable??
  141. Wich low profile bump stops?
  142. Clutch Start Cancel Switch REQUIRED to start now??
  143. 22re engine trouble.
  144. How to convert to SR5 Dash with pictures!
  145. Chattering Sound from engine bay
  146. Hey 3.4 swappers
  147. Leather seats??
  148. Confused... Suspension related
  149. Is my Mechanic lying to me??? PICS
  150. Engine wizards, please look at my engine. Pics!!
  151. Trouble wiring up my map lights
  152. 3vze won't start when hot, now won't start at all w/o starter fluid?
  153. transmission adjustments
  154. Rear Wheel Hub/Drum Paint Corroded
  155. rear springs
  156. Front end steering kit?
  157. headlight improvement
  158. 3.4 swap compl- need tune 'files'
  159. Oil Leak Getting Worse
  160. question about new shackles + leaf spring bushings
  161. tell me the truth about valve clearance
  162. Why won't this 22re cylinder head come off?
  163. Soft Top Help
  164. jumpy idle
  165. Help, 91' 22re 4X4 - no power
  166. 92 4runner K&N air filter problem
  167. safari rack and gas mileage
  168. 1st gen OME lift?
  169. Miss or hesitation?
  170. 90 V6 Idle Oscilation?
  171. Speedo/Tach cluster ??
  172. odometer
  173. Changed oil filter to ford V8 version
  174. starter issue...do I have to remove the headers?
  175. Tires and Exhaust?
  176. Thinking of herculining the bed of my 88 4runner and need advice?
  177. noisy hub?
  178. Possible silly question about PVC valve
  179. EGR malfunction code 71?
  180. My new Super Swampers TSL Radials are on!!! *56K warning Pic heavy*
  181. short side lc coils on 2 door 4runner 90
  182. Driving On Hwy In 4Hi
  183. Head Job
  184. W56 Capacity
  185. Total power loss on my 88 Toy
  186. Picture of underside of 4runner
  187. v6 question!
  188. 22RTE head decisions
  189. Water temp gauge 1988 PU
  190. 3VZE engine rebuild, sort of
  191. tire rating
  192. 3.slow, not so slow
  193. Need help with 86 4Runner EFI
  194. 95 4runner for sale!!! Very clean and XTRAS
  195. Remove BJ spacers or back off torsion bars?
  196. 3.70 gears for 89 8 inch 4WD axle?
  197. shifter boot
  198. HELP exhaust muffler and pipe problem
  199. Leaking power steering gear box
  200. Tranny keeps popping out of 1st gear
  201. Chattering In Driver Side Hub
  202. Removing headlamps
  203. Squeeky Clutch
  204. Rust forming on manual hubs and lug nuts
  205. Strange coolant/ heater problem
  206. 22RE coolant drain problem
  207. Auto Tranny Problems
  208. Cigarette output un back Bumper
  209. 33x10.50 Will they rub?
  210. Timing Chain 22re
  211. Bad Automatic transmission.
  212. Do u have a repair manual for my 88 Pick up EFI
  213. Clutch recommendations for towing with a 3.0L?
  214. Ok, I'm going the the Orient engine, but have a question.
  215. intake removal
  216. 91 Toyota 22re will not start
  217. locker and hubs question
  218. Stronger clutch or newer clutch?
  219. 2nd gen winch behind valance
  220. Tire Size for 88, will it fit?
  221. 22RE emissions equipment removal
  222. Help two codes!!!
  223. "Kuh-chunk" noise in driveline
  224. 3.0 v6 89 4rnr - oil filter location?
  225. 4.88 Toyota 8" axels
  226. Window and Side Panel removal
  227. Which clutch would be best...
  228. 22RE Timing Float
  229. Accelerate problem
  230. Axle Housing Rotten, diff. fluid everywhere!!
  231. Idle and over heating problem
  232. REQ: A/C conversion parts list req for 86 w/ 22RE
  233. 6" Lift and Rear Drive Shaft
  234. broken e-brake cable
  235. Trade gears
  236. broken "deluxe" springs
  237. 3vz-E starter showering sparks
  238. 95 4runner cigarette lighter removal?
  239. Truck or 4runner?
  240. Cheap Starter
  241. More power from my 22RE?
  242. 32's and oem alloys
  243. shocks = bumpstops??
  244. results on 1994 4runner 3.4l swap (completed)
  245. 86' starting problems
  246. No Acceleration past 15 MPH
  247. For those that have headers......
  248. Brake light comes on...
  249. Locker Choice
  250. What year pickup is the same as 87
