starter question
Old Nov 23, 2008 | 04:08 PM
Nothingbutyoda93's Avatar
Question starter question
im replaceing my cluch do i have to remove the starter. and if so whats some advise on taking it off
Old Nov 23, 2008 | 04:43 PM
abecedarian's Avatar
yes, you'll have to remove the starter in order to get the transmission separated from the engine.
disconnect the battery, remove the access plate inside the passenger's side wheel well, use 14mm socket w/ extension and swivel if necessary. if you don't need to get the starter out of the engine bay, don't worry about the wires except to make sure you don't damage the plugs, etc.
Old Nov 23, 2008 | 08:35 PM
Jay351's Avatar
I didn't have a wobble extension, but I had about 5 6" extensions. The slack that resulted in all those extensions attached provided just enough wobble to get the socket onto the bolt.
Remove the skid plate and go in from the front for that one bolt, its a pita.
The other nut (its on a stud) is a little easier. I found a smallish extension provided enough room to slowley loosen and remove the nut (the nut and stud came off when I did it...).
I would consider throwing some new starter contacts in at this time, that starter can be a pain to remove
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
