- Is there a DIY way to find the source of an oil leak?
- Newbie
- Very odd Misfire
- Hard start and code 11 think its cold start problem
- Update on Second Guess
- need help identifying these broken parts
- 87 4runner ZUK mod question
- Air Conditioning Retrofit
- Lindsay's Long Leg Seat Mod
- Help 3.0 not running after new plugs
- A fine new addition
- Different a/c hose sizes ?
- Need some advice about my 22RE
- After market dip stick
- Toyota IFS Knuckle seal HELP
- Has anyone used this vendor or parts
- fuel injector connector splice
- COR permanent "SAFE" fix
- inspection plate cover
- 22RE Intermittent CEL and Truck Surges During Acceleration
- Flooding in a 22re
- 1991 toyota 4runner 3.0L timing belt/new injectors/vale job,service
- 88 22re pickup turns off
- 3.4 Clutch on 1992 3.0 V6
- 88 pickup problems..
- 89 3VZ-E Rebuild/Shop manual
- 92 Rear gears whining
- 86 22r problems
- 16" wheels on a 1991 pickup
- 1st Gen 4Runner: Bad Brake Booster?
- LED headlight polarity issues, 93 Pickup
- 88 4Runner door panel clips
- need help with trans problem
- 86 pickup engine issue 22r
- Need Tips on changeing oil filter 1988 4X4
- 1995 4runner obd 1 code 22 and 24
- gearing question
- timing issue?
- 3VZE torque
- Blower motor works intermittently
- Water pump gasket question
- 22re overcharging? Hissing battery...
- 86-95 Top Ten Truck Problem List - GO!
- 87 temp guage/sensor
- 1986 Toyota 4x4 SR5 Fully Loaded With Options - Needs a little TLC
- Sloppy gear shifter on automatic 1988 22re
- Lift Ig-na-ray-moose
- 86 toyota pickup shutters when coasting
- Old Man Emu leaves matching front and rear height
- 86-95 Toyota truck frame.
- 87' toyota pickup w/22re (carbureted) motor
- 95' 4runner electrical problems, please help!
- code 51 probz
- Blown Head gasket ?
- R150F Transmission removal
- '87 efi 22re 4x4 idles fine in 4wd, but sputters/dies in 2wd at low/mid rpms
- rear window
- 91 pickup new door source?
- Bogging Down
- 22RE Headers Pros v Cons
- 1991 Pickup 3.0L SR5 o2 sensor
- 93 4runner ac doesnt blow
- oil pan
- 95 degrees outside, truck won't crank
- Got a tough one here -- Brake pedal movement
- Engine rattle
- Coolant temp gauge- Test light results...
- Shifting issue. Stick spins.
- 1991 V6 3VZE misfire issue + bed damage- worth fixing?
- Mass Air Sensor got mucked up
- 22RE P/S Pump Vacuum Line Routing With OEM AC?
- Aftermarket rims
- Anyone ever tried jeep flares?
- 86 4runner rear tires bouncing
- Gasket Maker on Valve Cover?
- idle and sputtering?
- 4runner shift lever diagram?
- Rough idle when driving with A/C on
- 22RE Cold Air Intake pros v cons Help
- low rough idling and wont stay running 3.0
- Just a tire Q
- Progressively often stalls during startup...
- 1988 4Runner Fuel Sending Unit repair/replace
- '94 2WD 22RE - Need help removing oil pan
- Shifting issues
- How's it work?
- 94 front turn signals
- Help diagnosing a problem
- 1994 pickup dlx 22re transmission coolant lines
- Need a New Engine 1992 Toyota pick up engine
- 95 4Runner steering and suspension
- 1994 3.0L 4Runner for sale
- Changed plugs, wires, diet cap/rotor . . . Now won't start
- exhaust issue
- 87 4runner 22re problems? HELP
- 84-89 Grille
- 1992 3.0 4WD smog trouble.
- 94 Pickup Charging Issues
- Rough idle warm start
- new engine 3vz-e install
- 1986 Toyota pickup 4x4 22re won't fire getting fuel fire stops at coil
- 1990 2 Door 4Runner
- A340H rebuild...anyone dared this one?
- Locking hubs (4x4?)
- Exhaust gurgle
- 87 Turbo Wiring Harness
- Distributor issues
- Ideas for rotted 95 4runner fenders
- What Is This!!
- Need help identifying a part and figuring out where a vacuum line should go.
- Some 22RE lessons learned (the hard way...)
- 87 4Runner idle problem at start up
- Can't break crankshaft bolt. Concerns about using a breaker bar against the frame.
- 94 pickup speedometer not working
- 4x4 not engaging
- 3rd member removal help
- HELP! Can someone help me Identify this part
- melted alternature fuse Box
- Passenger locking hub hard to tun
- 3VZE Timing Belt Skip
- Front Right brake locking up after driving
- Strange Shifting problem 1986 4x4 pickup
- 91 4runner timing issue
- New Engine 89 4runner SR5 "Bosses"?!?!?!
- misfire/injector swap problem
- code 52 and 51 please help
- Engine HELP!!!!!!***
- Replacing rusty fuel pump bracket - Can't under gas line connection.
- HELP! Brake rotor insanity!
- Where does this wire bolt to?
- Frame cracked in two , advice on repair?
- Have I busted the injector, or is the part useless?
- Misfire or normal engine behavior?
- 92 pickup won't pass emissions
- Leaking Intake Manifold Gaskets
- 93 4runner motor swap need help ASAP
- 93 Auto 4runner 3.0l has power but wont crank
- 92 3 Ltr Running Hot
- 87 4Runner 4x4 back glass wont go down...
- 1993 Pickup 4x4 carrier bearing
- 89 toyota pickup
- 22RE - Air/Fuel Mixture Screw on Throttle Body Turning Itself
- 3VZE Thread Chaser Question
- Soft top for the 86 RUNNER
- Anyone help please
- 98-04 All Pro Expedition Leafs on 1st Gen?
- Tie Rod Adjusting Sleeves
- 1991 toyota 4runner 3.0L brake help poor stoping
- I need the measurements of the ARB bumper turn signal cutouts
- can anybody help
- Motor went out on 86... now what!?!?
- electric fan in front of radiator how to test
- 22re rear oil leak.
- Anybody know?
- '89 Pickup owners manual (not repair manual) stolen
- Truck grinding
- Stuck removing EFI Fuel Delivery Pipe from 22RE ('87 4x4 PU)
- Need help on how to install injector spacer + o ring
- Air Conditioning idle/switch
- Tdc
- 5 spd tranny
- wore out alternator
- Bed compatibility between single cab and ex-cab
- Topped Orange coolant off with Green.
- Plastic Tube inside 22re Oil Pan... What is it?!?!
- Kinked fuel line/tube
- Questionable 1995 4Runner Purchase
- 22re timing chain slap?
- Just finished head job, now motor dies on acceleration.
- Replaced head gaskets, now power brakes don't work?
- AAP diaphragm ?
- First Order of Business: 87 Toyota
- which backspace rims
- 95 22re warm start idle drop then runs fine
- W56B rebuild question
- 91 pickup v6 4x4 no power
- How to keep water out of locking hubs?
- Manual to auto tranny swap
- Hit a deer yesterday morning...
- Weird intermittent noise from auto tranny area?
- 308K, worth while to replace the head gasket?
- Injector Swap Problem
- Fun places to find oil ( TB and spark plug hole)
- smoking...need help
- Minimum head dimension required for milling?
- Truck Stalling
- Vacuum line help.
- 22r leaking fuel bowl answered?
- 3.0 suspension swap to 2.4
- How long did your last 3VZ Headgasket last ?
- need help diagnosing driveline chatter
- Where to buy radiator
- 3vze last resort...
- 22re AC/idle problem
- no gauges working on 1988 4runner
- RV2 can install question
- 93 toy ifs with LSX question on tach
- 1990 auto transmission throwing 4 codes!??
- Oil in combustion chamber
- 22RTE, what's the thing worth?
- 22R intake coolant leak
- Strange noise in 4th gear
- Parts truck, good idea?
- power steering
- Fuel Injector Clips
- 95 SR5 V6 Engine Ticking with RPMs
- 22re Homemade EGR/PAIR Block Off Plates Clean Engine Bay
- axle
- Parking Brake
- Issues when cold
- Coolant leak, finally found the problem. Few questions.
- How do you recalibrate speedo in 92 V6 4Runner 4x4?
- Cant find part
- bad egr? how to test if egr is working or clogged
- Will start but wont idle
- Help me out here.
- Planning to do a motor/trans swap on my '88...need some advice
- Driveshaft/T-case bolt pattern problems
- Need Tips or Advice on Putting new Rubber and Bracket on Door Glass
- 4wheel drive not working
- Time to freshen up my rolled on paint job
- muffler noise...turns into clunking
- brake problem
- 91Toyota ifs 4wd light on in dash help
- 3VZE Knock Sensor connector, harness side...
- Best Circuit for Dual Battery Install
- Picked up a 91 4runner!
- will these wheels work on my truck?
- SR5 Gauge Cluster Calibration Picture
- steering gear box help!
- 1993 4wd front rotor removal
- 1993 Toyota 22RE ticking after valve adjustment
- 93 22re Start then Stop
- Running lights wont turn off!!
- Starter Issues
- help, broken head bolt
- 1993 Factory Service Manual single PDF file complete with navigation
- Which 02 sensor do I need.
- Can't find new fuel sending unit
- 94 22re speedometer not working.
- Need help with clutch problem?!
- mysteriuous oil leak from transfer case
- 94 toyota pickup v6 runs great then fuel pressure drops off
- Are the shift knobs screwed on or pressed on?
- Fuel Rail Bolts Snapped!!!
- 87 4 x 4 22re balancer bolt dimensions please
- Slow starter?
- 89 hilux
- 90 4runner power windows, wipers and gauges not working
