Think i need a new rear axle???
Old Apr 24, 2010 | 07:42 AM
McQuaid's Avatar
Guys
Found this today, im finding it difficult to find the parts over here so how much you guys think i'll pick up a rear axle housing for a manual 3litre turbo diesel for in the states???
Any help would be appreciated
Old Apr 24, 2010 | 07:48 AM
McQuaid's Avatar
Here's a pic
Old Apr 24, 2010 | 08:34 AM
Tofer's Avatar
Sponsor
JB Weld it
you can find the IFS rear housings over here for a couple hundred bucks ( hell i sold a narrow rear axle for a case of beer) but shipping would be killer.
Old Apr 24, 2010 | 09:24 AM
Matt16's Avatar
All Hilux Surfs/4Runners have the same rear axle housing. Its quite heavy and I suspect that it would be prohibitively expensive to ship from the colonies.
Old Apr 25, 2010 | 06:16 AM
McQuaid's Avatar
i cant even find one on eBay, this looks harder to find than i thought
Old Apr 25, 2010 | 07:16 AM
Tofer's Avatar
Sponsor
i dont know if you're searching for "turbo Diesel rear axle" or not because you will not find them here... you want to just make sure its from a 90-95 4runner. also check Craigslist.org
Old Apr 25, 2010 | 12:50 PM
Matt16's Avatar
Search for a 1990-1995 4Runner axle, the earlier one's were leaf-sprung. They'll work, but you'll have to weld on pads for coil springs and mounts for the 4 links... easier to buy a 1990-1995 rear axle.
Old Apr 25, 2010 | 08:07 PM
Desp's Avatar
What are we looking at in the picture? I can't make it out.
Old Apr 25, 2010 | 08:18 PM
peow130's Avatar
I don't see it either..
Some type of crack in the housing?
Old Apr 25, 2010 | 08:26 PM
Desp's Avatar
Oh I see it now, it must be the rear of the axle and the tall thing is one of the brackets.
Old Apr 25, 2010 | 08:27 PM
Desp's Avatar
Originally Posted by McQuaid
Guys
I have one I might be able to give you if you want to see how much shipping would cost from 76227 in Texas.
Old Apr 26, 2010 | 12:20 AM
McQuaid's Avatar
yes, it started as a hole in the housing at the top so i was always weeping a bit of oil, then the big arm that is welded onto it holding a tension bar broke off, ive gotten it welded by two diff proffesional welders but has always broken again, then this large crack appeared the other day and covered a motorcycle i had on a trailer with my axle oil ;-) dont think it can be fixed so need a new one...
Desp, your a superstar.....who do you reckon i contact to get a quote for shipping? do you reckon its the same rear axle as mine?
Old Apr 26, 2010 | 12:41 AM
McQuaid's Avatar
what dimensions and weight you guys reckon this axle would be shipping at???
Old Apr 26, 2010 | 04:20 AM
Desp's Avatar
All you need is the axle housing, right? I can remove the drums/axles/third member and make it as light as possible. It's off of a 1995, V6 4WD 4Runner so it should be the same as yours.
Old Apr 26, 2010 | 04:22 AM
Desp's Avatar
I'd start out saying about 5 ft long, 12"x"12 and at least 100 lbs. I know it's probably over 2 with everything on it.
Old Apr 26, 2010 | 04:26 AM
McQuaid's Avatar
Great, i'll get a price and get back to you
Old Apr 26, 2010 | 04:42 AM
McQuaid's Avatar
$640 to ship it from texas to ireland, WOW.....didnt think it would be that much...would there be anyone else to try other than UPS?? would my rear axle be the same as one from a 97 hilux surf??
Old Apr 26, 2010 | 05:12 AM
Desp's Avatar
I tried Fedex, it looks like around 575, I'm guessing pretty much anything will be 500+.
Can't weld it up then support it from the outside with some bracing?
Old Apr 26, 2010 | 05:13 AM
McQuaid's Avatar
looks like its a pretty epic crack, wraps all the way around the axle too....i have an option to get a rear axle off a 97 surf but not sure its the same???
Old Apr 26, 2010 | 10:41 AM
peow130's Avatar
The later model axles aren't the same as the older 79-95 axles. I believe the diff is different.
You might be able to make it work if you convert it to leafs and leafs on your 4runner. But the dimensions of the later model link in the rear are going to be different.
