only looking one front hub for 4wd, will you 3wd or only 2wd still
Old 05-05-2009, 05:06 PM
89whitetoyota's Avatar
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
me and and my dude where going up a big hill and he had trouble locking on eof his manual hubs, so he was wondering if you only locked one of the of the front hubs locked with you have 3wd will one front tire engaged and the other not or does it not matter unless both front hubs are locked?
Old 05-05-2009, 05:19 PM
abecedarian's Avatar
if the front is open diff, i.e. stock / not locked or not LSD, one wheel will slip regardless of whether the other wheel is locked or not.
and if the hub on that other wheel is or isn't locked it won't make a difference one way or another.
Old 05-05-2009, 05:22 PM
open diff won't make a difference if a wheel slips or not. if the hub is unlocked that's no difference than the wheel slipping. make sense?
Old 05-05-2009, 05:25 PM
toyota4x4907's Avatar
No 3wd. All the power will go to the side unlocked.
Old 05-05-2009, 05:33 PM
PETE_YK's Avatar
As stated above...because of the nature of a (open) differential the power will go to the wheel that spins the easiest which in your case is the one with the messed up hub.
Old 05-05-2009, 06:33 PM
Jay351's Avatar
You will be stuck in 2wd. Pete nailed it on the head.
Old 05-05-2009, 06:37 PM
Banned 'cause I was 4runnerchevy also banned
86toylet's Avatar
Wow !
Old 05-05-2009, 06:44 PM
maybe you should differentiate- 1 wheel up front and 1 wheel in the back = 2wd, right?
Old 05-05-2009, 06:53 PM
ok i get it. so you have to have them both locked or you get nothing up front. makes sense. dont hate on me im drunk
Old 05-05-2009, 06:58 PM
no, having them both locked doesn't mean much.
Say you're crossing a stream at a 45 angle and the front left loses traction and the right rear looses traction: that means you're not moving anywhere since 1/2 your torque goes to the front and 1/2 goes to the rear by default / by design. If the differentials are 'open' (front AND rear) the wheels that can spin will spin and you'll go nowhere. And given that case it won't matter if your front hubs are locked or not.
Make sense?
Old 05-05-2009, 07:00 PM
Staff
DeathCougar's Avatar
Originally Posted by 86toylet
Wow !
So you were born with the knowledge of how a diff works too, huh? Didn't ever have to learn anything?
Old 05-05-2009, 07:03 PM
Jay351's Avatar
no, 2wd as in rwd only.
With an unlocked front hub, all the power that is sent to the front end is gonna be sent to the unlocked wheel. Since it obviously spins with least resistance...
Old 05-05-2009, 07:08 PM
Justinlhc's Avatar
Yeah, AFAIK if you unlock a front hub on an open differential you will have -0- front wheel action since the unlocked axle will have the least resistance, getting the power but not being able to transfer it to the wheel.
oldirtydirt
02-23-2020 09:30 AM
deepmarsh
08-06-2015 03:44 AM
Steven.m.paulk
07-13-2015 01:40 PM
TokyoD23
07-12-2015 06:01 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: only looking one front hub for 4wd, will you 3wd or only 2wd still
