hard to start 22r
Old Mar 12, 2007 | 04:25 PM
tssievert's Avatar
hard to start 22r
i pump it then crank crank crank crank crank crank, then it starts and runs fine, it only does it after it sits for a couple of hours. it does it when it is 20 outside or when it it 80. is there some kind of check valve in the fuel pump thats letting gas drain back to the tank?
also, how long would it take to change the rear main seal on a 2wd truck?
thanks in advance
troy
Old Mar 12, 2007 | 04:28 PM
paxil4x4's Avatar
Drama Queen/Banned
There is still going to be fuel in the carb bowl, so it's not a drain back issue
Old Mar 12, 2007 | 09:36 PM
notanymore's Avatar
not quite the same thing, but my 22re was hard to start and when i changed the plugs it started easier, just a thought
Old Mar 12, 2007 | 09:47 PM
91muddog's Avatar
possible clogged cold start injector?
Old Mar 13, 2007 | 02:07 PM
notanymore's Avatar
on the carb there wouldnt be a cold start injector. right? it would be the choke. so that would be another thing to check
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
