- Wierd oil pressure
- Pulling Pitman arm trouble
- 3vze timing issues
- 91 shaking 50mph and up.
- intake manifold conversion
- Hard Start '94 Runner
- Bigger brakes, bigger MC?
- Help! 1991 4Runner front coil spring??
- Just installed the 4crawler spacers
- new guy 1st t4r
- Exaust help
- Tube front bumper build
- looking for tube frontend pictures
- '92 engine problems
- 22re to 3.0 engine swap questions
- differences between 22r heads
- 86 auto tranny major leak!
- Has anybody rolled trying to pull you out?
- Gas Tank Capacity
- OME n92 vs n98?
- 99 4Runner seats into an 87 4Runner?
- roof off, over night
- Brake issues. Sucking air in somewhere???
- Knock Sensor Voltage...
- Recalls
- I think I broke something, truck won't start
- torsion bar???
- 22re swap efi to carb
- speedometer recalibration
- 67" trail-gear sliders on a 2nd gen?
- ISR mod leak question
- EGR and colder spark plug
- Brake line problem...
- Don't park under trees
- idle on v6
- 86 4Runner finally home! (wreck)
- Roll bar, take it or leave it?
- Not the best way to learn about your yota..... :(
- bumper brackets?
- how does my 22RE sound?
- SHOCK/Flip kit question....
- 88 with 22re loping idle
- Clutch Pedal master slave pin hole out of round
- '91-'86 issues
- a/c half way there
- door removal ideas??
- 1988 4runner V6 Hesitation or Miss & low idle
- Battery/Intake Swap
- Which muffler for 22re
- Stock Exhaust size
- 3VZE timing belt experience and thanks
- help with fuel leak in '91 22RE
- 3rd Gen electronic speedo's???
- 86 Runner Rear Window Problems
- Heating Problem
- Buyin a new winch
- Wiki History on Toyota Hilux/Pickup
- Best deal for a SAS kit
- this is my first EFI truck want to upgrade but i am kina lost
- Oil Seal Rant
- IFS spindle bushing clearance specs ?
- new TG rear 3rd wont fit!!! is it tight?
- fsm for 94 runner?
- anybody used these auto zone shackles
- Not sure if i need this bolt in the middle or not on the exhaust?
- 1991 4 runner need lots of answers
- HELP ! grinding sound from right front tire area
- Factory Service Manual
- locked hubs + 2wd=?
- Burning Smell at High RPMs
- 87 Toyota Pickup SR5 4x4
- bushwacker flares with mc rear
- Shops in Michigan
- Need help w/22re ticking!
- Finally put my lift on
- Difference between 2WD and 4WD boxes?
- ? about downey springs
- Need help on 1991 22re
- ammo boxes
- Which side of the caliper moves?
- Trouble with codes
- no return fuul from pressure regulator
- ALso noise when im driving.
- 1990 Toyota rv 3vz clicking
- Power windows hvent worked in over a month
- buying a 1990 runner Good or Bad Idea?
- ok heres a stupid question how do you take off the shifter on a 5 speed
- Door hinge modification with removable pins and bushings
- Who makes a good Torque converter?
- Loud ticking after valve adjustment
- Clutch noise
- 1987 truck: what's it worth?
- Sudden loss of engine power and running rough
- front noise problem
- annoying EFI
- Slave Cylinder
- weber carb help!
- 3.0 time to rebuild or SWAP???
- help! 88 ex cab 140k- bent frame
- How can I do an "in driveway" 4wd check?
- Intermittent check engine light and engine dying
- Still tapping after valve adjustment. Header bolt stripped out in the head also.
- '91 Rear Spring Optiions
- Added on to rear bumper
- Engine died while driving!?!
- Vibration during acceleration
- SAS questions
- 4runner idle
- Remote Kill Switch?
- Vibration in steering
- Backward TPS
- 1987 4runner California Smog Requirements
- 22R Turbo without the turbo installed
- only looking one front hub for 4wd, will you 3wd or only 2wd still
- No Spark any help?
- Time to blow the budget
- So my 1991 runner met a concrete
- dual case driveshaft length?
- whats a good price for toyota front straight axle
- 3.0 to 3.4 conversion - ECU question
- New to me 4Runner
- So close to AC I could feel it!
- So now I have a transmission issue.....
- i think my rear window finally died. . . .
- 3.0L v6 Thorley headers on the way, any tips?
- just did a body lift and now truck is overheating please help.
- TVV's are REALLLLLLY fragile
- making a tailgate....
- My ISR MOD - whad u think???
- HID Question
- Anyone use this spare tire swing-out kit?
- Some help please- 1995 4runner 3.0
- computer programmer
- eliminate load sensing proportioning valve?
- 22r into 4runner
- grinding noise
- Tailgate swap...... regular to tire carrier !!!!!
- Which third memebers can i use?
- Please Help. Another Noise thread
- Replaced starter, now windows and locks are intermittent.
- 94 4runner rwd transmission
- striped bolt hole on head help
- I painted it.
- 86 starting problem
- 85 2wd IFS help?
- Bumpers
- stock 91 thinking of what i should do?
- rear tailgate regulator spring
- Bushings
- knuckle bearings
- Tie rod end grease fittings wth?
- 1st gen mud flaps question
- "post your trucks" Toyota Baja Build NEED ADVISE!!!!!
- air box opinons??
- 4.88s + Aussie Progress
- diff swap ?
- Crank Pulley Troubles
- 3vze loud ticking after running for 30 seconds
- Which shocks do I need?
- sensor
- Battery trays
- Overheating now with same radiator
- Bleeder-Dude's Official 22re Engine Rebuild Thread - TONS OF PICTURES!!!
- Forward shift t case on R151F?
- bought an 89 22RE to rebuild and replace my 86 re. Will it work?
- tranny swap
- Disapointed...31 10.5 15 yokahama MTs and OME 901s on the back
- Crazy Starter Battery Idea
- Questions about block heater replacement (with pics)
- Does the coils of a land cruiser fits a 4runner?
- Another yota gone...:(
- A little parking lot fun with snow
- Rocker Pods
- 4Runner Lift gate issues
- Transfer case Shifting
- Parting out 94 sr5 4runner
- what is the diff between ujoints
- brakes
- One-Piece Tundra Conversion
- Fuel problems? Rough
- My first time replacing injectors 88 4runner
- 95 4runner Remote
- Hazard lights won't work, but turn signals do
- Cup Holder
- oil/fuel/temp gauge help
- oil/fuel/temp gauge question
- which exhaust should i do
- motor swaps??
- Thanks! With your help, I have replaced wheel bearings, etc
- Anyone recommend 33x12.5 tires on the stock 15x7 wheels?
- Head Gasket
- Vacuum (Lack Of) Help 3.0
- Removing Brake pins
- 95 4Runner Sag [Help!]
- creeper joint shackle mounts?
- Digital Thermometer Install
- upgraded throttle body...
- Need W56 trans. and TC buying help/advice
- Easy question, what are these buttons?
- Rod Bearing Math
- License Plate Light Braket...
- Truck wont even push-start
- 3.0 engine codes HELP!!!!
- I think I need Glasses
- fixed hubs WHY?
- anybody had any luck running lead substitute
- 4.2 Diesel swap???
- Manual truck radiator in a auto 4runner?
- Odo Died... Speedo erratic
- Need help on flushing my cooling system.
- Anybody ever break a diff breather when removing?
- HELP!!! '86 XtraCab vacum line
- EFI relay COR relay? Last post before the shop
- Idler arm bushings
- Looking for 3rd gen EXTENDED CAB truck mods - PICS OF 3rd gen EX CABS PLS.
- bucket seats in a1988 reg cab
- 1988 3.0 fuel problems
- Will 88 4runner V6 Starter Work on 88 4runner 22-RE?
- front axle help
- engine not settling down (major loping).
- What Brand is good for Ball Joints
- will stock 4runner running boards fit on a pickup
- Long Travel Suspension
- Lack of power 3vz
- Broken Plastic Injector Cap On 3VZE
- Tach Troubles
- 1989 4runner AC dryer
- VAF help
- Anyone tried using hydrogen generators?
- exhaust problems..
- Are there bigger gas tanks?
- 87 4Runner rear axle bearings
- Knock Sensor
- Fuel Pump..no Fuel Filter..no Fuses..no
- 98 Fenders 92 truck
- 1991 3.0 engine noise
- 93' 22re guidance needed
- engine violently dies under hard braking?
- Calgary Pick 'N' Pull
- Clutch/Transmission Problems?
- Air Conditioning Help
- 87 with strange manual Tranny Problem
- anyone need a sfa close to vt craigslist find
- Heat in an '88 SR5...very slow to warm up
- Ball joint spacers and leaf spring question
- New in the yoda scene
- My wife is AWESOME.... Look what she bought me!!!!
- 91 3vze motor into 95 4runner, what do I have to change?
- it pulls hard to the left
- My Mechanic Screwed me on my 22RE-C Rebuilt Motor. HELP?
