PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 [235] 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Water Leak help!!
  2. what should I do?
  3. 22RE Output Shaft Question
  4. running boards off
  5. Need EFI help!!!
  6. Pulled out two stuck trucks today!!
  7. 1986 4runner help me please
  8. Bilstein Shock Question
  9. both lowbeam headlights go out? try this first.
  10. Any auto transmission mods out there?
  11. rear window antenna
  12. Do I need longer shocks???
  13. Who has the best lift prices? Looking for superlift K743
  14. need help with a part for 86 runner
  15. faint oil light on new truck
  16. 4Runner Engine Swap Finally DONE!!!!
  17. 2nd Gen 4runner REAR Addco swaybar pics?
  18. 1986 4runner questions...why no mods?
  19. Quick question: jiggler orientation on thermostat install?
  20. off the trails in the shop
  21. air flowmeter
  22. 3.0 liter automatic transmission shifting problems.
  23. rear bumper bent...easily fixed?
  24. Canadian online stores?
  25. Rear Axel Seals
  26. 92 2wd w/ 94 sr5 cluster - tach issues
  27. Pressure relief valve?
  28. 22-re getting hot at idle and during stop and go
  29. Overheating Help!
  30. MSD ignition stuff for the 3.0????
  31. suspension question
  32. Thermostat testing
  33. Best parts sites and stores
  34. manual hubs
  35. Advandages of a dual steering stab. over a single
  36. 4x4 binding on right hard turn
  37. Top off..... uh oh
  38. E-Locker to Cable Install & Question
  39. Airflow Meter Help
  40. CV's, the good the bad, ect...
  41. 1995 HILUX 22RE DESTRUCTION (sad)
  42. 3.4 swap parts questions
  43. 88' v6 too much fuel!!!
  44. Truck dies when I push on the Brakes
  45. Are you asking too much of the 3.0?
  46. head gasket ? and ive searched but still have ?
  47. 86 toy options
  48. 89-95 truck door swap?
  49. '86 Turbo SR5 Automatic w/Overdrive
  50. Clutch shudder
  51. Electric Fan Thermostat??
  52. Need pics of BJ spacers and Braided brake lines on first gens
  53. Weird coolant temp problem
  54. Want to change instrument cluster
  55. Panel protection
  56. Trail Master Vs Tuff Country
  57. lucas as a gear oil additive
  58. cost for muffler & header install
  59. 22RTE Broken Timing chain
  60. Jet computer program
  61. 3VZE Does the Coil have a Ballast Resistor?
  62. custom bumpstops?
  63. Where can I find parts fichies or schamatics for a rear axle?
  64. Transmission Shifting Help! - 3.0 to 3.4 Swap Question...
  65. v6 carrier compatible in 4 cyl third member?
  66. TPS Setting
  67. Autozone CV Axle
  68. Will this work?? 2wd fender
  69. Removing rear window
  70. strange O/D issue
  71. Clutch not disengaging
  72. Functional flatbed
  73. Price check help please......crankshaft regrind?
  74. Rear Brakes lock just before stop
  75. Swapping hubs question. I'm an idiot.
  76. My exhaust symptoms Blown headgasket or condensation
  77. 1st gen rear seat belts
  78. Intro and which stock rim for 33" x 10.5 tire
  79. 80 series LC wheels on 1st Gen Pickup
  80. rear coils or coil spacers?
  81. Took the top off the 4runner today
  82. 95 4Runner auto transmission ?
  83. Speakers...
  84. replacing windshield
  85. Front axle pinion shaft seal
  86. 3.0 Leak Help
  87. 22RTE: Finally wants to start...but won't
  88. timing chain cover gaskets
  89. 93 deluxe or 97 tacoma?
  90. taco buckets in an 89 pickup
  91. Toyota parts by Military APO shipping to Afghanistan
  92. 3VZE Rebuild Questions
  93. Today it's the O2 sensor
  94. a Question of Gas Mileage
  95. ...In-cab Fuse Panel...
  96. Sub+65mph=top Off
  97. brake system questions
  98. how can i tell if my t-bars are crancked
  99. snow plow for 88 2WD Toyota pickup
  100. 22re break in time
  101. 80 AMP Fuse
  102. 3.0 wont start
  103. Inertia Switch?
  104. FUEL pump. Location?
  105. Inertia Switch?
  106. Overdrive off question?
  107. knock sensor problems searched and cant find
  108. sitting stock, pics?
  109. Need help...shackle touching exhaust
  110. Question about Coil Resistance -Ohms
  111. Engine Problems
  112. ABS Speed Sensor question
  113. steering stabilizer Part # 90 4runner
  114. Can you ID this?
  115. I need help!!!!
  116. new member with questions
  117. My truck is leaning off to the right
  118. Stuck torsion bar adjustment on 91 Pickup
  119. 93 toyota 4runner 3.0 engine replacement
  120. TuffCountry Lift
  121. 86 4Runner Issue
  122. looking to get 2.5inches of lift in the back for freeish?
  123. Need Help
  124. must i say toyota of seattle winners....
  125. My 86' $runner
  126. Sqotd
  127. My 1'st gen 4runner
  128. HELP! 22RE dies with AC or in reverse
  129. Name this part! And where to buy it...
  130. ADD Relay
  131. 4Runner seat question
  132. 33's and a '91 Runner Auto... Gears?????
  133. Acess so I can remove the shifter?
  134. Is this the alternator
  135. How do I remove the front map light?
  136. sweet graphics!!
  137. Cheap IFS Lift Kit???
  138. do you rotate off road tires
  139. Those who have pulled a 3VZE -
  140. 22re feels weak, hesitation under load I'm lost!
  141. Horn Relay Location
  142. Power Antenna + Tree Branch = Jacked up
  143. Seat swapping??
  144. aux heat gauge
  145. recommendations for shocks?
  146. Hoist for roof removal ???
  147. Tacoma Axle Under '91 Pickup Questions
  148. Rear Sway Bar for 1st Gen 4runner?
  149. Exhaust manifold install help
  150. Wheels...
  151. Tires = MPG, MPH, HP?
  152. 22re, Will Not Start. Help Please!
  153. valve cover leak/buildup?
  154. Ethanol
  155. 4wd sway bars on 2wd?
  156. Manaul locking hubs....why and how
  157. how tall would it be after??
  158. a/c question.....
  159. Whats wrong with ES 9000's?
  160. Questions for those who have retrofitted A/C on a 22R
  161. looky looky
  162. YotaTech Newbie w/ Temperature Guage Problems... Read * Please help :D
  163. 3.4 obtained, help me gather knowledge?
  164. 86 Runner Stock suspension>>35 inch tires
  165. Odd whistle when pushing in clutch
  166. why dont i have this!!!
  167. Temp too cool?
  168. axles
  169. 94 4runner Factory Alarm
  170. oil leaking out of driver's rear tire
  171. deadly sound!
  172. different gearing in the same truck
  173. hard to start 22r
  174. NO BRAKES!!!!! Brake problem
  175. help with shock lengths and canadian offroad stores
  176. I want new rims
  177. People who have had someone re-gear your diffs...
  178. PIC request: 2nd Gen 4Runner tail gate latch
  179. Differential compatability
  180. Low Pro Bumpstops question
  181. 2 inch suspension lift. Somthing needs to be done!
  182. Does any one make Diamond Plate or metal Door Panels?
  183. Where do you buy your Aftermarket parts?
  184. fuel gauge
  185. After headgasket no fuel!
  186. What is this?
  187. windshield wiper problem HELP!
  188. 1st Gen Opinions
  189. New Motor
  190. Why did Toyota cheese out on 2nd gen beds
  191. Front Lift options
  192. Oil Pressure Gauge Question?
  193. Emissions Failure at Idle
  194. glowing exhaust need help
  195. 3.4 swap model years for donor
  196. What's the difference between a 4cyl and 6cyl rear diff?
  197. Pick-n-Pull parts
  198. 22R EFI Swap Idling High
  199. Alternator Squeal
  200. Exhaust systems for 22re pickup
  201. 2 pinion 4 pinion rear difference?
  202. Super SLOW in Colorado!
  203. 2nd gen 4R rocker panel rust repair thread
  204. new to truck maintance
  205. Rear window Won't go down - Motor Hums
  206. Body lift shifter question
  207. name change
  208. Fuseable links - School me
  209. I had a rough ride
  210. 22RE Air By-pass thingy
  211. Spark Plugs
  212. Install Warn Manual Locking Hubs, 91 4Runner SR5, Auto Tran
  213. No heater fan
  214. Crazy Temp Problem (very crazy)
  215. 3.4 swap donor
  216. New to a manual trans
  217. 1993 fuel pump question
  218. Motorcrate.com 22re Remans: Any Feedback?
  219. automatic tranny drop
  220. Need Some Turbo Help
  221. 4runner tailgate
  222. Tune up, uh oh?
  223. Front end help please
  224. drivetrain/powerplant swap
  225. black tail lights!
  226. OME901/Rancho RS5009 review (pics)
  227. BJ Spacer HELP
  228. 22RE Gas Milage
  229. man gets butt whipped by exh manifold
  230. 22RE Power
  231. shackle pricing and time?
  232. 60" Yakima tracks on a 2nd gen 4Runner
  233. cover on back of motor
  234. bodylift steering shaft/firewall grommet q?
  235. Hard Top Options
  236. oil pressure sender
  237. 22re Engine Options
  238. Picture gallery??
  239. AC question in 1988 Toyota pick-up
  240. Front Diff. Question
  241. 91 3VZE Motor in a 94 4runner
  242. New truck, no jack..
  243. truck wont run--video of it
  244. 95 4Runner Knock Sensor Help
  245. Can someone check this for me
  246. EGR Block Off Plates! Uhh...
  247. Dirty South Off-Road
  248. What should I do with the rear?
  249. Will 03 4 runner buckets fit my 88 pickup?
  250. Too much tranny fluid
