PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Hi beams aren't working -- at all- on 1985 Pickup
  2. Headlight problems
  3. 1989 pickup 2wd 2.4 overdrive not engaging
  4. O-ring instead of gasket on oil pickup tube
  5. No power to B+
  6. 1986 Restoration
  7. Body Part swap??
  8. 86-95 22re to 2l-t/2l-te conversion
  9. Universal fuel filter
  10. Snow Wheeling!
  11. Blue vacuum switching valve replacement
  12. Code help please
  13. Painting my cluster surround, suggestions/questions
  14. Sporadic cutting out
  15. 1993 Toyota 4Runner Rear Speakers
  16. Whirring noise manual transmission
  17. New Year, New Truck, New Member
  18. Part number for fender flares
  19. 86 horn circuit, can't find the relay?
  20. Front Mud Guards - best place to get?
  21. Broken rear torsion bar mount repair
  22. 2nd to 3rd gen winch bumper fit compatibility?
  23. TAIL Fuse is the wrong amperage.
  24. HELP! pulling codes
  25. CV Axle replacement
  26. Speedometer correction help.
  27. 1987 Custom Cab Rebirth
  28. Replace dash blanks with USB extension
  29. Temp Gauge Flutter (sometimes)
  30. 1990 4Runner Top Fender Bolts and bumpers
  31. 1986 to 1992 22re swap cpu issue
  32. 89 yota 4x4
  33. 89 4Runner Tailgate Tensioner Rattles
  34. Rough Idle and Throttle Issues Please Help
  35. Rear brakes getting hot, right parts combo for 1 ton?
  36. LC Engineering And Doug Thorley Out Of Stock
  37. 22re Throttlebody sticking question?
  38. 23 RE starter/solenoid problems
  39. Add rear spare tires wing arm to 1991 T4R that didn't have one
  40. Chassis/rear mounted wing
  41. 1990 Pickup No Power
  42. Truck stalls under high electrical load
  43. 92 Pickup New Transmission
  44. 92 Pickup New Transmission
  45. My 4wd tries to kill me IFS 87 pickup
  46. Maybe there are dumb questions
  47. Clutch issues/misunderstandings
  48. VAFM Disassembly on 3VZE
  49. Endless cranking cold start help
  50. 91 truck no power to main fuse box behind battery
  51. How is the 22RE ignition module controlled?
  52. '88 22RE Toyota 4x4 wont start when cold...
  53. Door Mount rear vew mirrors
  54. Soft/Spongey pedal after replacing my drum brakes
  55. Why are there two cutouts on the top of the piston and not just one?
  56. 1988 SR5 aftermarket head unit problems.
  57. Clutch/Brake Pedal Height
  58. Shift lock fix and power steering
  59. 95 4 Runner 3.0 rough cold start
  60. 3VZE acting strange - Time for a new throttle body?
  61. 89 Pick up
  62. 91 Build, how and how much
  63. 3vze no injector pulse
  64. CT20 vs T3 and ebay manifolds on Mini Cruiser RV
  65. 1993 Toyota 4Runner 3.0 Limited Radio Wiring Harness
  66. 3.0 to 3.4 Engine Swap
  67. Sending unit
  68. Opinion on Diodes (or not)
  69. 86 toyota turbo pick up runs like crap when cold
  70. CA smog Please help - Diagnostic Included
  71. Noisy wiper transmission
  72. 1991 Toyota 4Runner 3.0 Won't Start After Plugging In Cigarette Lighter
  73. 1991 Toyota 4Runner 3.0 No Spark
  74. 87 4Runner Throttle Cable Assy
  75. Really bad idle on warm restarts after going through big puddles
  76. 4wd Indicator Switch for gear driven TCase
  77. 95 4runner Emissions trouble
  78. Front sway bar
  79. Tailgate weld nut
  80. 87 Pickup - Old Man Emu shocks on a stock suspension?
  81. Calculate mileage/miles travelled
  82. IFS Front End Rebuild
  83. 2nd gen 4runner universal rear wiper mod
  84. new steering gearbox and steering still loose
  85. Imobile 1987 22re with Itasca RV with auto transmission problems
  86. 88 4runner lower control arm bushings
  87. 1989 Toyota truck - not starting on cold mornings...
  88. Front Skid Plate 94 Pickup
  89. 22re 0 Compression
  90. Intermittent Chirping Sound Coming From 3vze
  91. Misfire on 93 Toyota 4Runner 3.0
  92. 1986 Toyota 4 x 4 PU Horn not working
  93. "Random" Stalling
  94. 1993 22re knocking noise
  95. WTB - brush guard for 84-89 4runner
  96. 88-92 knock sensors vs 93-95 knock sensors
  97. Cold Air Intakes For 1993 Toyota 4Runner 3.0
  98. Question on Restoration - Body Work
  99. 1988 3vze auto 4x4 pu no injector pulse
  100. 93 22re dies above 1900rpm and restarts at 1600rpm
  101. Just getting that age?
  102. Online junkyards
  103. 1990 4Runner Antenna Nut
  104. 1991 pickup 4x4 vibration
  105. 3VZE TPS direction
  106. 2nd Gen 4Runner driver side mirror
  107. 89 Pickup starting prroblems
  108. Replace or at least relocate Toyota fuel filter?
  109. Temp gauge fluctuates on 1988 toyota pickup 22re 4wd
  110. Castrol GTX high mileage 20w50?
  111. 91 Toyota pick up 3.0 L automatic 4x4 will not move under acceleration
  112. No Crank, electrical issue
  113. Best choice for head gasket
  114. Please Help fuel pump power issues
  115. Help break pedal goes to floor after bleeding.
  116. Loose headbolts
  117. 1987 4 runner fuel sending unit
  118. AC compressor bad
  119. Regarding flywheel installation on 1995 4runner
  120. 94 PU Potential Head Gasket Failure Diagnosis
  121. A/C Amplifier circuit board
  122. 1992 Toyota Pickup 4 Cyl PU
  123. Replace leaf spring eye bushing?
  124. 1986 22r idle revs high
  125. 1987 Pickup 22R air intake
  126. Igniter Alternatives for 91 22re
  127. 95 4Runner 4wd trying to engage
  128. 1990 pickup 22ere starts then stalls
  129. 92 4x4 Auto truck 3.0 Relays/switches in ignition sequnce
  130. 3VZE ticking
  131. Ticking AFTER heating up.
  132. Anyone know where this vacuum line should go?
  133. Fuel pressure gauge sometimes holds pressure, sometimes it drops automatically. ????
  134. Have high beams but indicator does not light
  135. 3VZE No Spark No Start Out of Nowhere
  136. Need Help Diagnosing: 22RE Ignition or ECU failure, other? 86 4Runner Dead w/Code
  137. 86 4Runner Windshield Leak, Upper Seal and Trim Missing (84-89 4Runner, 84-88 Pickup)
  138. Rough Idle, Dead Spot & stumble w/ Acceleration. Out of Ideas!!
  139. Functional cold air hood scoop intake
  140. Help. Timing belt moved forward
  141. 1994 Toyota Pickup 4x4 29k miles!!
  142. 1986 v6 4runner: transmission?
  143. CV Replacement '93 4x4 with A.D.D and Auto Lock Hubs
  144. 22re engine not starting, backfiring from intake.
  145. 22re Running rich, poor fuel economy
  146. Transmission leak
  147. rear axle bearing tool (homemade)
  148. 1994 Speedometer
  149. '88 4x4 3vz manual *Transfer Case fluid* ... is castrol syntec gl-5 okay?
  150. Single Clunk when turning over, misfire and puffing white smoke.
  151. Noise Identification Help
  152. LED headlight pick for 1998 4runner limited stock housing
  153. Runs like garbage, can't figure it out.
  154. New member and new to me '91 Xtracab SR5 4X4
  155. Gears and lockers test run
  156. getting some body work done around the back bed
  157. 95 pickup with 22re won't start.
  158. Speedometer Sensor and 4WD indicator for RF1A
  159. 1993 22RE not getting fuel -HELP
  160. 87 4runner manual trany swap, best donor
  161. Trouble Codes 11 & 14 Help
  162. 3vze coolest leak.
  163. TCM problem
  164. Transmission fill
  165. Low Idle after LC Header install
  166. Rear ujoint
  167. Aftermarket Gauges
  168. Rear joint replacement
  169. Injector pulse loss when hot
  170. What sensor is this? 93 4runner
  171. New to Toyota please help
  172. Air in radiator. Not enough to blow hose.
  173. After a year and a half, my ‘93 finally runs!!
  174. 1994 4runner V6 coolant loss question
  175. 1988 SR5 gauge needle painting
  176. 1984 Carb to 1992 EFI Swap
  177. Truck Oil Leak? Head gasket?
  178. 1987 4wd emission decals-cal spec-need photo
  179. Alternator light flicker but good voltage everywhere
  180. Loss of Power after 2200 rpm
  181. What PSI are you guys running with 31x10.50s for the best possible ride?
  182. 1991 pick-up 4x4 with3.0
  183. Source for front valance nuts
  184. Add 1991 toyota pickup
  185. 3VZE Oil in Water
  186. Zip locker, unknown part...
  187. Running rich, re-built twice and still not done
  188. 22re no idle issue.
  189. Was running now crank and no start.
  190. 3.4 swap Texas
  191. R150F royal purple
  192. 1994 dlx
  193. Fuel Injector Noid Light 22RE
  194. Tailgate wiring question
  195. 93-95 alternator on a 91 3vze?
  196. '85 Pickup Engine Clacking and Other Woes
  197. Won't start 89 pickup 3vze
  198. 1988 4x4 w/3vze + manual 5 speed = which type of Redline and how much ?
  199. Knock sensor engine bay wire
  200. Identify these Coolers Please!
  201. Air cleaner housing lid gasket
  202. 1986 4runner SAS questions
  203. KC Daylighters and Voltage
  204. Fuel Pump Wiring Question
  205. turn signals tight: lube recommendation
  206. Rear cam plug
  207. What is this cable for?
  208. 1994 Pickup Body Lift
  209. Horn stuck on
  210. sources for replacement bedsides for my sons 1991 SR5 V6 extended cab 4x4.
  211. 93 4Runner Transmission
  212. need help. thx..
  213. Rear upper control arm replacements
  214. Steering wheel question
  215. 99 tacoma front turn signals do not work
  216. Rear door exterior handle disengaged
  217. Weber carb T/S
  218. Alh swap kit
  219. Turn signal 1994 4runner
  220. Weak binding crank, need help diagnosing
  221. 1986 complete restomod build
  222. 88 4x4 winterization, shocks, t-bars, and tune up questions
  223. Fuel Pressure Control Circuit 92 p/u 22re 2wd
  224. Code 25, valve adjustment and now won’t start
  225. ?Vacuum issue? 88 efi 4x4
  226. 4runnw
  227. Trouble identifying full hose part numbers
  228. Murray radiator blowing coolant
  229. Osidetiger upgraded 12-hole injector review
  230. A few muffler swap questions
  231. custom fuel tank fab
  232. 1994 4Runner misc. questions
  233. Pickup 3.0 power steering leak
  234. Alternative Options for Wheels
  235. New member, '92 XCab 4x4 PU owner - hopeful MB diesel swapper
  236. 1988 3VZE intermittent stutter issue
  237. Hole on top of new rear V6 differential housing.
  238. Bilstine shocks for my lifted T100
  239. 1st gen lifgtgate motor swap
  240. Truck sitting uneven
  241. Knock sensor disconnected, no CEL?
  242. CV boot popping off
  243. Extended front brake hoses too long - tire rub
  244. Good Quality CV Axle Choices
  245. 95 4x4 clutch
  246. Missing fuses? Recovered stolen '90 4WD 3VZE MT deluxe pickup won't start
  247. sr5 cluster with bulbs vs leds.
  248. 22r weber 32/36 vs 22re vs 2l diesel
  249. HELP, loose power cable
  250. Oem Plastic timing chain guides?
