Rear ABS questions
Old Feb 1, 2008 | 02:14 PM
Matt16's Avatar
Rear ABS questions
I have a 1990 4Runner SR5 22RE 5 spd. with power steering. I have even seen an ABS fuse. I'm thus assuming I have rear ABS even though I have never seen an ABS light on the dash.
Is the process different for bleeding FRONT brakes with a truck equipped with rear ABS?
Old Feb 1, 2008 | 06:26 PM
Jay351's Avatar
Rear abs makes no difference in how you bleed the brakes.
Old Feb 1, 2008 | 06:32 PM
toytech76's Avatar
**X2*
Old Feb 2, 2008 | 11:38 AM
Matt16's Avatar
Good, that makes life easy. Now to modify the load sensing proportioning valve to cope with the 1.5" lift.
Old Feb 2, 2008 | 04:56 PM
Jay351's Avatar
I didn't even bother
But if you really want to, just make a flat bracket 1.5" long and bolt the lsv to that and the bracket to the stock mounting hole on the axle.
Old Feb 2, 2008 | 06:12 PM
longhungsilver's Avatar
or just stick it to your frame like i did
Old Feb 3, 2008 | 01:23 PM
Matt16's Avatar
The braking is fine as is, I just have time because I'm off work from a car accident.
Old Feb 3, 2008 | 07:32 PM
bigarms23's Avatar
if you have abs look for the sensor on the3rd member if its not there you dont
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
