still leaking after inner axel seal replacement.
Old Sep 1, 2009 | 03:19 PM
Y2Krunner's Avatar
ok, so i have replaced this seal a couple times in the last few weeks. both times it has started leaking again. i am at my witts end with this. One thing that happened to me when i replaced the original one was my seal puller nicked the inside of the axel housing, right on the corner of the 45 degree angle where the seal surface opens up to the abs ring surface. its more on the angled surface and not the seal surface (see picture). not sure if this is my problem, maybe a burr on that little nic damaging the seal going in. Both seals sat nicely and the breather has been cleaned out. The bearing and outter seal were not replaced.
Old Sep 1, 2009 | 04:16 PM
akaphilly's Avatar
i really dont think that tiny spot would cause it. you could have a bent axle.. try getting marlins heavy duty seals!!
Old Sep 1, 2009 | 07:41 PM
Y2Krunner's Avatar
marlins heavy duty seals <-- who carries them?
Old Sep 2, 2009 | 03:18 AM
akaphilly's Avatar
marlin crawler dot com
Old Sep 2, 2009 | 09:03 AM
J-Ball's Avatar
Damn, heavy duty seals!? I wish I would have know that before, it might help.
Unfortunatly your 2000 may have other issues. Have your axles been upgraded????
See my post here....
https://www.yotatech.com/forums/f2/k...p-pics-189989/
2000 4runner axles were flawed from the factory, unless you replace everthing and do the upgrade, they will continue to leak. However it sounds like you have a more immediate problem. I don't think it is the nick in the tube. I don't think it's a bent axle shaft, unless you had an accident. Is your breather clear and functioning properly??
I think it's safe to say that JUST replacing the seal is only a temp fix. The RIGHT way on a 2000 is to upgrade every thing. The RIGHT way on all others and upgraded 2000's is to replace the bearing, (bearing case also if needed), both seals AND check the breather!!!!
LEAKING AXLE SEALS ARE A PLAGUE IN THESE 4RUNNERS!
Old Sep 2, 2009 | 09:15 AM
Y2Krunner's Avatar
this is all currently on my 98 4runner
Old Sep 2, 2009 | 09:30 AM
GoFaSSter's Avatar
MArlin Crawler did not seem to have anything special for vehicles with ABS. It says OEM on their description and no picture. Am I missing something? I would like to find out because I need to replace the passenger side seal. Thanks.
Old Sep 2, 2009 | 11:45 AM
J-Ball's Avatar
Saw your sceen name and just figured..... going too fast.
I'd still check to see if there is any slack in the bearing case. (I'm not sure how much yours differs from mine). Any slack or roughness could cause the seal to fail.
Any other symptoms with the rear end?
Maybe try a differnt brand of seals?
Are you freezing the seal before you put it in the axle tube?
Old Sep 2, 2009 | 12:53 PM
akaphilly's Avatar
oh man. i forgot the HD axle seals arnt for an ABS axle.. crappy.. sorry
also good call J-ball on the breather.. if it is clogged that will cause your axle seals to blow.
Old Sep 2, 2009 | 01:30 PM
jdmaccord6's Avatar
same thing happend to mine and i also have a 2000. Turns out the bearings were bad which caused the seals to go bad. I endded up replacing everthing (bearings, inner/outer seals). I might be missing something else too, but I think total in parts was less then $200.
jasonty
41
Dec 23, 2018 01:00 PM
yourrealdad
Jul 29, 2015 11:08 AM
Iceman4193
Jul 15, 2015 04:48 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
