PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 [215] 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Wheel Stud Dimensions
  2. "Tonka" decals
  3. know what size this bolt is?
  4. Need Some Advice
  5. help please. gauge/ eletrical question
  6. KYB's any good?
  7. EFI Circuit
  8. Just got 4Runner #4
  9. sr5 cluster issues
  10. looking for a part number or a better way
  11. Help me Diagnose my 86 22RE Oil Loss Problem
  12. driveline - 88 4x4 extra cab seems too long
  13. Ball Joints
  14. do i have to crank the t bars to fit 33s?
  15. what is a bimetallic vacuum valve??
  16. Thinking about selling my 4runner
  17. fuel? electrical? problem need some help
  18. Fuel Pulsation Dampner-warning and fix
  19. Good engine parts sources
  20. Here is the Red Rat...
  21. 22re rant new look!!!!
  22. Soft top storage care tips
  23. shaving bump stops
  24. Battery size question
  25. 87 toyota pickup carb problems,dies out.
  26. 1st Gen 4Runner Exhaust Install (with pics and vid)
  27. Rhino liner nightmare
  28. windshield problem
  29. coils
  30. Toyota Parts Dealer Nightmare
  31. Building a bumper update
  32. Some new Pics of my Truck
  33. check to make sure this is my seafoam line?
  34. How long does a fuel pump usually last? (EFI)
  35. TPS sensor (CEL)
  36. tuff country lift kit?
  37. 3vz or 3vze
  38. IFS steering box mounting
  39. rear HI- clearance ?
  40. 93 22re to 22ret conversion
  41. spacers coils and ????
  42. Sidelights Pllleeease!
  43. How to smog?
  44. Havin some issues with my green beast...just before the snow starts too!
  45. My $60.00 Ehxaust System!!!!!!!!!!!!!!
  46. has anyone been able to fit a subwoofer in a regular cab
  47. has anyone been able to fit a subwoffer in a regular cab
  48. Brake Problem
  49. Door Handle
  50. 91 4runner problems
  51. UPS showed up today
  52. 87 + - truck won't keep running.
  53. 22r oil pump leak @ timing cover...
  54. 3rd gen wheels on 2nd gen pics
  55. Emergency/Parking Brake question
  56. What type of tranny fluid for 86 4 Runner auto with 22RE
  57. My check engine is coming on need some help
  58. ?? Need help in wiring in rebuilt motor.
  59. 3vze cams on ebay
  60. **rare** .....well, medium rare
  61. does borla make headers for a 3.0
  62. Homegrown Alignment revisited
  63. Generally What does vavle adjustment cure
  64. Need Part # for Starter
  65. tires,gears and lift
  66. Best place to get a 22re short?
  67. DEAVER 2.5" MINI PACK vs 63" Chev swap
  68. Electrical problems. Long pause before starter turns over?
  69. What sould I do?!?!?!?
  70. Bought the goods
  71. how many differnet gears did yota put in my truck?
  72. Skid plate for 2nd gen with 2" lift...
  73. Changing 22RE Timing chain guide
  74. New 2nd gen Gauges?
  75. Clunking In rear end or rear suspension somewhere
  76. Used 37"
  77. Parking Cable Adjustment Bolt Stuck
  78. NOOB 89 4runner suspension?
  79. Newbie Questions
  80. adjusting steering
  81. Turbo Gauge Cluster
  82. egr questions
  83. 1986 4runner 22r EFI not starting no fuel
  84. 1st gen 4runner louver panel
  85. Rated to Tow
  86. 2nd & 3rd Gen running board compatibility
  87. Need help with power steering problem
  88. Anyone found a timing cover & hg oil leak fix?
  89. 95 runner electrical problem pleez help if you can!
  90. Clutch problems
  91. Shift knob thread pattern
  92. noise: grinding souns on light throttle
  93. My Craigslist find
  94. 2wd n 4wd brake lines
  95. Turned a major mile mark
  96. 4runner stereo
  97. non vent to vent doors?
  98. Legal exhaust decibals in WI
  99. New to me motor....manual to auto...
  100. 86 4x4 turbo -at TURBO WORKING?
  101. Warmup rpms?
  102. vibrations under me?
  103. unsteady idle 3vze auto
  104. What do i do?
  105. Alignment Thrust Plate
  106. Miss
  107. 91 Pickup Cab removal possible?
  108. 2nd genfender flares
  109. body mounted roof racks?
  110. Truck won't start, not getting gas
  111. need exhaust advice
  112. RPM interferance with Sub Woofers
  113. IFS Tie Rods
  114. Gearing for 35's
  115. Converting to manual hubs. Need to replace wheel bearing?
  116. defintive electric fan post.
  117. rear axle questions?
  118. i need a clutch and throw out bearing, but too many choices
  119. Finiky IDLE! advice?
  120. Runner-up
  121. Any one remaking the factory graphics
  122. generic intake tube (88 v6 3.0)---where,how $
  123. rubber gasket thingy on the factory running boards
  124. What are the chances it'll run?
  125. A Few interior repair questions
  126. New member in AK needs reman
  127. what is the thickness of the 2nd gen 4Runner roof sheetmetal?
  128. OME rear leafs. too stiff???
  129. Yet another Blower question. Please help
  130. Garage Fit For a Yota
  131. 94 acura integra intake on my 3.0??
  132. Gettin' my rear back up there
  133. Advice On Wheels And Tires
  134. wining noise
  135. Rear
  136. Yet Another problem with the 2nd gen rear window...
  137. new here hve a afew questions!
  138. LED dash lights for 86 4runner
  139. timming belt water pump kit on ebay
  140. Idle surges when a/c is on?
  141. my clutch is slipping
  142. Body Lift
  143. body lift block diameters?
  144. hella 1900s?
  145. SR5 tach cluster upgrade question...no tach
  146. carfax
  147. Rear lift help
  148. What's this on exhaust manifold?
  149. rear leaf springs??
  150. 37" daily driver gearing
  151. rear leaf springs??
  152. High Idol
  153. 1st Gen Runner Interior Pics-
  154. Leak in the front of the tranny.
  155. Still problems starting
  156. ARB Snorkel on 93 22RE pickup?
  157. I bet im the only one
  158. Teraflex revolver shackles
  159. Lift ideas
  160. 22-re AUTO won't hesitate and surge in PARK
  161. Jumping TE1 and E1 fixed idle?
  162. lightened flywheel = has anyone done this v6, 3.0 1988
  163. Camper Thread!
  164. Starting problems
  165. Question regarding 3.0 engine
  166. PPG glass or OEM equiv??? HELP!!
  167. Another Timing chain Problem
  168. shifting problems
  169. Slave cylinder mounting woes
  170. Fender gap vs. Lift?
  171. manual conversion questions
  172. Exhaust for the 3.slow?
  173. Trade Honda Accord for Toyota truck?
  174. LCE Headers on a manual? Anyone done this yet?
  175. help:wierd find:but need help
  176. Those with a CARB motor..what do yo do for a snorkel?
  177. Timing/ignition module
  178. Gutlesss!!!!
  179. Head Gasket recall 800 #
  180. 4runner hard top rust
  181. 1st Gen 4runner Rear seat
  182. timing belt on my 88 4runner
  183. Oops, I broke a nipple and i cant get it out
  184. L/R Torsion Bar ID
  185. overheating!!!!
  186. 22re knock sensor compatibility?
  187. Will silicone alone work for a tstat gasket?
  188. Forgot head pins during rebuild
  189. ball joint spacer install
  190. Gas gauge not reading properly.
  191. So I think its time for lift
  192. In need of brake help!!!
  193. im new
  194. HELP! How the #$$@% does this go in there?
  195. 4runner vent window
  196. Why? / What?
  197. winter camo, complete....
  198. what is more important, clutch, or
  199. 1ton spring swap
  200. U-bolt flip kit? Do you have to buy the kit?
  201. Manual Swap
  202. What wheels are these?
  203. What SSTs are worth buying?
  204. Truck Shakes when stoping
  205. wared manifold???
  206. Oil Light Just Flashed!!
  207. 22re swap no start
  208. 4runner ifs problem i think please help
  209. Semi stripped t-stat housing
  210. Guys i need quick help on pricing
  211. 88 4x4 v6
  212. Colorado people, where to get rebuilt 22re?
  213. 1987 4Runner 22re oil pressure...
  214. Problems starting
  215. Camo update... for those who care
  216. rear tires wearing weird axel help?
  217. 4WD seems to be binding?
  218. 87 Turbo 4runner question
  219. 3.0L Head gasket recall still being honored?
  220. 37"s on a 1990 4runner
  221. First Yota build up
  222. 3vze issues
  223. If You Go Wheelin Take Some Pics
  224. Federal Couragia Tires
  225. help me find a pic (flat olive and black paint job)
  226. Urgernt - Need a new key!
  227. Can you identify this plug?94 3.0 4x4
  228. IFS set up pics
  229. Front side light removal
  230. engine ticking sound at idle
  231. Locking Hubs...manual or auto??????
  232. Locking Hubs...manual or auto??????
  233. Failed Emissions Inspection. Causes of high NOx?
  234. inexpensive gearing
  235. i've got an itch..
  236. What Wheels are YOU running? pics
  237. 4Runner rear window won't roll down with key
  238. Put a 2nd gen center console into a 1st gen
  239. Body Lift!
  240. 2 PCV's on 22RE?
  241. Parts for 93 4runner
  242. why do fram filters suck
  243. feeling slightly overgeared with 3.0L 4.88 33x10.5
  244. Help finding lockers
  245. 33's on a stock 88 pickup 4wd
  246. A little shake, a little stutter.
  247. Toyota Paint Suppliers
  248. 93 Xtra Cab 4x4 A/T Shifter question?
  249. Valves Adjusted Tighter = More Noise?
  250. what is this?!!
