PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. help please ECM
  2. Changed O2sensor .......Now she won't start
  3. Tapped at 50mph
  4. 95 t100 transmission shift solenoid sensor location on a Automatic
  5. 94' running rich and having other issues
  6. Is anybody else running 5w50 synthetic in their 3vze?
  7. Help with timing!!!!!
  8. 87 DLX front pass seat cable
  9. The Search for Rear Bumper Corners
  10. After months of one thing after another...
  11. OEM lug studs
  12. AXLE SHAFT questions
  13. Vibration, loud, humming sound in 3rd And 5th gear
  14. 94 4Runner 22RE sudden poor mileage Codes 52 and 25
  15. 92 pickup 4x4 intermittent vibration
  16. What is the O.E.M for a 93 3.0 fuel pump?
  17. Cranks but no spark
  18. '91 winnebago warrior (toyota pickup chassis) v6 automatic wobbles when put in drive
  19. Just did head gasket now I got crank no start
  20. Tie rods and ball joints?
  21. What is this sensor and part number...
  22. 3rd Gen 3.4 motor, dash and full wiring swap into a 2nd gen
  23. Taking out Transmission to dos
  24. My wobbling pulleys (info)
  25. My wobbling pulleys (info/fix)
  26. Transfer Case Buzzing
  27. CMH - keep it or block it?
  28. Blower control replace
  29. 94 SR5 sunroof glass replacement
  30. Where to find a bump stop
  31. 22re - Intake vaccum thing - name?
  32. Something I noticed.
  33. 22re wiring diagrams
  34. newer style - tps connector 22re
  35. permanent fuel pressure gauge
  36. 95 Toyota 4Runner 3.0L "Where do I start"
  37. EGR/PAIR and hardline delete help??
  38. Vinyl Flooring for 94 Pickup
  39. '87 22RE blowing smoke on acceleration
  40. '93 Toyota Pickup Headlight Issues
  41. Cooling System Issues - Steam but guage reads ok.
  42. 3VZE oil pressure sender leak
  43. 98 Tacoma transmission put in an 89 pick up
  44. 94 pickup 22re will not start need some input please
  45. Cluster swap question
  46. Cluster swap question
  47. 1UZ-FE Engine Swap?
  48. '88 PU door adjust instructions? Wind whistle.
  49. 94 22re pick dies when idling down
  50. What's a blown head gasket look like?
  51. Head bolt removal trick...
  52. 1989 W56C Trans 4WD Truck
  53. temp gauge not working 22re
  54. fuel shutoff
  55. sensor
  56. 22R HAI and Thermo Valve
  57. No-start, Rapidly flashing CEL
  58. Port work and over sized valves?
  59. Seriously... omg... so frustrating...
  60. Looking For A 1988 Truck Bed
  61. Clutch replacement add on?
  62. R150 Dimensions for adapter
  63. AISIN HUB "springs and pawl" PARTS No. ??????
  64. 1992 Toyota Pickup 5 Speed Manual Transmission Fluid Change
  65. Valve cover hose leak
  66. How much should I sell for? 92 Toyota Pickup 3.0
  67. 1990 3.0 pickup backfiring issues
  68. Odd Brake Pad Replacement Question (OEM pads don’t have the hole for the spring)
  69. 1986 4Runner no start
  70. 91 4runner water pump pulley misalignment
  71. Rear bumper
  72. Heater stopped blowing
  73. 90 vs 94 Toyota
  74. 22re bogging, will not rev
  75. 92 4runner 4x4 issue
  76. Starting issue 1991 4runner 3VZE automatic
  77. Rear Drum Clearance/Cooling
  78. timing
  79. 91’ 3.0 broke down!😢
  80. W56 transmission/transfercase breathers
  81. Checking out W56
  82. LCE 22R Heat riser kit
  83. Did I drill too deeply into my head?
  84. T4R first gen 1988 - Lug nuts for OEM alloy rims
  85. Merry Christmas
  86. 3vze cranks, but no start.
  87. Best camshaft?
  88. Where dose the ground off the firdwall connect to motor
  89. 5vz issues, any help?
  90. 1986 r22 no inyec
  91. 1986 R22 No inyectors sign.
  92. Timing way retarded!!
  93. Headliner
  94. 95 toyota 4runner 3.0 not running
  95. Frozen Alternator?!?!
  96. Carpet replacement
  97. Plastic on Side of Truck Bed 1988 4x4 Help Needed!
  98. Turbo help
  99. Re-wiring truck
  100. E-Bay lights
  101. LED Headlight install
  102. Brake-drag from changing only one set of shoes?
  103. 22re not starting after changing bad MAF sensor
  104. 1987 4runner back window problems
  105. Best muffler???
  106. Need ideas on what might be the cause
  107. 1992 pickup transmission delayed overdrive.
  108. 93 4x4 Pickup chokes under acceleration
  109. Transmission swap gasket help
  110. Catalytic Converter Bolts
  111. *NEED HELP* Toyota pickup running extremely rough
  112. I can't get a break... help please
  113. Leer shell rear door lear
  114. Yet ANOTHER rim size question thread
  115. 1992 Toyota pickup DLX 3.0 v6 not starting.
  116. Another No Start Thread *Please Help*
  117. Top shift transfer case in place of forward shift
  118. Head Gasket /Intake Gasket 22RE-What else should be replaced
  119. **NEED HELP** timing chain rubbing on cover
  120. Valve Cover Washer Seals
  121. Fixed my "NO HEAT" situation...bad control valve
  122. 87 22re Won't start
  123. Idle/low rev issues
  124. 1990 22re 2wd pickup base model cigarette lighter
  125. 1992 /1996 frame swap
  126. NO 4th gear. Trans swap?
  127. Alternator or water pump squeak after shutting down.
  128. Source for OEM Style Spring Clamps?
  129. Leaking fuel, what hoses are these?
  130. Tranny trouble
  131. For what it's worth...
  132. 88 22re Throttle cutting in and out.
  133. 80s parts source
  134. Help diagnosing engine noise 22r
  135. 22RE Engine install
  136. BVSV or TVV vacuum valve in water block 3vze
  137. 1990 toyota sr5 4x4 v6 just put in new tps and came up with a surging idle
  138. Exhaust Recommendations
  139. lifter orientation
  140. Interior shift boots replacement
  141. Blue/Red temperature lever
  142. 1st gen 4runner plastic trim and rubber parts
  143. Need a 1994-1995 4runner/Pickup ECU
  144. Code 41/52 Together
  145. 1993 Toyota pickup engine noise
  146. can I rebuild my speedo cable?
  147. No headlights
  148. Part Identification
  149. Any experience with aftermarket chrome bumpers?
  150. Differences on down pipes from exhaust manifolds?
  151. passeger seat
  152. Head rebuild in ca
  153. Drive Belt Idler Pulley replacement for 95 Toyota pickup
  154. 86 2wd pickup---turn key will not start
  155. Best 22r short block seller?
  156. Anyone have the LC Engineering Pro Flow Exhaust for 3VZ?
  157. T4R first gen 22RE - Noooo! Coolant leak before trip.
  158. Diagnosing a 1994 Pick up running ruff
  159. Truck sounds like a popcorn maker!
  160. Help with distributor timing
  161. No start No crank after its at normal running temp
  162. knoch sensor
  163. 3vze no start!?
  164. 1989 toyota pickup V6 intermittent starting issues
  165. Your take on double shackles aka revolver shackles
  166. 88 Sr5 Gauge Cluster Just Went Out
  167. Wheel hub bearing
  168. Striped wheel stud
  169. Overdrive won’t engage in 4Lo
  170. And Now My '94 is Worth a Little Less
  171. Gas mileage issues?
  172. Rear seats in an '87 pickup?
  173. 1994 3.0 in a 1989 4runner
  174. Bucket Seat Swap with 90s Corolla Seats
  175. Denver 22re
  176. Got the head off, how is everything looking?
  177. Tapping sound, rebuilt 92 2.4 22re
  178. 4wd indicator switch help
  179. 1994 22re issues
  180. Clutch won’t disengage completely 3vze
  181. In major need of front end upgrades
  182. Logic puzzle for 12v nerds
  183. 22RE Burns Oil Only In Gear
  184. no power
  185. OBD I (Best bang for the Buck)
  186. Need a recommendation on a good car cover for the 4Runner
  187. 2wd motor vs 4wd..
  188. 1991 Toyota 22re pickup back pressure issue
  189. Remove bed of 2000 Dodge 1500
  190. Chrome accessories?
  191. 1986 22re (W56) Random Misfire At Idle and 2000-3000 RPM Range
  192. strange whistle/ 'air inflating tire' sound
  193. 22re just DIED
  194. Pipes from heater core to coolant lines.
  195. Seized fan support *RESOLVED*
  196. Contemplating 3vze swap
  197. 88 4Runner trouble starting, but runs good
  198. Low idle on hot startup 92 22RE
  199. oh no.Rod knock?
  200. Valve adjust help
  201. Oil Leak, unknown
  202. rear sway bar upgrade
  203. Silicone gaskets
  204. 92 3vze no start after head gasket repair
  205. Very Rough no power 94 pickup 22re
  206. Whats the proper term?
  207. Grueling Daily Commute - Help with 1993 Toyota Pickup 4wd v6
  208. Blinkers and OD
  209. '88 4Runner no speedo, flashing O/D light
  210. 86 2wd diesel pickup driveshaft
  211. 4Runner RPM change in mornings
  212. 88 Pickup: no check engine light, won't start.
  213. Starter compatibility
  214. Anyone running a snow plow?
  215. help with intermittent front end vibration - audio clip
  216. 22RE propane conversion SR5 Tach question
  217. 93 pickup 22re engine swap?
  218. sun roof drains
  219. 3vze odd idle, need help
  220. 3vze no start
  221. Anybody using a UWS toolbox?
  222. flasher dont work
  223. output shaft seal A43D
  224. 1993 yoga pickup UWS toolbox
  225. Some help with the dash
  226. Timing belt spring location
  227. tires
  228. intermittent rattle when decelerating
  229. 91 22re 4x4 giving me strange idle issues.
  230. Spring seat/lower shock mount question
  231. 3vze temp gauge
  232. Torsion bar compromised ?
  233. HELP! Raw Fuel coming out of exhaust manifold after new injectors
  234. Unsolvable TAIL fuse issue
  235. 2014 camry
  236. 94 hi-lux truck
  237. 95 4Runner 3.0 timing issue/question
  238. Finally... no more leaks
  239. 1994 Toyota Pickup 3.0L Mystery part
  240. Dash board lights help
  241. 1st gen 4Runner Dood bumpers
  242. Oil pressure sending unit wire routing on a 92 22RE
  243. no heat
  244. 95 4Runner rear window. Age old question maybe.
  245. No low oil pressure idiot light on a 92 Deluxe?
  246. aftermarket water temp sensor on my 1988 PU
  247. intermittent alternator issues 22-RE - coolant related.
  248. Starter run-on after truck sits for a week
  249. Fuel line replacement on 88 4runner
  250. Sensor identification
