Manaul locking hubs....why and how
Hey guys, I keep reading about people recommending a conversion to manual locking hubs. What are the advantages/disadvantages of this and how could I find out about the conversion?
thanks
mike
thanks
mike
It is only a matter of wear, you will see no mileage benefit. If you lift your truck and put your CVs at an angle, get some manual hubs. Also if your truck has auto hubs (not ADD) you should replace them since they don't really work.
Here's some other links on the subject that might help you out:
https://www.yotatech.com/forums/show...ght=aisin+hubs
So, I'm assuming the whole CV reason won't apply to me. It also sounds like the fuel consumption advantages will be negligible. Guess I'll just keep my auto-lockers.
BTW, what is ADD? I found that reference in several threads, but no one indicated what it is.
thanks!
i wouldn't necessarily say that you won't notice a difference in gas mileage, as i gained almost 2mpg. it could just be one of the luck of the draw things, but i'm really glad i installed them. its really easy too.
My mileage increased between 1 and 2 mpg, and I noticed a SIGNIFICANT decrease in effort and better steering feel (lighter, more nimble). Well worth the $60 for two Aisins and 4 hours it took (tore down hubs & regreased); otherwise, your CV shafts are always turning. PLus, they look WAY cooler!
I noticed the easier turning as well and I never split a boot again after doing mine. My front end was stock but they still do wear on the boots when you turn and they are turning. Make sure if you install them you lock them and drive for a ways every couple of months to keep everything up front lubricated and in good working order.
Take a look at
http://www.off-road.com/toyota/tech/aisin/
for everything you need to know about the different versions of the hub.
This thread has a good writeup with part numbers -
https://www.yotatech.com/~corey/tech...etal22lica.htm
The FSM pages online at
http://personal.utulsa.edu/~nathan-b...14freewhee.pdf
have the exploded view of the hubs.
They are easy to rebuild. The only part I found a bit confusing was that the "spring" actually threads into the "follower pawl", kind of like screwing in a bolt. I can't think of a good way to explain in words what is obvious once you have the parts in hand. If you don't assemble it correctly the hubs won't disengage.
These hubs come up on eBay all the time. Try to get hubs from the southwestern part of the USA as they are less likely to be all rusty and corroded.
If you get a set and end up needing some parts, I have some left over. I got three hubs and rebuilt two good ones out of them. PM me if you need anything. I'll take a look at what I have and see if I can help you.
PNW94Runner
Sep 29, 2015 02:55 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
