PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 [144] 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. parking brake
  2. JunkYard Gas Tank cleanout
  3. ome coils
  4. Figured out my timing problem
  5. 90 4runner bad idle after valve cover gasket replaced
  6. Lifting Options on 87 4runner (IFS and 4" lift kit already installed)
  7. Quick question about seafoam
  8. Strange Idle Issue
  9. Hilux Surf Exhaust
  10. Most comfortable seats in Standard Cab?
  11. 1988 4runner--Where are the heater relays located?
  12. #4 resleeve and weatherstripping
  13. I need a photo of a gauge connector
  14. Sudden loss, and return of power?
  15. 88 4runner
  16. interior sun roof cover ?.
  17. need a picture of auto shifter
  18. 95 3vze Tensioner for T.B.
  19. 95 3vze Water pump bolt torque
  20. turning problems/smelly smells/ lights
  21. speddometer cable
  22. Cranking issues
  23. exhaust.
  24. regearing for 33s
  25. Base model 95 3vze Timing Belt
  26. 22RE slowwww Idle after EFI reset
  27. Please Help Identify this bracket
  28. Front end clunk
  29. New truck. Holler.
  30. hard start after engine swap
  31. 4.7 transfer case gears
  32. 22re to a 22ret
  33. 91 runner flooding in the am...?
  34. Trunnion Bearing Eliminator Kits - New toy from trailgear for SFAs
  35. 1993 t100 interchangeable rear end
  36. Rear Lift Leaf Springs, Any Ideas?
  37. Please identify this header
  38. Empty coolant overflow tank...
  39. Pulls hard right in 4wd
  40. Marlin Crawler Bumper Help
  41. Straight pipe cat back exhaust project. LOTS OF VIDS!
  42. Thread info for clutch master and slave cylinder
  43. 1991 4runner Sr5 v6 Auto Starting Problem
  44. MC Shifter seats and socket
  45. hey guys need a ton of help! 3.0L lol
  46. Colorado to Kansas
  47. No coolant flowin, need help please!
  48. Wanted screws for back tailgate access
  49. transfer case fill plug
  50. CV Grease - What is the brown/yellow stuff?
  51. EGR Vacuum Modulator question
  52. Rough, shakey, and weak after a new HG and and whole timing set.
  53. 22Re-t
  54. oil hose
  55. possible tranny sound & sources ??
  56. Timing Chain Noise on Startup, no broken guides.
  57. 1st Gen resto; need weatherstrip - lock cylinders
  58. tachometer issues
  59. ignition timing and power
  60. 87 4runner leaking onto passenger floor
  61. what price range am i looking at to swap a 22re in my 93 pu?
  62. 94 came stock with 31's ?
  63. Brand new 22re only runs 75
  64. Power Steering Assist
  65. Trouble getting into gears
  66. Exhaust
  67. Rear Defrost
  68. Tire sizes.
  69. Two sizes of heater cores?
  70. R22 head shaving
  71. 4runner Tune-up and still not running right
  72. trying to locate cause of loud noise.
  73. seats
  74. heating / cooling
  75. cracked dash
  76. Nasty vibration in gear
  77. Motor Swap help
  78. '94 22re 4x4, got no power at all
  79. What is this color called?
  80. 22r EFI vs Carb Dependability
  81. Code 41
  82. who loves 89 to 91 ext cab pickups
  83. 22re replacement - without a real garage?
  84. another MPG thread!!!
  85. Brake pads and Rotors
  86. Stripped a bolt
  87. Friend has some codes
  88. tranny issue?
  89. AC removal: pretty sure I'm good, but...
  90. Throttle positioning sensor
  91. Best Cheap Fixes on High Mileage Engines
  92. power door locks w/ manual windows
  93. After 95 tanks of gas I can say for sure that I get 21 mpg.
  94. Chrome grill and bumper
  95. Just Armour linered my entire 94 pickup. 56K beware!!
  96. Consuming Coolant
  97. Wiring at R/B No.1 FSM = incomplete
  98. FJ80 Cruiser Coils???
  99. Crower Regrinds
  100. 86 4runner break / rotor job *help*
  101. 86 4runner break/rotor job *help*
  102. getting 11 miles per galon on r22e 4runner(help) please
  103. High crankcase pressure passed leakdown test
  104. Tranny removal, starter questions
  105. 22re Distributor issue
  106. Rear-end knocking while turning sharp
  107. gas gauge no work
  108. Whats in my U-joint?
  109. Intermitant Knock Sensor Fault 53
  110. Transmission/Driveline banging noise?
  111. 4th gear grinds???
  112. Blown head gasket options
  113. witch FSM for my truck?
  114. 96 3.0 in a 93
  115. getting new shocks
  116. another clutch pedal bracket issue
  117. Emergency Brake Cable
  118. Hot ignition?
  119. turbo manifold ? for turbo guys
  120. Exhaust/Backpressure question
  121. 89-95 4runner 22r-e
  122. spedo in my 86 truck running too slow. how to fix?
  123. Slee Land Cruiser Coils To Lift 2nd Gen Rear?
  124. '87 4runner stuck in defrost
  125. Tranny oil. Did I screw this up?
  126. Removing 1st Gen Door Panels
  127. sunk my 4x, hydro lock, fixed, now doesn't idle
  128. So...ok to run 30" tires with no gear change?
  129. Need gearing advice
  130. Fuel Sender Test?
  131. Flipped my 4runner :(
  132. What is the best coolant for a 22re? Yeah I did a search...
  133. Early and late 22R oil pans swap?
  134. Part ID for 1986 4runner
  135. finding a vacuum leak
  136. auto trans etc box
  137. tire carrier pickup
  138. New Rear Bumper From T.G. With Optional Side Mounts
  139. original super swamper tsl?
  140. I need tips before going into emmision testing today
  141. 22RE temp almost to the red, before coming down to mid way point.
  142. Clutch?? Or what.....
  143. Just bought a project crawler 89 ext cab
  144. Questions about rpm and gas pedal
  145. Water in My Defroster/Heater?
  146. tranny swap? A340E to R150?
  147. Factory work light plug on dash
  148. Plans for a project car
  149. Grille guard 87 to 94
  150. 1st gen 4runner window seals front
  151. Code 31
  152. Time for a clutch....
  153. Vibration at 60mph and above
  154. drive shaft squeak
  155. Speed bleeder
  156. New Shocks or not???
  157. Savage Offroad Rear Bumper
  158. Overheating mystery
  159. Engine running issues
  160. Brake pedal goes to the floor on the first pump
  161. Cheap exhaust options
  162. Thermostat Modification
  163. HELP? Where are the fuse & resistor located on my 89 4Runner for the ECT (TCU)
  164. Stereo considerations....
  165. coilover questions
  166. Swap 4 Speed for 5 Speed
  167. Over heating problem
  168. 93 5 speed fluid ?
  169. clock fuse is randomly blowing
  170. Taco rims fit over Manual hubs?
  171. What is an "Ideal" BUDGET IFS suspension set up
  172. Weld a 4 Pinion rear diff.
  173. Why does IFS have inconsistant flex/droop? (W/ pix)
  174. Cleaning up my Emissions
  175. Low gas warning light stuck on
  176. HELP! Rear Wiper Wont stop wiping!!
  177. New truck, runs great but annoying rattle
  178. what exactly came in the sr5 package?
  179. clutch replacement
  180. Next project: High Compression N/A 22RE w/ 20R head
  181. timing chain slap?
  182. coiled brake lines purpose??
  183. Timing Belt Marks and TDC...
  184. 22re cel and possible shorts
  185. ParkinG light 'issues'
  186. runs good cold
  187. Zero Electrical power nothing at all
  188. altenator belt falling off
  189. 1990 4runner v6 problems
  190. am i doing something wrong when installing wheel bearings?
  191. Brake Bleed Problems After New Wheel Cylinders
  192. SR5 wheels with Wheel spacers
  193. 94 3.slow ARB snorkel help!
  194. snow plow?
  195. 3vze head gasket rebuild questions
  196. Ice scraper holder
  197. EB 268 guys
  198. 1988 4Runner Lift Kit Help
  199. OLD Coast Rd near Monterey CA
  200. 22re head gasket adventure. [Pics] Help / Advice / Tips welcome!
  201. Painted tail light lenses
  202. Timing Chain Kit
  203. head gasket replacement
  204. 1st gen rear cargo panel questions
  205. tinting windows. advice?
  206. 4x4 quit help?
  207. Fix that driver's seat blowout!
  208. exhaust leak.... again. I need some help
  209. just curious about 4runners with 22re?
  210. TPS woes
  211. Water in my oil:'(
  212. 22re tensioner pulley
  213. Clutch & Idle
  214. Driver door controls - need immediate help!!
  215. No air from center vents
  216. Seat swap in a 91 x-cab
  217. trouble codes
  218. No water flowing across top of Radiator...Causes/Solutions???
  219. trying to find the infamous radiator stop leak picture
  220. vacuum hose need HELP!!!
  221. Will a 3rd gen's roof rack mount up to my roof
  222. heater question?
  223. What to look for in a new pickup...
  224. Finally an end to Knock sensor issues, had to cheat it though...
  225. Code 71 EGR. Where to look/fix first?
  226. 93 4Runner and 94 DLX
  227. stock 22re exhaust size
  228. 89 22re will start but will not run
  229. 95 22RE 4x4 ECU problem or not?
  230. Clutch opinion
  231. 95 4x4 4runner rotor replacement help
  232. Now thats a dead Trunion
  233. Ever see hub breakage like this?
  234. no brake pressure in one caliper !!!!!!!!!!
  235. Started the exocage
  236. parts washer fluid
  237. locker issues
  238. big 22RE problems
  239. Tell me if I repaired rust the right way
  240. 3vze misfire, stumbling, rough idle: need help diagnosing
  241. stuck woodruff key in crank
  242. 5sp Swap question
  243. Tranny and Transfer case
  244. 91 22RE A/F mixture gauge Qts
  245. 22R Timing Question
  246. o2 sensor wiring
  247. I can get free Axles what are your thoughts?
  248. vacuum leak?
  249. 4Runner dies when hot...
  250. Rear springs - question on "ruk" brand?
