new member with questions
Old Mar 14, 2007 | 01:59 PM
toyota3x4's Avatar
i bought my truck a few months ago its a 94 pickup ex. cab. 4x4 v6
i have always noticed that the front is a little lower than the rear
yesterday i measured the front an one side was 14'' from the top of the rim to the fender an the other side was 13.5''
i did some research an stock i guess there sopposed to be 15''
so today i busted out the torque wrench to tighten the torsion bar bolts down, i didnt have any extra bolts an i read it was a good idea to so i was just going to be carefull
first i loosend them a bit then tightened them down pritty good, but on one side the top bolt moves with the bottom one
so now do i need to get new bolts or is there a way to fix this, an if do need to get new ones what are they called
im planning on getting bj spacers and new torsion bars in the near future
money is pretty short because i allready blew a head gasket on the 3.0 an had to have the heads replaced -3500$
thanks for any info
Old Mar 14, 2007 | 02:02 PM
TNRabbit's Avatar
thanks for any info
Damn man! You can get an entire engine INSTALLED for that....!!
You just need to oil the bolts up good with PB Blaster ($2 at walmart) or equivalent about a day before you're going to work on them. Put a wrench on the top bolt to hold in place. Just don't go up too high or you'll put additional stress on the CV joints. I find about halfway between the upper & lower bump stops works well.
Old Mar 14, 2007 | 05:20 PM
dijlop's Avatar
yea. never had to do anything with the head gaskets, but $3500 sounds pretty insane. i would suggest just buying a new truck. lol. figure out something, and dont spend that much to replace a head gasket. good luck.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
