PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 [191] 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Pre-runner toyota: IFS A arms
  2. New HG, still eating water. Cracked head?
  3. lighting mounting
  4. 3.0 not turning over... HELP
  5. Anyone else seen a 1990 4runner 2 door????
  6. 4Runner Stock Lift Rear Leafs
  7. removing bed
  8. AC belt replacement
  9. Flat bad conversion
  10. rut-roh, compression low on fo
  11. engine upgrades ?
  12. I need input considering a 93 4runner
  13. code 51
  14. 22RE Performance upgrades
  15. Help?! My truck has demons!
  16. Rear suspension
  17. Napa clutch MC and slave
  18. blown oil pressure gauge.....
  19. ahh stupid spark plugs!
  20. 3vze swap with 3.4L... is it worth it for what happened
  21. What adhesive for ADD vacuum lines
  22. So I was a little bored today...
  23. gas leak front of frame??
  24. Downey Header install issues on 3.0
  25. rear window motor + regulator needed
  26. What type of grease for Ball Joints
  27. Lubricating everything
  28. Broken 4wheel drive?
  29. Throttle Body Vaccum Leak
  30. How do you tell your CV Axles are shot?
  31. BAZ Truck has been Recycled
  32. Catching truck in gear?!?
  33. tell me about the 3.0
  34. 3rd 4runner drivetrain in 2nd gen runner?
  35. i busted my IFS
  36. blacking out wheels on 95 4runner
  37. Going back to stock airbox
  38. bent or broken valves on 3VZE 95 4runner
  39. Clutch Help
  40. No power above 4500RPM
  41. 94 2wd Automatic trasmission part number
  42. pickle fork for removing steering stabilizer
  43. 1884 4runner noise??
  44. Suspension Question
  45. Interior rear panels
  46. Rear Glass installation for 88 pickup
  47. DIY Rear suspension
  48. driveshaft install?
  49. Proper Break In???
  50. good deal
  51. Best Place for New Balljoints?
  52. Yellow radio wire problem
  53. Cargo Net
  54. I am looking for....
  55. '89 runner manual
  56. 22re rebuild problems need help
  57. Bikini Top
  58. i just found out,,,,,, why dont yotatech have a myspace?
  59. Need Help
  60. Locker Q front/rear
  61. whats the biggest i can go
  62. pics of 3 vze engines
  63. are auto ye or ne for rock crawling?
  64. Grounding to block necessary??? Help Please!
  65. Power Steering Help
  66. pickup roll bar
  67. what lift for 35īs
  68. Rattling Noise while turning .....Axle, Cv Joint Help !!!
  69. 3VZE Vacuum diagram. does anybody have it
  70. aussie lockers?
  71. 1992 4 runner over heating help
  72. Anoyying rattlig noise.
  73. First gen seat belts for the back seat...
  74. Issue Going Between Park and Gear
  75. Clinometer Installation Help
  76. Saggy Ass End
  77. New Swampers!
  78. Grinding noise upon deceleration...
  79. 3k rpm sputter
  80. Does/did Suzuki use the same aisin locking hubs
  81. anyone else running an mpguino?
  82. Need Help!!! Please.
  83. Bad Stuff Happens
  84. I need engine help
  85. 3.0 auto, 22re 5 speed swap.
  86. Are there any major diiferences between a 91 and 94 4runner
  87. new major oil leak
  88. Before and After Pictures
  89. what year 22r ??????
  90. Rear U-Bolt Thread pitch and pattern
  91. Addition to 4crawler starter fix.....
  92. crazy smoke, little fluid loss
  93. AFM issue?
  94. solid front brake lines; is there a better way?
  95. 22RE siezed up
  96. for those of you who had your engine rebuilt
  97. 22re Ceramic clutch installed
  98. Pings when I shift
  99. 88 4runer in need of driver's side rocker panel
  100. auto trans to manual trans???
  101. having electrical problems
  102. Brand new 92 Hilux Surf
  103. Starting Problem/ Hot or cold??
  104. Wheel Bearings or bad front chunk?
  105. pics of trail gear SAS
  106. To hone or not to hone....
  107. 94 4runner underpowered anybody got any ideas??
  108. high lift on ebay?
  109. checkengine light? abs light? back door light?
  110. Newbie Help
  111. Is it a good deal?
  112. Steering linkage problem
  113. 7.5 front diff dis-assembly
  114. installing tailgate window, channels? 90 runner
  115. quick fender question.
  116. Fuel Pump Problem?
  117. Sputtering engine at high speeds. Any ideas?
  118. Blowing fuses with taillights...
  119. steel wheel lugnuts
  120. O2 Sensor Failure Help
  121. 1989 Toyota Dually COMPLETED (pics)
  122. pooched and STUCK zerk .... hep me hep me !!
  123. Help me out...what's wrong now?
  124. Installed my new springs, but have a few questions.
  125. Throttle Body Replacement ?.
  126. Problems with reverse and idle
  127. okay, I think someone owes me a crank
  128. is this going to be a problem? Intake 22re
  129. rough idle????
  130. 3vze alternator upgrade
  131. Hand Brake Help!
  132. Help me I.D. this part by watching this You Tube Video
  133. T100 CV shafts?
  134. Should I get a new engine or just the head?
  135. Rear Window replacement - help needed
  136. Does anyone Recommend this write up for Code 71
  137. Gear To Tire question
  138. Lift Springs??
  139. EMERGENCY my 94 4runner just went screwy
  140. 1991 toyota 3.0 330,000 miles, what to do?
  141. 90 pickup shifter problems
  142. 90 22re possible bad piston ring or H/G
  143. Here's what I have to show after a summer of tinkering
  144. Rear pinion seal size
  145. 3VZE head gasket symptoms?
  146. Throttle Body Spacer
  147. detroit locker question
  148. Is my thinkin' stinkin'?
  149. Antilock brake sensor location
  150. 84-88 Rear Heater fan switch; used for lights?
  151. 3.0 and the 3.4
  152. 87 4Rnr - rear window won't roll up? where to start?
  153. fitting subs into a reg cab?
  154. Any good junkyards in tacoma, washington area?
  155. Stuttering Acceleration??
  156. Replacing the Rear Wheel Bearings
  157. 85 window helppp
  158. 1993 4x4 pickup steering issues
  159. need kit for SAS?
  160. driveline removal/installation tip
  161. TC's 2nd Gen - Rear 4Link Swap (Buildup Thread)
  162. New Brake Line, Too tight of Clearance?
  163. Water in oil?????
  164. a question on reliabilty
  165. Busted out back window - and side window
  166. Will a set of 3rd gen rear coils fit a 2nd gen?
  167. No 1 air hose
  168. Brake Warning Light
  169. A/T oil temp, Battery, Brake lights all came on?!
  170. mounting 87 22r block to a 94 5 speed
  171. intake difference...
  172. First Valve Job/Timing Chain
  173. MC bumper pics.
  174. Coolant Leak
  175. New Exhaust: O2 Sensor Flange Mount or Thread?
  176. An auto to manual question...
  177. backspacing
  178. Who has removed their carpet?
  179. Help a brotha out!
  180. Want to DIY fix my A/C
  181. 89 3VZE igniter/efi relay problem/question
  182. Engine leaking oil
  183. 4" Backspacing ok?
  184. Seafoam>Where and how to add to our trucks
  185. Replacing Clutch '95 4Runner - Questions & Pics
  186. is my radiator the problem
  187. 3row alluminuim radiators
  188. 22re Rebuild Complete
  189. 3.0 5spd owners
  190. Leaking Gas?
  191. seat of my pants......PLEASE HELP
  192. 3 1/2 hours of hell
  193. 10 bucks to whoever
  194. My dilemma...
  195. Cranking Torsion Bars
  196. 2nd gen factory roof rack location dimensions
  197. Oil Pan Gasket/Rear Main
  198. Just replaced knock sensor and now truck wont start PLZ Help
  199. RE-torqe new head gasket?
  200. Front Bump Stop HELP
  201. TVV valve?
  202. Transmission woes?
  203. Cobra 29 ceiling mount?
  204. AC Compressor Temperature
  205. RUST- its a killer
  206. 4x4 not working
  207. New wheels
  208. Suspension
  209. Webpages?
  210. My 4Runner Lift Plan
  211. What are all the parts included in the 4in bracket lifts?
  212. MC Rear Bumprer and ?" Drop Ball Mount
  213. What do you guys think of this wheel/tire combo?
  214. WTF!!!!!!! AC Retrofit
  215. grinding into reverse
  216. 1992 toyota pickup
  217. Brake problems
  218. headlights for 87 4Runner, OEM or aftermarket?
  219. Just got my front gears!
  220. changing rear brakes
  221. Idle for a modded 22re
  222. speedometer
  223. Set of 16" sport wheels on 94 4runner
  224. Losing Clutch Fluid
  225. Locking storage - 1st gen 4runner
  226. Power steering pump squealing and burning
  227. New Driveshaft Problems
  228. Major gear box problem...
  229. replacing windshield trim
  230. Time for a new engine.
  231. '90 4runner only worked in 4wd low?!!?
  232. some pics
  233. manual hubs
  234. Idle for V6 4runner
  235. vacuum troubles?
  236. v6 3.0L 3vz
  237. 1988 3.0 4runner won't start need some help
  238. Smell of gas with no sign of leak...
  239. Started tinting my windows today!
  240. Unknown Brakeline
  241. Replaced clutch now it won't release
  242. Important Question About Knock Sensor Wire
  243. Add a Leaf for 4Runner
  244. help!
  245. New Project Suggestions
  246. 3 yotas at pick n pull wadsworth ill
  247. lower ball joint replacement
  248. 1st post- Here goes...
  249. NOT MY TRUCK but this thing is BAD a**
  250. What's a good number
