can anybody help
Old May 25, 2015 | 10:05 AM
tham1992's Avatar
can anybody help
I got a 91 Toyota pickup and just put a motor in it went to start and was leaking gas fixed that went to start it the next day and it caught on fire melted the wiring harness is all it did does anyone know where I can find a wiring harness its got the 22re motor and I just need the engine wiring harness
Old May 25, 2015 | 11:12 AM
thook's Avatar
Ouch. Yeah, google Nix99 in WA state. They may have one.
Also, get a fire extinguisher at Lowes or some such place. I had slight fire at my alternator years ago and have kept one in the vehicle since.
Old May 25, 2015 | 11:37 AM
skypilot's Avatar
Ebay is another choice.
Old May 25, 2015 | 02:26 PM
osv's Avatar
osv
junkyard
Old May 25, 2015 | 07:36 PM
Terrys87's Avatar
I know from 85-89 there is at least one change in every harness. Going by history, I would say you are going to need a 91. Engine harnes is vague. You have the Main Harness across the dash, Injector Harness is probably the one you are needing. There is also the Headlight Harness and the Fuel Pump/Tail Light harness.
Amen on the fire extinguisher, so cheap and easy to use. Learn the different classes of fire as well. Your local fire department will be glad to explain to you what they are and proper way to use a fire extinguisher. Good to have a few in the house and shop as well.
