well i finally passed california smog...
Old 04-28-2010, 07:52 AM
machine23's Avatar
but i was comparing the numbers for this smog to my last smog 2 years ago, and there is a significant difference,
this years' numbers
at idle, 765 rpm. %CO2= 14.8, %O2= 0.1, HC=78, CO= 0.28
at 2500rpm. % CO2=14.9, %O2= 0.1, HC=18, CO= 0.03
last years' numbers
at idle, 939 rpm. %CO2= 15.2, %O2= 0.0, HC=7, CO= 0.00
at 2500rpm, %CO2= 15.1, %O2= 0.0, HC=9, CO= 0.01
i was pretty shocked that it passed, because when you listen to the engine when its idling, the rpms seem to go up and down. the engine constantly dies on me. say your going 45mph or so with the tach at 2500rpm, if you let off the gas, and put the clutch in, the idle will drop below 300rpm and bob there for a little while. sometimes it catches itself and comes back to 800 or so, but it has mostly been dying that way. it died on me 6 times yesterday after getting it smogged. and no, the brake pedal has zero affect on the idle.
and the engine feels like a true gutless wonder right now. timing is correct. 150psi compression all around, and it runs kinda rough at idle, almost like its misfiring
Old 04-28-2010, 07:58 AM
MortonPhotographic's Avatar
I don't know much, but I would change out the fuel filter to start with.
Old 04-28-2010, 08:02 AM
snobdds's Avatar
I would check the TPS.
Old 04-28-2010, 08:49 AM
OutlawMike's Avatar
Start with the basics and go from there. When was the last time you did a tune up? Cap, rotor, wires, plugs, air filter, fuel filter, all the consumable stuff.
The oxygen sensor can cause issues if it is reading giving up the ghost, it is a maintenance item also.
You cat could be losing efficiency also, could be part of the reason why
Check the TPS resistances and the timing/idle speed, make sure all of that is up to snuff.
Move on to the EGR system, verify that it is working properly and not causing problems.
Any codes stored in the computer?
If you have good compression in all cyclinders, then, you most likely have a solid motor mechanically, but some EFI or emmisions components are wearing out, or something out of adjustment/clogged, etc.
Good luck.
Mike
Old 04-28-2010, 09:46 AM
machine23's Avatar
cap, wires, plugs, rotor, fuel filter, all replaced recently. and my k&n air filter was cleaned recently.
im taking it to my toyota master mechanic pretty soon, so hopefully we will be able to figure it out
Old 04-28-2010, 10:31 AM
idaho wildfire's Avatar
i had the same problem with the idle it is your pcv vale you can pick one up at napa for like 4 buck
Old 04-28-2010, 12:55 PM
90runnerfan's Avatar
hey not to brag well yes i am im moving to oregon friday so i dont gotta deal with this junk ahahahhahaha. no but seriously i hate the state of california
Old 04-28-2010, 11:59 PM
machine23's Avatar
its not the pcv valve...it was also replaced recently
Old 04-29-2010, 02:45 AM
sportbiker929's Avatar
how old is the cat?
Old 04-29-2010, 03:21 AM
totally a bro
Staff
vital22re's Avatar
a jumping idle should point you to electrical.
cruisin69
Early Land Cruisers (Build-Up Section)
34
05-22-2018 12:25 PM
malteserunner
89
02-09-2018 06:59 AM
Scatterbrain
09-03-2015 06:46 PM
dguzzi
09-03-2015 08:48 AM
Jason Webber
09-02-2015 03:30 AM
Quick Reply: well i finally passed california smog...
