- 1100miles trip went very well!!!!
- Smoking engine bay after HG replacement
- Mystery coolent leak.
- need sensor!! 89 efi
- dana 60 full width front 3 or 4 link ?'s
- blinking battery brake light - Alt Ground Issue?
- 94 valve covers-is it hard?
- Radio woes, today was a pain.
- 4runner resists turning when in 4wd
- question about shocks....
- harmonic balancer bolt
- help - need Wiring Diagrams
- whats bad in my front end!!?? axleshaft support bearings?
- Missing Throttle Return Spring
- Rod directions
- 95 Pickup fuel tank
- 93 toyota wont start
- hub nut??
- Bleeding brakes on a rear ABS system
- Finally got another Yota
- Rear spring u bolts
- tranny mounts
- 22RE engine wiring issues
- T100 Rotors for '86-'95 Trucks/'Runners
- 3.0 starting problems...
- 22re rebuild parts
- Seat question?
- so my yota is totaled...
- looking for a 1st gen 4runner
- Heater/vent/ temp. slides/linkage stuck. Idea's?
- 6" ifs lift?!
- Overheating question.
- Just replaced both CV axles but that clicking sound is still there!!
- Identify this lift
- What gears were stock on 86 xtra cab 22re 4wd? Anyone know?
- Help, 91 4runner won't start.
- Need help w/ Aisin Hubs
- Stumbling, hesitating, misfiring, etc. FIXED!
- 86 4wd 22re auto w/ 5.29 in rear. What for front?
- M.a.s. Adjustment screw help!!
- 2nd emissions attempt...failed!!!!!!
- Help removing CV shaft (yes, I searched)
- 1993 truck power mirrors
- Exhaust System Constriction?
- JC Rear Coil Spacers??
- How do I change front passenger side axle???
- spoiler on 1st gen runner
- 22re header
- Left Rear Brake Continuously Sticking
- Idles When Cold; Dies When Warm
- 22RE Engine Rebuild sooooooo pretty....
- New Exhaust on 3.0 with intake headers, and cams
- V6 with high idle, yes another question, but....
- Need advice: 87 4runner
- dont understang compression
- instantly losing total fuel pressure in rail
- 22re oil dipstick length
- Help with shocks, overload springs, etc
- 22RE - High Idle coming off the highway
- idle issues..... please help....!
- What triggers a cel?
- Thunk! in the driveline...
- body ground?
- white smoke on start up?
- Need info on 1994 4Runner Factory Alarm (TVSS)
- 93 22re Intake manifold removal ??
- Distance from axle to frame?
- Selling my 90 extracab today...SIGH!
- the cancer...
- Random miss going at steady speedany tips?
- 33" tires with 5.29 gearing on V6 too high?
- altenator upgrade
- 300km / 186 miles to a full TANK!
- K&N filter trail fix
- Price a bit steep??
- Vacuum Hose Routing Diagram
- Look at what I just got little bit of *bling bling*
- 88 Pickup fuel descending unit, steering stablilizer bushings?
- 22RTE to a 22re
- idle screw on 22re
- suspension rebuild/frame repair/rust prevention superthread
- o-ring in oil pan!!!!!!!
- 2nd Gen 4Runner 2WD lifts
- hub help
- HILUX SURF 92 lift questions....
- Car wash and open, hot headers
- Please help front main bearing issue
- Feedback on these body repair panels
- installed aftermarket intake kit now engine dies
- front end noise?
- cleaning an 02 sensor?
- New bumper and such
- 02 or a/f?
- Front to Rear 4cyl Diff
- 1st Gen Best of both worlds
- Broken E-brake cable
- fuel preasure
- Any good seat mods?
- axle housing question
- 86 turbo starts and dies
- snagged a low mile rear diff thats been sitting indoors for 10+ years, anything I....
- What are freeze plugs?
- 4runner won't start
- 22re engine hunts
- easter wheeling videos
- 1990 Automatic Trans Types
- Pitman Arm Woes
- Critical Areas To Undercoat With Fluic Film ! ??
- Clutch issues.
- cd player?
- Any Good Online Resources for 3.0 Head Gasket DIY ?
- Redline MT-90 Tranny/Diff
- killed the waterpump?
- CODES 21 and 27.. PLEASE HELP
- Questions about Pro Comp shocks
- rear sag, summit catalog link???
- FJ60 spring width
- interior curiosity...
- forgot to put the sway bar back in, didn't even notice
- Help with REAR BRAKES
- cold start idle
- Speedeometer inop ?
- Trail changing CV shafts
- Front Suspension Question
- factory EGR block off????
- Clutch Master Cylinder Replacment Problems
- exhaust question...again
- What are these, addaleafs?
- Another Idle problem
- Quick Release Doors
- Torsion Bar Questions
- Sensor problem..truck is dead
- V6 w/ extra parts inside?? PLEASE HELP!!
- Runs good but doesn't idle anymore! Help!
- 22RE Guys- tailpipe inspection...
- Anybody here using Cranes 6000- 8931 trigger?
- 93 4Runner PS Hose
- Delayed shift into overdrive-All brains ITT please
- more tranny problems
- Am I too stupid to figure this out? Please help with my seat swap
- Cold a/c fanished
- diff breather part number
- need major help!! No spark wont start
- wont change gear Auto box on 3vze
- mud guards
- 91 SR5 Dash swap?
- 33's for now...35's later
- efi vacume diagram. PLEASE HELP
- '89 not starting...
- ooops!
- 3.0 misfire?
- 1988 4 runner Rear Window
- Newbie doing HG close to the end and desparately need timing advice.!
- Please help!!!! One wire to go!!!
- 88 Toyota engine problems - bearings?
- Help Idler Arm
- sick of the 22r carb
- Fuel Injector q's!!
- My new little DD Toyota truck find...
- temp gauge running high.
- leveling out truck
- 88 auto tranny
- CO and HC emissions
- Snorkel for the Runner
- p/s pump rebuild
- 92 pickup 4x4 steering parts interchangable with ???
- My new/old 4runner
- New Clutch now some issues
- 16" rims on 88
- Pickup Bed Tire Mount DIY
- Vacuum Switch Testing?
- HELP! Wierd situation after dropping in a 3.0!
- Anyone have experiance with this 22RE head off Ebay?
- Thoughts wanted on 1" body lift and 31's
- 91 4runner w/3vze dead engine - won't start
- Control Arm Bushings: Worth Replacing?
- new factory recall
- Bigger TB?
- according to MY vin number...
- Welding front spiders?
- Installed a tow hook, question
- 3.0 spark plug wire clips/holders
- 84-89 4 runner seat track cable ..
- 94 3VZE oil starvation puzzle
- Installed some Bilstein Heavy Duties - Pics
- Help with tranny
- Tensioner Bolt
- 88 with rear wheel beaing noise.
- Just bought a 93 4Runner, few questions
- runnin on 3 out of 4 cylinders....
- Shifter boot question
- clutch is noisy until i press the clutch pedal.
- installing transmission and oil temperature gauges in my 89 4runner
- Mountain driving?
- mud flaps
- Fuel Problem
- Rip yotas
- getting a code 5
- dashpot question
- Is heater assembly same from 86-95?
- My "New" 87 4 Runner
- Check Engine Light Flashing When Driving
- My little 4Runner RTE project...
- popping noise
- rear window won't go down
- Water Fording
- New Aisin 1" bore MC
- Inspection Light questions
- 4runner tail lights
- digital guage cluster swap
- We can help with part numbers and tech
- Millermatic 185 for my SAS project
- So what sort of axles should I be looking at for 400whp
- My 94 Toyota
- ?? Engine revs high after driving in the FWY.
- transfer case flange
- 89 v-6 issues
- Centramatics installed!!
- New Lift and little baby 31's
- Aisin manual hub swap questions
- headgasket ?
- HELP - Fuel pump / fuel tank question
- tube door mirrors
- UnderCoating "Hard Grease" Meathod ?What Type !!!?
- bug shield
- 4:56 versus 4:88's
- starting to pull the clutch, wish me luck.
- Questions about suspension/tires.... dont hate
- body lift on auto trans
- roll bar yes or no
- Dont know witch cam to buy
- removed third front, can i drive with it out?
- Lockright locker install into V6 rear-write-up with pics
- need help to release the freon from the A/C system
- 87-93 idler fan bracket. CHEAP
- transmission woes g58 r150f adapters?
- rear suspension questions
- 88 4Runner 3.0 - Need Advice, Fix HG or do 3.4L swap?
- factory keyless entry system on all 4runners?
- Dark Red/Brown ATF. Flush?
- alternator issues. please help
- metered the AFM, numbers posted and help?
- 34x9.50 narrow ss's little updater...
- 22rte to 22re help
- front calipers and both back brake shoes need to be replaced on my truck
- New to ME 93
- reman 3.awesome
- Antenna WOES ideas??
- Will a 2nd gen runner body fit on a 84 extra cab frame
