- 3vze throttle body
- My truck weight 1993 22re xtracab 4x4
- Trade my '93 SR5 gauge cluster w/tach for your base level cluster w/o tach
- Will a Jeep winch bumper fit ??
- Fuel
- Killed my runner off roading
- Ngk spark plug wires keep on ripping 22re
- 22re pvc valve defective
- 95 4runner misfire
- brake proportioner?
- Trouble code: 31 - Air Flow Meter signal (Vacuum Sensor signal)
- 1991 4runner gauge cluster issues
- 1990 Toyota pickup 22r Slight tick
- Need rear sway bar links
- 2nd gen runner instrument cluster bulb replacment part numbers?
- 2nd gen 4runner 2 door 1/4 panels?
- cold start time switch
- 1991 pickup cruise control
- problem with locking hubs
- 93 3.0 issues.
- Knock sensor (22RE): a spare one anyone?
- My afm broke cause of myself
- Anyone in Colorado have a 22re for sale
- 94 Pickup - What are these wires?
- 86 Pickup Brake Master Cylinder: Which manufacturer?!
- 88 4 Runner 22re Injector pulse
- 1987 Toyota pickup 22r idle problem
- Bogging When Accelerating
- So I messed up again....
- Electrical Gremlin - Need Some Help
- Backup Lights 1990 Toyota Pickup Automatic
- Is this the ugliest wiper blade known to man?
- help need to identify brake upgrade to my 86'
- Back to the Future build
- 94 Toyota 4runner 3.0 HELP
- 90 4Runner standard w/3VZE climate power control issue
- Low/Pulsating Pedal/Weak Rear Brakes -1993 Surf
- 1986 toyota truck 2.4 fuse box cover pics
- 1994 Ignition coil/Igniter
- 89 removable top
- Quick rebuild question.
- Widening the Track Width on a 95 pickup
- Rebuild possible?
- What's going to be more reliable/inexpensive
- Stock speaker sizes 1993 SR5
- Weber Carb Gasket issues.. please help!!!!
- 4Runner 3vze doesn't run right
- Question about toyota rv t case
- 1988 Toyota pickup 4x4 3.0 distributor help
- Mounting roof rails to a 2nd gen
- 3.0 no power after installing new heads
- 88 4x4 truck pulling hard left on steering (*sometimes)
- ARP head studs worth it?
- Rattle from 2500 - 3000 RPM?
- Back windows
- Tune-up parts
- 94 pickup 3.0 3vze: ecu or gauge cluster or ???
- Abs actuator leaking power steering fluid.
- Please help me understand how my truck still runs (COR related)
- 3vze no start. Getting Fuel/Spark. Tested multiple sensors. Completely lost
- Interior dome light replacement??
- Changing linkage on my 1992 Toyota 4runner
- factory winch option
- My journey into a 22RE
- 3vz head gasket rebuild - cranks but wont turn over!
- TPS concern. Need help. Holding up fresh rebuild.
- Squaling sound in clutch
- 3VZE throttle body electrical connector
- 92 help
- 91 Pickup 22RE - still won't start sometimes
- Sometimes Long crank time when 22re is warm
- Throttle Body Port R
- Need help with windshield molding
- 4runner utility lamp
- 89 5sp 4x4 PU clutch “slips”
- Factory rod bearing or no?
- Lift help
- Do rebuilt 22res last as long?
- Using the crank from a truck with more miles?
- 95 Runner stuck in low on cold start
- Fender needed
- 95 3vze running rich when smogged
- Back windows
- Fender flares for 93 pickup
- Side mirrors?
- 89-95 Pickup driveshaft lengths
- 22re fusible link replacement/or delete?
- 95 pickup rear shock removal
- 86 4runner overheating issue
- 22RE Pinging Getting Worse!
- Toyotas in Jordan - This is Toyota love
- hub making a clicking noise ?
- Ventilation broken thing
- Help! Gauge cluster paper
- Missing Bolt on Vehicle Speed Sensor, part number 83181-24070
- Newbie stock 90 pickup
- Part number 180 OEM Toyota thermostat 22re
- Brakes are touchy!!!!
- Fan Pulley (False Water Pump) Replacement
- Tie rod question
- Hard Shake in 4x4 High
- 86 running few seconds and dies
- 1989 Pickup with 3VZE
- Newbie with a question about 1991 pickup
- chasing idle after TPS
- Leaking oil pan
- Cooling system hoses 3vz
- Suspension upgrade questions 1st gen 4runner
- 92 Toyota 4x4 truck v6 3vze ; 4x4 indication light on dash comes on while driving
- My truck doesn't have springs
- 95 4runner no spark.
- Redline engine builders
- Too nice to junk, Help!
- 22re Water Pump
- 1991 toyota pickup acts like not taking fuel
- Brake light switch question
- Pulling distributor, TDC vs rotor location
- 26 PSI for stock 4Runner front tires
- 22re idles low (500) on warm starts
- 2nd gen Nerf bars
- Did I get a bad part? Power Steering Gear Box - Pressure Line Fittings
- Transmission Front Seal Replacement
- Replacing 4x4 Locking Hubs
- Narrowing Down Fuel Issue no start- 91 3vze
- Diff ratios
- 86 4runner steering coupler rag joint puzzle solved!
- 90 Toyota Deluxe Pickup 22RE
- Erratic idle.
- 1990 Toyota pickup 4 speed manual transmission oil capacity?
- Compression Test Question
- do I just pry off the wireing connection to the MAF sensor to remove it for cleaning?
- 1st gen SR5 seat slides?
- 77 pickup parking brake cable
- tps replacment question
- Mud flaps
- 90 4Runner unknown vibration while driving
- head lights low beam will not turn on
- Brake handle assembly replacement
- '91 Pickup 22RE sometimes won't start - no crank at all
- Starter works but engine won't turn over!
- 93 Toyota Pickup Dlx 22RE 2.4 L - Mass Air Flow Sensor Replacement
- Rebuilt 3vze, have to hold gas to keep running
- Wiring help 91 Toyota v6 Auto trans
- Should I run regular unleaded when setting the timing?
- 4runner problem
- Hit a bump and truck shutdown
- Rebuild kit
- 88 4runner electric window switch problems
- Removed what should have not! (transmission)
- cruise and intermitent wiper help
- Oil in Bellhousing and throw-out fork boot
- Difference between a MPI AND AISAN motor?
- Alternator, digital dash woe
- quick and dry on replacing a pitman arm
- Rear diff leak / which gasket to use?
- Have I mentioned how much I hat rust? **Shock mount gone**
- Crankshaft Bolt Removal
- Ok, exactly what parts do I need to buy for wheel bearings?
- 1987 Pickup - 22r - Stalls when pulling away
- Need help - 92 truck 3vze 4x4 -specific cold start issues
- 94 pickup 4x4 3vze burning igniters up problem
- Coolant leak somewhere towards the back of the engine
- 2nd gen roof off
- replacement alternators
- Trucks giving me a headache!!!
- 8 Amp parasitic draw, and part identification help
- Correct location for EFI emblem on tailgate?
- Rust in High Humidity
- '88 4runner - has a few issues
- Hilux vs Pickup vs 4Runner generations
- Help me diagnose this noise
- Question about steering shaft?
- 92 3VZE Head gasket woes
- 22R air intake bolt bolt snapped and so did the easy out, any suggestions?
- ITM parts
- Check engine light 92 pickup 4x4
- help with brake lights/turn signals back feeding into each other.
- Code 52 (Knock Sensor) diagnosing questions
- What the hell? (Crank, no start 22RE)
- 86 22rtec oxygen sensor help
- 22re turbo kit
- 93 Toyota pickup 4x4 3.0L w/ 300k miles
- Diagnosing this temperature related idle issue. And AC idle up...
- Help Something shorted out when I was jumping another vehicle,no power anywhere now
- Hilux/hiace transmission info needed
- Starter Intermitently Not Working (Solution Found, wondering if it's damaging)
- Gear Grinds 1st to 2nd Gear
- 1987 4runner Strange Tach Problem
- 94 4 runner 3vze issues
- r12 compresor oil
- Bleeding clutch system
- wornout clutch? 1988 RWD pickup, 421K
- Cup Holder Removal
- Random idle and poor fuel milage 1990 toyota 4 runner with a 22RE
- Moulding, drip for roof and topper
- EGR system disgnosis
- Air Fuel Ratio Gauge and test drives
- Mysterious misfire
- Transmission drop & front differential
- Leak questions
- No idle-up when starting cold engine
- 1995 3.0 - Bad Fuel Pressure Regulator?
- Engine Vibration at 3k RPM
- 86 22RTE exhaust manifold replacement...help
- Odd noise from alternator or water pump
- Bilstein 4600 vs 5100 for 2-3 inch lift?
- Rear window latch?
- Weak spark at ignition coil after changing Wires and Coil
- 88 pickup
- Flat Towing my 93 4x4 5speed
- Rear brakes vibrate under heavy braking
- Shirley's Demise
- Warrior rear bumper?
- Tedabyte's '89 Pickup build log
- Air cleaner noise
- Need help. Running fine....5 min down the road truck dies can't restart
- 3vze no spark
- Magnaflow VS LC Engineering
- Some help with a 91 Hilux Surf (2LTE)
- Egr/air injection help
- 3VZE Inconsistent Idle and Shutting Off
- New SS muffler assembly for '87?
- Clutch size questions
- Squeaky clutch pedal? Here's a fix
- '94 3VZE Oil Cooler
- Chuck's 89 22RE 4Runner
- 87 4Runner turns over but won’t start.
- 22RE won't start when hot - where to look?
- Adding AC - Need some Guidance
- New to site, sort of new to Toyota 4runners
- Smittbilt Front Bumper picture
- Replacing rear leaf springs + shocks / need advice
- Auto Trans idle speeds
- Broken Clutch Bracket & Clutch Master + Slave Cylinder Replacement
- vapor lock, fuel injection?
- 93 4Runner V6 3vze Diagnostic Not Working
- Just won't run (long read)
- 1st gen 4runner, 2nd gen truck crossmember differences?
- Spark plug wire holder
- 93 3vze 3.0 acceleration/power problems...
- A340e transmission compatibility
- Urgent situation: snapped leaf springs
- 88’ Toyota dolphin motor home AC issue
- Headers Headache
- Exhaust tip?
- Rear differential bearing race
- Wiring question with CSI
- Fog light bracket fab help
- Shifter Boot & Clutch
- Engine surges when foot is on brake pedal and is warm
