What triggers a cel?
Old Apr 17, 2009 | 12:14 PM
yota4life6's Avatar
Would the following trigger a CEL?:
vaccuum leak?
bad TPS?
thank you
Old Apr 17, 2009 | 12:42 PM
toyota4x4907's Avatar
Vacuum leak= probably not
Bad TPS= yes.
Old Apr 17, 2009 | 01:15 PM
Dan.3's Avatar
something wrong
Old Apr 17, 2009 | 02:01 PM
yota4life6's Avatar
After 02 senors, vaccuum check, plugs and wires (and a failed emissions).. the truck is still idle jumping and running poorly.. I thought I had it nailed but its back!!! So I have been reading alot about TPS's and thought I would inquire.. So if the TPs would trigger a CEL, and I dont have a CEL on, then Im cool?? I even rana scanner and pulled code 21 and 27..hence the 02 sensor changes... but nothing showed up about a TPS..
any thoughts?
Old Apr 17, 2009 | 02:09 PM
Is your coolant full? When the idle in my '93 22re was fluctuating, it was due to low coolant.
Old Apr 17, 2009 | 02:21 PM
neq0323's Avatar
There are several things but mostly anything that has an input to the ecm can set off a CEL.
Old Apr 17, 2009 | 03:28 PM
DeathCougar's Avatar
Code 21 and 27 are.....?
Old Apr 17, 2009 | 04:48 PM
scope103's Avatar
Originally Posted by yota4life6
... So if the TPs would trigger a CEL, and I dont have a CEL on, then Im cool?? ...
You may be cool, but you can't really diagnose your problem that way. The computer is very smart, and if a sensor is way out of whack it will give you a clue about where to start looking. But the lack of a code only tells you that things haven't gotten so bad yet that the computer is complaining.
For instance, if your only TPS problem was an intermittent idle-position condition, I don't think that would throw a code. But it might give you loopy idle.
So you still have to be systematic, even if the computer doesn't know yet that you've got a problem.
Old Apr 17, 2009 | 06:16 PM
abecedarian's Avatar
Basically:
21- faulty heater circuit on primary O2 sensor
27- faulty heater circuit on sub-O2
I already commented on this on his other thread: https://www.yotatech.com/forums/f116...e-help-179698/
Old Apr 18, 2009 | 10:58 AM
yota4life6's Avatar
went back to emissions this morning after all that work done..failed bad!!! Legal CO limit is 1.20, I was 7.89!!!!!!! What in the hell is going on? Anyone know what that level is 7 times what it should be? the truck aside from the idle jumping from time to time, runs well.. What can I do to pass emissions????
thanks
Ronnyboy
Feb 11, 2016 05:57 PM
Sam hain
19
Sep 30, 2015 08:25 AM
charlie_fong
Sep 27, 2015 10:06 PM
Draven023
Sep 26, 2015 12:41 PM
Boomer8404
Sep 24, 2015 01:12 PM
