PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 [130] 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. mega pressure build up in gas tank
  2. I need a frame measurement from you OME leaf spring people.
  3. Running Hot
  4. Poor MPG and Fuel Odor
  5. AFM installed…and it runs like crap?!
  6. 86 22RE throwing codes 5 & 11
  7. engine swap or upgrade to 3rd gen
  8. 85-95 22R 22RE Piston Ring sealing
  9. Help with interior mods
  10. Head Gasket Woes...Again
  11. Transmission/Speedometer problem
  12. Dana 60 straight front+engine swap
  13. low beams dont work but high beam does????
  14. cylinder missing, and it doesn't make sense!
  15. Rattle noise from engine
  16. Tune Up Help
  17. I want to know what is missing from the bottom of my engine?
  18. 89 22RE won't start after timing chain/gasket change
  19. Rancho IFS Lift Install by a newb
  20. Hazard switch..light blub needs to be Replaced HELP..
  21. New coils vs leafs
  22. Uneven Tire Wear - Wheel Alignment or something else?
  23. Real slow, long crank, and codes 12 and 13
  24. exhaust manifold - use it?
  25. knock sensor/pigtail/ 95 3.o
  26. 22RE firing only on 3 cylinders
  27. 90 to 92 parts swap
  28. 92 4runner anti lock light
  29. Burning Oil but no leak? And rough engine... vaccum issue?
  30. Wiring diagram help.
  31. Went on Vacation for 1 week, now truck doesn't start
  32. brake light switch bad?
  33. Door panels for 89-95 Pickup Single Cab
  34. Body lift removal considerations??
  35. No Knock signal, code 52
  36. $100 Cat Converter cause a HG to blow?
  37. SR5 Cluster swap 1994 4WD to 1994 2WD problems!
  38. 86 Runner ret swap finished um.... almost
  39. Wheeling with canopy?
  40. Sorry, but I have another AFM swap question and need HELP
  41. Speed/Odo not working code 42
  42. New timing chain in 22RE making noise?
  43. '86 SR5 4X4 Pick-up Rear Pinion Seal
  44. 3.Slow headers.
  45. Post pics of "2wd" pickups
  46. Replaced Rear axle seal and bearings
  47. Help!!! INTERMITTENT POWER LOSS (92 4Runner Turbo Diesel)
  48. Original 1986 4Runner window paper/label
  49. Original 1986 4Runner window paper/label
  50. My 94 4runner w/ FJ80 Coils & 4Crawler BJ Spacers
  51. Check Engine Light. auto 4x4 93 4runner
  52. timing belt tensioner roll pin
  53. truck wont start just clicks
  54. Need some good advice on a 22-re problem
  55. lost connector! Can't find its home!
  56. Rear brake ticking noise
  57. IFS Diff Question
  58. Transmission Problems
  59. replacing parking brake cable
  60. 1992 Rear Window compatible with 1996 4RUNNER Question
  61. Seat Track Swap
  62. 95 4Runner A-Pillar Pods (dual)
  63. coolent puddle
  64. acceleration body roll?
  65. starter problems again
  66. my $500 91 4runner 4wd
  67. 89 pickup body work/paint...soon
  68. 93 Runner shakes (especially uphill)
  69. disable check engine light?
  70. Help with wire harness clips?
  71. rear axle help
  72. 1st-2nd "hop" 93 22re
  73. starter issues
  74. Does this sound right!????
  75. Rearend vibes
  76. O2 sensor operating voltage
  77. bad hg? white smoke
  78. fan belt change help
  79. no start 95 4runner 3.0
  80. Couple Quick Questions: 1992 Toyota 4 Runner w/ 360K
  81. Mystery camshaft question
  82. 1986 Tailgate window INOP
  83. Mysterious missing parts, and parts that shouldnt be there.
  84. Oil Pressure Reading SR5 Cluster
  85. Can't Turn over Crank by hand
  86. 1st Gen 4runner gate lock cylinder?
  87. 93 4runner rear lock diff
  88. 93 22RE blown engine or?
  89. Help! - Turn signal dimensions for a 89-95 Truck
  90. Info needed for AFM swap...filter system?
  91. IFS parts breakdown w/ Part Numbers
  92. Possible Thermostat - Temp Sender - Temp Guage Problem...
  93. Exhaust is shot!!!
  94. Idle air control valve (IACV) help! high idle issues.
  95. blew a tire on I-5 today
  96. A/C Idle Up Troubleshooting
  97. 88 yota engine problems
  98. A bunch of questions regarding 33x12.50's on a 2nd Gen 4Runner
  99. Purge Line not connected to throttle body?
  100. 1994 4x4 pickup, CV Joint?
  101. transmission mount and clutch chatter
  102. Shackles and johnny joints
  103. Help removing 22RE
  104. 1988 4x4 Front Diff. Help
  105. over heating, where does this go?
  106. Need help with camshaft/crankshaft allignment marks
  107. 87 pickup auto
  108. Driveshaft broke off while driving..what to do next??
  109. oz sensor mount thingy
  110. Where to mount clinometer on 2nd gen 4Runner?
  111. New rebuilt 22-re (85-95) **BLOWN**
  112. 1988 Toyota Truck Xtra Cab Exterior Pillar Post looking Piece
  113. how to id my tranny
  114. 3.0 AC on Idle Too Low
  115. Roof Basket Direct Mount?
  116. black or blue color poll??
  117. 91 Runner with a Knock Sensor Issue, Please Help
  118. Mystery rear end play with Video!!! What is the problem?
  119. where is the transmission control module located
  120. what would cause a new waterpump to groan?
  121. New exhaust recs for my 92 Xcab?
  122. Fresh Head gaskets + a few codes
  123. Mystery rear end play, feels like a U-joint but not
  124. '89 3.0 VZE tap tap tappin' away...
  125. No oil pressure
  126. Stock Rear Speaker Wires?
  127. Aftermarket parts
  128. 3.0 Jerk Problem
  129. Gauge cluster does not work and NO fuse is blown!! any way to check its function???
  130. Power steering pressure hose '91 4Runner
  131. Complexity of adding A/C
  132. used truck 216K maintenance?
  133. Brake/MC diagnosis.
  134. AFT leaking all over the place
  135. Control Arm
  136. Alternator Upgrade: Idle Amps?
  137. FSM on CD??
  138. Factory security light won't go off after playing submarine
  139. kinda bored, need a cheap new project
  140. Gauge cluster question..
  141. Looking for 22R-E pics
  142. 22re fuel pump questions
  143. Stock Mud Flaps??
  144. Oil pressure sender
  145. 22r needle valve problem
  146. Visors for 1990 4Runner?
  147. '95 4runner mirrors on a '94 pickup
  148. 22RE dies out. Need help!!
  149. 3vze Engine Knock
  150. 1994 vss
  151. 5mge swap in 85 yota pickup
  152. Replacement Connectors?
  153. replacing the bulb in the shifter console?
  154. 1994 3.0 4x4 ext cab dead miss at idle only
  155. BJ spacer + bracket suspension lift
  156. Harmonic balancer counter tool
  157. 2nd Gen 4Runner ARB Bull Bar light options
  158. Wont start. Please help real time
  159. cross-threaded brake line
  160. Engine never gets to operating temp
  161. No acceleration...
  162. Coolant Boiling
  163. Drum Adjustment Question
  164. 87 22re w/efi issues.....
  165. Whats this junk in my oil pan
  166. 22re clutch chatter?
  167. Valve noise after lash adjustment
  168. lower control arm bolts
  169. 86 22re clutch issue
  170. losing coolant
  171. Selling my 1993 22re - Vancouver BC
  172. Write-up: Set timing on non-running 3VZE
  173. ever put your cabover camper on your lifted truck?
  174. head differences
  175. A/c belt adjustment help please!
  176. 4Runner diff's or hogs head
  177. Let's play a game - what are these? (pics)
  178. 3.0 V6 Cold Starts fine dies after warming up
  179. well thats weird...when I run my A/C
  180. No brake pedal on my 89 pickup
  181. new 22re
  182. v6 Power Steering Rebuild
  183. 22R break-in questions
  184. Weber Carburetor Issues?
  185. 1st Gen 4runner rear 3 pt seat belts
  186. Loping question
  187. 87 22re exhaust manifold leak (Newbie)
  188. A/C help
  189. Firewall AC line block of grommets
  190. Random efi fuse issue
  191. 1986 toyota front end
  192. MC bumper on truck with 2" body lift (with pics)
  193. 91 toyota manual hub conversion problems! pls help!
  194. V6 Auto 4runner Output Shaft Seal Help
  195. pre-purchase rebuild parts
  196. 22r to 22rec ???
  197. EXTREMELY annoying squealing sound!!!!
  198. HUGE missing issues with A/C
  199. Vacuum HELP!!!
  200. 89' Pickup to 4runner bumper tube swap
  201. Alternator issues Not your common problem
  202. 1994 Toyota truck wont start..
  203. Sr5 seat retrofit. Seatbelts too?
  204. Another starter problem
  205. help with 1995 4runner differential
  206. cv boots torn in 2 days
  207. Traded my Heep for a 2WD 1990 Pickup named Travis
  208. mild toyota truggy pics?
  209. Signal Light Mod
  210. Rust under paint
  211. A different starting problem with the 3.0 V6
  212. Replacing backing plates and rear brakes
  213. Upstate NEW YORK Pickups!!
  214. Transmission / Rear gear ratio question
  215. 22rte dying...?
  216. 95 V6 Engine acts up on freeway.
  217. Wire harness ground issue 95 pickup
  218. Need help asap with EGR vacuum solenoid/transducer/moduler....87 4runner turbo
  219. Help!!!! 1990 Toyota 4runner PWR door locks, and PWR windows dont work, ATALL!
  220. ac belt tensioner
  221. Headlight Burnout
  222. Cleaned my headliner today
  223. 89 22re rebuild or ????
  224. 90 4runner 22re swap codes 51 and 31 help!!!
  225. Turbo vs Non Turbo AFM
  226. Fuel Pump Issue
  227. r12 to R134 conversion questions
  228. EGR valve part numbers / differences...
  229. paranoid spark plug
  230. 1986 4x4 truck wobble
  231. 4wd problems
  232. trouble starting
  233. 3vze has something missing on left head?!?
  234. Official 86-95 FAQ READ FIRST!
  235. a/c repair
  236. Water leak behind glove box!
  237. new 86 4runner project
  238. 4runner and pickup interchangeable parts?
  239. I can not remember the code number but,
  240. Weber Carb guys!!
  241. R150F transmission problems
  242. Can't remember where a few things go: 86 P U 22RE
  243. ABS question in 2nd gen
  244. 88 4runner SR5 with engine fuse issue
  245. 4Wheel Drive No Worky
  246. Name that switch or what ever it is.
  247. 88 4runner fuel pump v6
  248. Engine moise after new Head Gasket
  249. 87 4x4 truck 22r Water pump pulley
  250. turn signals dont work but hazards do...
