- Tractor muffler
- Carb question
- Help me with this heater problem...
- 4 cyl vs v6 vs 4wd engine bays/ mounts the same?
- The Winners of the YotaTech Decals Are
- Weird noises
- Failed smog - NOx
- First 5 to email me get free YOTATECH decal.
- Possible 84 1/2 4runner
- a little advice
- YOTATECH decals printed
- 3VZE Rebuild - Gasket set recommendations
- Injector installation - no engine oil on the o-rings?
- Did they ever make husky liners for 1st gen 4runners
- Cat Theft Warning!!!
- 22re aftermarket exhaust manifolds
- 3.0 3vz-e
- 4runner seats and console into 88 p/u
- What clusters are compatible with my truck
- 88-94 bumper
- auxiliary fuse box ?
- 4 speed to 5 speed
- 3.D'0h question - Cold start injector?
- Timing chain guides?
- IFS upgrades
- Service manual for 88 pickup???
- Suggestions...where's this leak in these pics
- Lockrite Question -And I have searched
- Quick question regarding crank/cam/chain alignment 22re
- 99 tacoma rims on a 87 pickup
- '93 22RE problems!! HELP!!
- Turning off aux. light with key
- 90-95 Options & Accessories
- 88 22re idle
- BLKNBLU Bling
- Centramatic Balancers
- Yota87's SAS Questions
- code 25 and 26?
- 3VZE "offbeat rattle"
- electric locker swap
- timing belt
- Will a WARN (89-95) Truck Front Bumper Fit an 84'-89' 4Runner
- Bumpers for front and rear.
- What is needed to twin stick an 88
- fender flares
- Noise Question - Detailed Description
- How limited is the 95 runner when wheelin
- tranny and bellhousing mixmatching
- Crap 22re,reman or rebuild
- 12v Power outlet question
- Parts question: What the heck is this?
- horn help answers
- Gearing advice
- Locking hub question
- Engine Instal ?????
- 2wd to 4wd conversion
- fuel rail problems
- swapping out V6 rear end to 4cyl rear end
- Lifting 92 4runner...need tips!
- wheel spacer questions
- What's cheaper 3.0 rebuild or crate motor??
- tire and rim size
- having trouble getting the new races in
- 3.0L oil pressue
- Gear up for fuel mileage ?
- springs?
- LCE 22RE supercharger??
- Lock Cylinder Question
- Ect Button
- Fuel gauge / sender issues
- gearing for 3.0 v6
- Blew a Rod? What better time for a 4.3
- Power Window Relay
- 2ltd exhaust.
- Newbie 3.0 Questions (rough, low idle)
- YOTATECH decals
- Overheating Damage?
- Coolant leak... freeze plug?
- Scan and post your brochures
- what pistons are theses?
- Bob or Tube my bed?
- need an A/C switch.
- Poor College Boy's 92 Truck
- exhaust mani crack
- fuel tank filler neck
- Rattleing under the runner
- decoding engine block numbers
- Frusterating 4-link
- 2UZ-FE swap into 2nd gen 4runner?
- best spark plugs for The 3VZE
- Brake bias adjusting after lift
- dash light/tail light circuit
- 22r question
- Third fit
- I need a favor from some with a 2nd gen 4runner
- Back window motor compatibility question
- For all those frustrated 3.0 v6 owners
- Bogger? Blaster? Buggy? Batmobile?
- #3 cylinder low compression!!!
- weber/holly carb on a 22r cali smog legal
- Turbo 3vze
- cracnk pulley and powersteering pulley...
- Warm idle miss
- chrome bed caps
- 3vze mods
- LSPV Compensation Questions
- 3.0 clicking ,oil pressure ?
- Broken bolt for lug nut - Rear
- Cigarette Lighter Woes
- Help! 94 Runner engine/tranny separation
- exhaust removal - help needed
- Yet Another Fuel Pump Question
- Help me! Stumbling, no oil pressure..
- for the moderators
- 86-88 runner drag truck?????
- 87 pickup rough idle
- Headgasket success/tips/Victory at last
- power steering pump leaks into exhaust
- 87 Runner intermittent start.
- 87 front into a 93 front??
- 3.0L timing belt replacement help
- hows this sound?
- no power
- CEL code 26
- what gears do you run with 35's
- Heater control valve/87' 4Runner
- 3vze: voltage & amperage across +b and fp
- Bad VAFM?
- brake and battery light...
- Need a shop in so. cal - 93 3.0 Blown HG
- for the more advanced
- Roll Down Back Window for '94 Pickup??
- need a fuel injector
- Dual Viair 480's
- bucket seat in rear of 4runner
- Damn rear window!
- YOTATECH decals went out today.
- 92 4Runner Brake issues...help?
- Need advice...installing a rear heater in my 88 4Runner.
- Replaced thermostat, blew head gasket, how much???
- intake help!!
- front tranny leak..
- BarGOON in Ohio .. 4Runner parts .
- My 2nd 86 Turbo Runner - Pics
- Look at my intake
- Applied my IFS and YOTATECH decals today.
- Where to get Gen1 4runner toy?
- replace mass air flow sensor, won't start
- Shudder at 50mph/HELP
- Bedless: Have you? Can you?
- 1993 toyota pickup NO START 22re
- bumper question
- Drive Shaft ?
- Header install easier with transmission out?
- Gen2 (89+) 4Runner Q
- LSPV bleeding (rusted bleeder valve)
- sliders and bumpers - shipping cost
- turbo rebuild help
- sorry...
- lots o blown bulbs
- New Coils!!
- 95 3.0 in 90 pickup
- Quick question about replacement steering wheel
- Does Knock Sensor code = knock?
- YOTATECH decall Giveaway
- 33s to big
- Pics of 33's, spacers, clearance, etc...
- hood latch
- 92 pickup front bumper
- Rear ABS questions
- rear sag
- gearing question
- power steering woes.....
- ome spring installation issues. urgent need input please!!!
- Stilll not starting!
- Cost to install Energy Suspension Master kit....
- Extendable Sun Visors
- Question on shackle bushings
- All Pro Parking Brake HUMMMM
- 93 runner Spare tire tool kit
- temperature overshoot?
- Horn!!!!!!!!!!!!
- no shut off
- 3.0 no oil pressure
- ifs questions
- Bought a high lift jack from Tractor Supply today.
- No OME on TRDparts4U!?
- Help needed on 94 Runner engine removal
- Removing the 80 amp main fuse
- Help with LCA removal
- Diagnosis: Replace Rear Differential Bearings!
- ECU V6 3.0 compatability
- flopped and need help!
- Bumstops
- Newbie with an electrical problem
- Help: Need Drive Shaft
- killing a yota
- V6 tcase options
- 1st Gen fiberglass top.....what do you use to shine it up?
- rear locker?
- Lift ?'s
- fuel pump drive cam question
- What is that sound?
- Calling all Torque Converter and AT gurus!!
- Need help deciding -- fixing saggy rear-end!
- Twin stick installation
- '92 3.0 dies after throttle release....
- O2 sensors-replace them!!!!!!!
- which T-case fluid to use on 5spd swap?
- Lift suggestions and ?'s
- starting and dieing problem
- replacing master cylinder
- 3.4 swap price
- Some people shouldn't wrench on their junk
- Fluid replacement questions.
- 4Runner V6 fuel return lines
- engine swap options
- Super sensitive gauge?
- Voltage guage dances
- Fuel Leak-Might be Simple
- Dumb question!
- 3.0 Timing troubles
- Flashing O/D light and non-working speedo. Related??
- a few misc. problems
- 901 coils
- Seats
- quieting my exhaust
- Its time for a paint job input needed
- STOLEN!! Catalitic Converter
- Passed Emission Testing, but weird results.
- So is this '94 too expensive?
- WTB: Used 22-re Camshaft
- Rear Defogger NFG
- 4runner rear window
- The Flowmaster Super 44..
- Boken key
- Need help with an over heating problem
- Good defogger recomindations?
- uh oh!
- Need advice to help 4x4 performance
- 22re Check Engine Light, no noticeable cause
- 93 3VZ-E Clogged Water Bypass No. 4
- Not sure what to do
- Keeps popping out of third gear!
- locking hubs, lost a piece!!
- electrical gremlins and the different engines im contemplating
- Choke?
- Choke ?
- Engine Code 51 22re
