Attempting to control AC with haltech / 94 pickup
Old May 18, 2026 | 08:03 AM
White5thgen's Avatar
I’ve got my haltech all setup and running currently setting up an IAC and haltech controlled fan relay I wanted to do the same with the A/c compressor.
would anyone be able to assist me with figuring out in the A/c wiring where the request signal is? Maybe I’m missing something but this is my goal
Wire the 22RE's A/C Request signal from the cabin switch to a spare Analog Voltage Input (AVI) or Digital Pulsed Input (SPI) on the Haltech.”
I am assuming once that is located, I should be able to find the ground side of the compressor relay pretty easily to setup a DPO
any help is appreciated
Old May 19, 2026 | 06:47 AM
scope103's Avatar
Can I assume a "haltech" is a replacement ECU? https://www.haltech.com/ecu-buyers-guide/ In your stock truck the AC isn't controlled by (or even connected to) the ECU. Are you just trying to replace the on/off switch? I know nothing about "haltech," but I don't see that their ECUs have an output for that.
Old May 19, 2026 | 06:54 AM
haltech is a standalone ECU and it can do other functions/switches/sensors. It can control A/C clutch and in this instance it can apparently just control the A/C relay and leave the amplifier in tact I just can’t decipher the diagram to find what I need
Old May 20, 2026 | 05:25 AM
scope103's Avatar
The line labelled "A/C Fuse" on your diagram is downstream of the A/C fuse, which gets battery through the heater relay (this assures the compressor won't start unless the heater blower is running). L-W on your diagram, but L-R on mine. When the A/C switch is pressed, it connects that switched (by the relay) battery voltage to B-Y line to the A/C amplifier (your diagram shows the wire color changing to L-W, at a splice?, but my diagram shows no change in the wire color).
I don't understand why you would want your ECU involved in turning the A/C on and off, but that's up to you. Just keep in mind that you have to keep it from powering the A/C Amplifier when the heater relay is open.
Old May 20, 2026 | 05:31 AM
I need the ECU to know the ac is on so it can control the idle air control and cooling fans properly
The factory Toyota A/C amplifier is completely self-contained and handles pressure switches, evaporator freezing, and compressor cutout. The Haltech’s job is simply to recognize when A/C is requested so it can raise your idle and cut the compressor at full throttle.
  • Idle Up: The Haltech automatically increases your target idle RPM and/or idle valve duty cycle the moment the A/C is activated, preventing the engine from bogging down or stalling.
  • WOT Cutoff: You can program the ECU to disable the A/C compressor clutch when the throttle is wide open (WOT) or during high engine load, restoring power to the wheels and protecting the compressor.
  • Safety Lockouts: You can set the ECU to disable the A/C if the engine begins to overheat, or if the RPMs go too high.
would you be able to post your diagram? I’ve been having a hard time finding accurate diagrams for a 94 pickup 5 speed 4wd 22re
Old May 20, 2026 | 08:36 AM
dfarr67's Avatar
I'd probably be talking to Haltech or a dealer about wiring the ecu to know when idle needs bumping.
Old May 20, 2026 | 09:14 AM
the post above this states the instructions and function of what I’m trying to do from haltech.
Old May 20, 2026 | 03:15 PM
Robert m's Avatar
Could you just tap into the AC clutch wire for signal?
Old May 20, 2026 | 03:50 PM
the haltech uses ground to complete relay circuits to turn things on so I need to locate the A/C clutch relay power from dash switch and relay ground. But I can’t find any good diagrams, the one I posted doesn’t have the same colors as my truck
808-3VZE
Sep 23, 2017 07:45 PM
alva22re
Nov 4, 2015 11:31 PM
Gevo
May 31, 2014 08:36 PM
roundhouse
Sep 14, 2013 01:01 PM
joshik
Jul 28, 2006 09:11 AM
