Transmission Front Seal Replacement
Old Oct 15, 2019 | 02:49 PM
84 yota dude's Avatar
Hello.
Do you need to drain the transmission to replace the front bearing retainer seal? I have looked in the FSM and they do not mention just replacing the front bearing retainer seal.
I am about to drop in a new engine and have read that now is the time to replace the seal.
This is what I am talking about. https://parts.toyota.com/p/Toyota_19...031130115.html
Old Oct 16, 2019 | 04:23 AM
coryc85's Avatar
If you are talking about changing the input shaft seal, yes you will need to drain tranny. If you are only talking about that paper gasket for the bolt on cover, then no I don't suppose you need to drain tranny. I'd change the input seal if I were you.
Old Oct 16, 2019 | 05:25 AM
ev13wt's Avatar
5 Year Member
Is it higher than the fill plug? Sort of. It will puke.
Just tilt it a bit and do the seal, if you don't want to drain it.
Old Jun 4, 2020 | 10:53 PM
Appreciate the replies. Yes, I had to drain the transmission. Duh!
noneckrex
Apr 5, 2010 12:28 PM
Y2Krunner
9
Sep 2, 2009 01:30 PM
chopitrakeit
Sep 19, 2008 08:28 PM
Phssthpok
Oct 8, 2007 06:33 PM
ThomasJ
13
Nov 29, 2005 08:16 PM
