3VZE head gasket symptoms?
Old Jul 28, 2008 | 10:37 AM
JohnStra's Avatar
My truck starts really rough at least 50% of the time. Sounds like it's hitting on 4 cylinders. I can kill it and restart with some throttle and it'll be fine. If I just let it run it'll idle rough like that for quite a while before it clears. Once it clears it it'll run fine. No smoke, no white exhaust, coolant level doesn't appear to be dropping.
Does this sound like a HG or something else?
Other than the rough starts, the truck runs strong. Good fuel ecomony, etc.
Thanks,
-john
Old Jul 28, 2008 | 06:13 PM
Targetnut's Avatar
If the head gasket were leaking enough to cause a rough idle on start up, it would be loosing coolant. And really it should be running hot as well. because combustion gases would be aeriating the coolant.
It might be loading up with too much fuel. This can also be due to not enough air. like if the auxillary air valve is not opening. How fast does it idle when it is cold? (after you clear it out)
Old Jul 28, 2008 | 06:42 PM
JohnStra's Avatar
idles about 1000 cold. I found references to the aux air valve in a few other threads. I'll check that out? Anything else to look at?
Btw... before I got worried about the HG, I was thinking too much fuel. What about a bad injector?
Thanks!
-john
kgcwb44
Jan 29, 2023 10:02 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Coreyr384
Jul 10, 2015 11:13 AM
