Air cleaner noise
Old Sep 18, 2019 | 12:55 AM
Swis's Avatar
Air cleaner noise
I have a well maintained 1990 3.0 V6 in my Toyoterhome. When the engine is warm both inside and out I can hear a chattering rattle I can trace to the air filter. Is it possible that over the years that some spongy spacer has worn out and I have a potential air leak? Any ideas?
Old Sep 18, 2019 | 05:14 AM
ev13wt's Avatar
5 Year Member
Replace air filter. Then you will know.
Can you shoot a video? Youtube it and link it here?
Rattling is can be anything from a loose plate that reaches its resonant frquency at points in the rpm band to a timing chain or bearings.
Gonna guess connecting rods
Old Sep 18, 2019 | 11:23 AM
Swis's Avatar
It has a new air filter which doesn't fit tightly for reasons I'm trying to learn.
Old Sep 18, 2019 | 11:30 AM
old87yota's Avatar
What air filter did you buy?
I prefer the Genuine Toyota air filters.
They fit just right every time.
Old Sep 18, 2019 | 11:52 AM
RAD4Runner's Avatar
Originally Posted by Swis
... Is it possible that over the years that some spongy spacer has worn out ...
What spacer? The only soft material other than the paper filter is the foam/rubber gasket that surrounds it. That gets replaced with every filter change.
This ^^^ saves you labor and time to just use OEM.
nuknuk
Jul 21, 2016 07:06 AM
toyota hunter 07
Mar 12, 2011 06:53 AM
bw1
Feb 23, 2007 06:22 PM
98runn'n
Feb 10, 2006 12:38 PM
Blizzardlizzard9
Nov 23, 2004 10:34 PM
