- brake work ??
- HELP: Charging Issue/ Parts Compatability
- 120 on the clock
- Tranny questions
- power steering vacuum hoses
- 94 4Runner K&N Filter
- Doug Thorley Jardine Cat-Back Exhaust Systems
- air cleaner and smog help
- 87 22r no start help
- Rattling at 2500-3000 RPM
- Intermittent problem
- Lookin for a truck. What to look for?
- Insulation ideas for steering column hole in firewall?
- Battery and Brake Light on
- newbie to Toyota's, 95 4Runner SR5
- 88 4runner, 3.0, hard to start when cold
- 88 4runner in Maryland (need opinions)
- 22RE Turbo conversion -EFI Tech
- 3.0 acts like burnt valve only when hot
- If you have a 2wd post here!
- 22RE, what can it revv to?
- Do you have 5:29s on 35s w/3.0 5speed
- reading codes
- I blew the HG, again...
- Got speedo wobble?? Check this first!
- moisture under mat
- Help please!!
- I Need AFM Cleaning Instructions
- Is '95 a good year for a 4-Runner?
- 4Runner - Can't get out of 4 wheel drive!!
- NO 4x4?
- Rhino lining my floor???
- 2nd gen 4runner lift.
- $500 '87 4runner with....a 3.0L?
- need to fix my horn ( please, no jokes)
- tune up write ups?
- 94 3.0 intake valves stuck open
- 90 4runner wont start
- tread pitch?
- Vacuum Leak?
- floorboard coating
- How to keep shackle from moving?
- Who said IFS flex sucks?
- 86 runner head gasket replacement. Easiest way?
- My First Toyota
- No freeway power in fifth
- Barely idles then gets power
- My new (old) truck
- Differences Between Frames? 4runner and FJ60
- Speeding Ticket in MA, entrapment?
- Why does only the front get a double cardan joint?
- 3.4 Swap...Maybe..Looking for tips/stories...then possible teardown
- Shifter seat bushing?
- Sound near vent...
- I'm New to Toyotas
- 38x14.5r15
- replacement engine/bottom end? v6 4runner
- 5.29s and 31s for a DD?
- '88 22RE pickup, cam & header question.
- 4.0 Low gear set?
- 94 4runner tailgate lock?
- Starter
- how hard is it to bend a rear axle?
- Need some tires
- wheels seized!!!
- help?
- Is there a 4.56 e-locker out there?
- questiosn about dropping in my motor
- Electric Fan controls
- Finally got around to painting my wheels
- Modding Questions
- Problem with long cranking/starting now that it's cold outside...any help?
- Best method for cleaning a heater valve
- 22re stalling - clicking sound from ECU area.
- possible blown head gasket
- Pilot bearing removed with candle wax
- will adjusting VAMF fix bad idle?
- Name that Part!!! (22re w/picts)
- High Clearance Front Fenders?
- I really want some fiberglass bedsides
- what are the sighns of a bad torque converter?
- Exhaust manifold????
- Clunk from front in 4wd under load
- Aaaahhhh I Need Help!!!!
- bull bar
- No heat after heater core replacement
- 95 Toyota Engine knock sensor wiring
- starter question
- Hit a Deer in my 4Runner
- 1988 4x4 truck extra cab back seats?
- Need Help..3.0
- Mechanic Needed In La, Blown Motor
- Removed my cracked clutch bracket, and found the dash support was cracked too...
- air intake chamber gasket
- Thermostats easy to replace with no fan or radiator in the way!!!
- Cant find ISR mod parts...
- need more help guys
- southwest washington trails?
- timing belt
- Ordering my aussies.
- Fuel Injector Rebuild?
- question on a 4runner for sale locally
- steering wheel cover question
- Replace all springs?
- Braking Problems?
- 1990 toyota
- 91 pickup
- Diesel implants for 1989 4wd?
- Front Seat Swap in '91 4Runner Completed
- Unique surging 22re problems, please help
- Front upper control arm bushings
- Steering
- Factory sliding rear window latch ?
- cold start injector maybe?
- tonights clutch
- Getting 33's
- New headlight bulbs
- How hard is it to replace fuel injectors??
- Rear Heat Removal ????
- Weird overheating problem
- Factory tow hitch pictures
- Driveshaft/rear diff problems?
- Solid Axle progress..
- Transmission / Driveline Jerk?
- Dumb question.
- heater core removal 89 22re std cab pickup 4x4
- yota lookout, so you do this also?
- Water in oil but not head gasket
- Found some headers today
- 1st gen and 2 gen frame swap
- Round headlights or 92-95 grille/headlights?
- Brake lights no worky....
- Lookin for some add-ons
- body lift questions...
- New truck - What's wrong with it!!
- 3VZE with no fuel at start-up HELP
- rear axle bearing
- Turbo Charging a 22R
- Quieting the Tailgate Hinges
- Orginal ads, tv, specs and more
- 2gen 4runner rear window stuck down
- Valve Adjustment cost
- newbie question about clutches
- radio wiring
- 4wd not working
- 1989 4Runner Pro Comp 31x10.50s, what air pressure would you use?
- Rear end sagging?
- Building credit w/ tires and wheels
- reg. or syn. oil?
- does toyota make keys or order??
- Door lock control relay
- Need Help Fast 3.0 Waiting For Response!!
- Solid Axle help.. mysterious notches (to me)
- Fan shroud, oil cap and fun...
- Its Christmas!
- heater core hoses
- One of my pastic connectors came off
- 89 toyota alt
- 22RE vs 22RTE...differences
- Just Ordered
- 1st obstacle SAS disc rotor
- regearing
- Locker problem help!
- 4wd power steering vs. 2wd
- Check Engine Light = Code 52
- How to pull your 22RE
- Weber carb?
- quick question...Single or Dual steering stabilizer
- Pro comp
- Grease gun points
- 1988 W56 5spd tranny 2wd.. can i put my x-case on it?
- downey headers and exhaust?
- Discontinued Toyota Factory Decals, Stripe Kits & Tailgate Logos!
- Seriously???
- 89 4Runner 22re Auto "Name That Connector"
- Why Only one shock in the rear?
- Lost an exhaust bolt
- Is that a Solid Axle or are you just happy to see me...
- new key set?
- Wierd door lock proplem?
- Troubleshooting '92 4rnr/4wd operation....
- Fuel Filter repacement write up for 22re/Rte?
- Front end slamming
- need to sale my 89 4runner
- Idle jumps up to about 1200 rpm when idle after warmed up?
- Trouble Replacing Front Brake Pads!!!
- CEL Code Help
- Computer problems or cold start injector?
- i need this bad... please help
- What's this connector for?
- OILS, 10W40 or 10W30?
- Cat Victim
- HG replaced now has running issues
- cat converter question
- Time for an upgrade
- clutch went out lastnight???
- Torsion Rod Bolt Idea
- 1.25" Coil spacers install - 95 4Runner
- crossover pipe exhaust leak.
- Cruise control help?
- constant ticking.
- HELP! overheated, wandering idle, no heat!
- 93 4Runner Trans Cooling Lines
- some newer pics :)
- Uh-Oh...Here Goes (91 3vze overhaul)
- How to change headlight bulbs on my 94?
- o2 sensor nut size
- CV install and c-clip problems
- 3.0 Wireing/Vaccume lines plug back
- flywheel bolts
- Fyi
- Matt16, Aussie ???
- Replacing Ignition Tumblers in 1993 Pickup
- Gear chart?
- Fender flares post fender cutting?
- Should I get aftermarket shocks?
- Tyre size 31" To 33" Fuel Econ
- front end noise HELP!!!!!!!!
- misfiring?
- Re-flashing ecu
- Any Toyota techs out there????
- Coolant on floorboard inside truck
- battery
- 5 speed swap
- clutch
- Rebuilding a 3.0
- Brand freaking new
- awesome 2nd gen rear bumper
- Annoying clunk type noise on take off?
- used parts buying?
- Crankshaft bolt specs.
- ebay h4 conversion kit installed
- size of crossmember bolts
- ivan fenders
- toyota front axle
- is a 5 speed from a 22 re same as v6?
- New 86' Pickup
- Interchange Fuel Tanks
- Power window motors?
- 22RE TPS issue. Please Help!!!
- Idling Problem
- coolant leak sources
- egr valve cleaning
- Knock Senser Connecter
- What do you think of my nice rack
- Rear brakes grabbing bad
- Anyone had any experience with Motor Time?
- need help ID'ing some parts
- 22re Short block pricing differences from Toyota
