PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 [148] 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. NEED HELP Pinion Nut Wont Budge
  2. Broken wire between fuel filter and oil filter...What's it to?!? SEE PICS
  3. unsolved mysteries - transmission help
  4. Need help with 93 22RE fuel problem
  5. ticking problem.. (not original valve tick)
  6. Fuel Problem?
  7. 4.70:1 Gearing in V6 & Auto
  8. Crappy mpg after new coil pack and tune up.
  9. AC idler tensioner pulley missing need info.
  10. Replace CV or no?
  11. Front vibration and grinding noise after first snow day
  12. temp gauge
  13. cb radio locations
  14. charge and brake light
  15. Couple of questions: ISR, Spark plugs
  16. Hubs: Havent seen anyone do this before
  17. manual vs automatic transmission
  18. 3vze heres one
  19. Oxygen sensor brand preference?
  20. Strong exhaust smell...Too Rich????
  21. rear seat backrest fold knob
  22. 22re starts and then dies immediately
  23. 22re replacement help needed ASAP!
  24. Got my catalytic converter stolen last night
  25. Source for VSV and dashpot
  26. Breaking into my 4runner
  27. LC Coil seats
  28. 86' Diesel 5 spd. in 87' 22r 4 spd.
  29. Wait, that ISNT suppose to bend that way?
  30. No power, all fuses good. damn it all.
  31. Power window installation - apply power only when key is inserted
  32. problem inconclusive - need help!
  33. n00bie here... Saying hello.
  34. Front Differential on a IFS
  35. 3vze oil leak
  36. where do these vacuum lines go
  37. 92 22re leak
  38. Aisin Front Manual Hubs in bits.... Help
  39. Fuses melting?
  40. Wimpy Winch?
  41. Finally Herculined the 4runner
  42. From Auto locking Hubs to Manuel.
  43. injectors keeps leaking,no power and stalls when clutch is pressed
  44. '91 4runner front end squeal - stumped
  45. Brake line leak
  46. Emissions control
  47. Pictures of my truck 22RE
  48. Hydro-Locked
  49. LC coil lift question please help
  50. RPM jump with steady increase in throttle
  51. Problem: Cranks, won't start.
  52. timing
  53. aux off-road lights not working
  54. gear install questions?
  55. 3vze cranks hard but wont start
  56. Hard clicking/knocking in front of 3VZE
  57. Seat Swap Trouble
  58. 22re no diag port
  59. 22RE engine mod questions
  60. What transmission do I have? solenoids?
  61. 86 4runner fuel injector will not fire
  62. longbed bobbed
  63. removing lower steering wheel panel
  64. 1989 4x4 Visor
  65. need 2 know how to change waterpump!!
  66. Torn CV Boot....argghh
  67. OBDI Code 11
  68. wiring problem
  69. Oxygen Sensor Interchange
  70. pitman arm question
  71. craigslist truck in detriot
  72. Wanting a small lift
  73. LCE big bore and IACV
  74. 86 22rte. trans reverse wire question
  75. craigslist caught my eye
  76. Need new G54 Transmission
  77. Need help with power steering pump snap ring please!!!
  78. 22re exhaust downpipe/headpipe/y-pipe leak
  79. Manual Transmission Options
  80. Bolt sizes on '94 4Runner Running Boards and Rock Guard
  81. I got a newbie question
  82. Long travel bolt on 91 p/u
  83. 22re stops making power at 3000RPMs
  84. Rear diff, headers, blower and step-bars.
  85. No roll start?
  86. O2 sensor question...
  87. 86 turbo. knocking while turning - help
  88. noisy power steering
  89. Code 6 RPM signal/truck won't start
  90. Pictures of camber adjust bolts 91 pickup? Anyone
  91. Front tires rub 31 bfg
  92. Rebuilt 22RE idle and O2 sensor issues.
  93. 36/15.5 tires on 4-5inch lift
  94. O2 sensor question 88 4x4
  95. Hard power steering
  96. rear end code
  97. 86 22rte auto to manual swap wiring questions
  98. 94 Pickup 5 speed swap question
  99. 911!! need help!
  100. 22RE Stumble
  101. Dash Rheostat
  102. Putting an 84 22R in an 86 Pickup
  103. Need help with dropping the gas tank.
  104. Moog or Duralast: idler arm
  105. Cant get my steering stabilizer off my runner!
  106. front bumper removal for snorkel install?
  107. popping out of 4 low
  108. 93 yota roll bar
  109. No Brakes!.....No Leaks......?
  110. Steering Wheel not Straight
  111. transsmission help!!!
  112. Bunk Beds a.k.a. I live in my Truck.
  113. weird 3VZE coolant leak
  114. 200,000kms on my 3VZ-E!
  115. Rear slider replacement
  116. 1990 4runner 22 re trouble shooting HELP
  117. New Body Lift...Need Help
  118. CHECK THIS OUT!! (PIC inside)
  119. toyotas 1st locking differential
  120. 87 -- 22r rebuild -- No Freaken WAY!!!
  121. 1989 4runner leveling kit
  122. Moog spring swap?
  123. Sputtering!!
  124. frustrated with misfire
  125. Leaking Sun Roof
  126. 86 4runner tire question?
  127. It's Alive!!!
  128. Emissions failed 90 3vze
  129. 87 22r problem
  130. stripped threads...arrrrrgggg
  131. Another dumb 4x4 question
  132. Doing tune Up..what should i use
  133. wheel Spacer
  134. Overdrive codes 62/63???
  135. failed smog need 22re smog parts
  136. Surprised Me Towing!
  137. Fuel door will not stay unlocked
  138. camper skylight/sunroof?
  139. Rebuilt motor: White smoke and water in oil :(
  140. Bleeding the cooling system on 3VZE
  141. swappin a 4runner lift to a pickup
  142. Flowmaster origianal 40 or Delta Flow 40? Opinions? thanks
  143. tow hitch class
  144. need rebuild help on 94 4x4
  145. power steering
  146. 3.0 crossover
  147. ifs axle replacement
  148. Flickering oil light
  149. 91 Surf build-up thread
  150. quick question about an ecu....
  151. 22re fresh top end, now some problems?!?!
  152. 22r Coolant temp gage sender
  153. Pulling V6 Out of My '93: Need Advice
  154. 2nd Gen front end swap
  155. My 93 p/u story... suggestions?
  156. urban wheeling
  157. New Problem has shown its ugly face
  158. Removing Flywheel
  159. 22re sputters after mild puddles
  160. letting the truck sit for a week
  161. 3.0 Changing mains in frame
  162. Spun ALL sets of rod bearings!
  163. O2 sensor hole diameter????
  164. 1986 pick up 22rte motor
  165. Overheating diagnosis
  166. 1st gen 4runner- sweet locking center console
  167. Jack tools
  168. T-Chain Timing Marks Not Normal
  169. new exhaust pipe pics
  170. 1995 project Runner - quick fixes then engine rebuild, suspenion, etc
  171. potentially stupid question about gearing
  172. wire 88 4runner 22re help
  173. Exhaust questions
  174. 95 4Runner Dies!!! Help!
  175. fuel line help
  176. What kind of off roadin' can I do in my 2wd?
  177. 95 4runner engine swap
  178. Timing chain guide question
  179. Rear lift springs.
  180. Help Diagnose This Noise (engine)
  181. The engine cranks but wont turn over. ATTENTION MECHANICS!?
  182. After market alarm trouble shooting
  183. Could un-bled cooling system cause 22re water pump to fail?
  184. 87 4runner. lockers and power adders
  185. Automatic transmission skipping gears?
  186. Injectors 101 please, 3VZ
  187. 22RE runs weak after rebuild
  188. 1988 22re cold air intake
  189. 1987 toyota pickup straight axel swap
  190. coolant hose routing
  191. whats cheaper swap 22re or rebuild?
  192. 88 22re vs. 84 22r
  193. deep water VIDEO!!
  194. Engine needs replacing, or rebuild!!
  195. Electronic Overdrive issue
  196. Quick body question
  197. random toyota seal found in garage
  198. broken lug stud (plural), safe to drive?
  199. 3.0 Motor Swap - ECU Help
  200. Need your opinion on 22r head
  201. 89 4runner oil light question
  202. 22re gushing oil
  203. cylinder heads switch
  204. Ground Clearence 89' 4runner
  205. 91 pick up v6 revs fine after it bogs down and almost dies first
  206. Epic battle to start newly build 22RE continues
  207. I need help troubleshooting!!
  208. looking for opinions on the 3.0 v6
  209. 89 2wd 4spd -> 5spd swap
  210. oil loss on 95 v6 p/u
  211. helicoil question
  212. New to toyota--old problem 1989 V6 head gaskets
  213. Pull the starter when doing headers!
  214. Removing crank from 3.0, auto- pull engine or trans?
  215. rough idle on 92 4runner after replacing crank covers
  216. Time for a rebuild she has died!!!!!!!!!!!!!
  217. Aftermarket ignition spark gap
  218. need a new throttle linkage
  219. Grease nipples and a rattle.
  220. How much to cuff off my fenders?
  221. How to tell if your engine is frozen
  222. Diagnostic code 21
  223. Off The Wall Question About Engine Computers.
  224. 22R Alternator, DIY or Shop?
  225. 2 questions
  226. One last sensor... then It cranks!
  227. EGR / Vacuum help 3VZE
  228. Exhaust question
  229. No oil pressure when turning over new motor
  230. vacuum line help
  231. Cruise control wiring
  232. Blue-94 4Runner Build
  233. Manual hubs not turning all the way to Lock
  234. Anyone know where this goes?
  235. 22re ground wire locations - the guide!!!
  236. Diagnostic Codes 25 & 26
  237. 22RE Leaking Fuel Injectors
  238. charging system doesnt work
  239. Exhaust Manifold Cover Questions...
  240. 3vze engine water outlet corroded!!!
  241. Dome Light Wiring Pictures?
  242. Quick exhaust question!
  243. 1987 toyota electrical problem
  244. knock sensor
  245. ac idle up problem
  246. Leaking exhaust???
  247. Engine bay ground connection points? Diagram?
  248. Bad Fuel Pump ???.
  249. thermostat install
  250. rearend swap ?
