EGR / Vacuum help 3VZE
Old Oct 18, 2009 | 03:16 PM
xxJDxx's Avatar
So while checking my vacuum lines today I noticed the following line in the pic below wasnt connected to anything. The line comes from the peice circled. What is it for? seems to be connected to the EGR.
Also, I seem to be missing the temp sensor on the EGR...could this explain the rough acceleration / hesitation i get in second gear?
Old Oct 18, 2009 | 03:27 PM
Zinek's Avatar
The circuled Item is a valve that lets fresh air to enter into the exhaust manifold to controll emissions, With no egr temp sensor you should be getting a MIL code.
Old Oct 18, 2009 | 05:00 PM
xxJDxx's Avatar
^Thats what i thought, but no MIL...... whatever was done here happened before i bought the runner....
Old Oct 19, 2009 | 10:27 PM
xxJDxx's Avatar
Could someone go outside and have a look at their rig and tell me what that vac hose is connected to....Please...I could use the help
Old Oct 20, 2009 | 07:48 AM
BoostinChick's Avatar
If you have a stock hood you can look under that. It has a wiring diagram. I believe it connects to something on the VSV.
Old Oct 20, 2009 | 09:23 AM
harrywat's Avatar
I'm trying to load two pics that show where it connects. Problem is I'm a pic dummy.
No go on the pics, I don't know how. However, it goes to the VSV closest to the charcol canister, mounted on the inside fender.
Tell me how to add a pic and I'll show you. (old guys are sad, grin)
Thanks
Harry
Old Oct 20, 2009 | 09:28 AM
jpmountainboy's Avatar
i believe it goes tucked up under the plenum on the left side near a bunch of other garbage. its been a while though...rocking the 3.4 these days.
Old Oct 20, 2009 | 09:30 AM
look under there and you should see and empty spot hiding way back there...mark and disconnect all those little hoses if you need to see better.
Old Oct 20, 2009 | 09:36 AM
that valve is called the pair reed valve...here is the link on ttora with the FSM specs/routing on it.
http://www.ncttora.com/fsm/1990-1995...n/pulsedse.pdf
Old Oct 20, 2009 | 10:24 PM
xxJDxx's Avatar
^Thanks man, one problem down...
Next I've got to tackle my EGR....i have no temp sensor, and no MIL..... i tried to take the EGR off today and the bolts are EXTREMELY tight, i feel like i might brake something as the whole engine twists as i try to loosen them... could i potentially break something, or should i just use more force?
Old Oct 20, 2009 | 10:44 PM
bugs1961's Avatar
Only California trucks came with the EGR temp sensor. Mine doesn't have one either. If your truck was originally sold in one of the 49 states then you won't have a sensor.
Old Oct 21, 2009 | 08:54 PM
xxJDxx's Avatar
^really, surprised i haven't picked up on that yet, whenever i see pics of the 3VZE they always seem to have em....
as for the EGR...to loosen the nuts, do they turn towards the EGR valve or away from it?? Dont wanna be applying tons of force in the wrong direction...
Old Oct 21, 2009 | 09:54 PM
eugenedbrooksiii's Avatar
Its all right hand thread.
Blamalam
Mar 12, 2022 07:34 AM
Colington
Aug 13, 2015 02:21 PM
e_richard
Jul 30, 2015 06:50 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
