1990 4runner 22 re trouble shooting HELP
Old Oct 21, 2009 | 11:00 PM
1990 4runner 22re's Avatar
I am trying to work out why my 4th cylinder is missing at idle.
I have checked my distributer cap, plug wires, vacum leaks, spark plugs, injectors none of this has had any effect on why the 4th is missing at idle. Once rpms pick up then the miss goes away.
Anyone have some good direction for me??
Thanks,
Old Oct 21, 2009 | 11:33 PM
malteserunner's Avatar
Valve adjustment might be a little tight. Welcome to YT.
Old Oct 22, 2009 | 08:54 AM
I didnt add that to what I did already but ya I did a vavle adjustment and they were a bit tight. after I adjusted them I had no change in my problem. Kinda stuck on this thinking I might swap out ECC or something?
Thanks,
Old Oct 22, 2009 | 09:33 AM
Did you check your compression after the valve adjustment?
Old Oct 22, 2009 | 10:12 AM
Checked before but not after. I will check that later tonight but It seems like its got to be a elctrical issue?
Old Oct 22, 2009 | 10:13 AM
Probably, but I always rule out the basics first. What were the compression readings before the valve adjust?
Old Oct 22, 2009 | 10:15 AM
Oh, and you need to check your coolant level. Low coolant causes idle issues in 22RE's.
Old Oct 22, 2009 | 10:19 AM
Coolant level is good (drained to do the injectors and then replaced) compresions test was good it was around 170 striaght across
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
