4.88 third
Old Nov 23, 2009 | 04:31 PM
khamblin's Avatar
4.88 third
hey. just wondering about swapping to 4.88's in my 4runner. I have a 4cyl 4runner 92' and its got 4.10's in it right now. i've heard that 4.88's come stock in v6's with the 31" tire package. so is it possible if i find one of those that i can put it in my 4runner? just wondering about if that's compitable with my 4runner. so yeah if i could get some thoughts on that it'd be great!
thanks
Old Nov 23, 2009 | 05:17 PM
myyota's Avatar
They will work in your 4Runner.
Old Nov 23, 2009 | 05:24 PM
Murakami's Avatar
the 4runner donor has to be auto trans and 92-95 as well i think. look for code g144, if i recall. the swap is straight forward. search here for '4.88'.
Old Nov 23, 2009 | 05:31 PM
khamblin's Avatar
so does the donor have to be auto even if mine is a 5sp manual? also mine is g292. so it's 2 pinion. is the g144 the 4 pinion one? will that work still?
Old Nov 23, 2009 | 05:51 PM
Murakami's Avatar
only the autos had 4.88s. not sure what 2 and 4 pinion is but it will work!
Old Nov 23, 2009 | 06:32 PM
toyNG's Avatar
this should have all the info you need http://home.4x4wire.com/erik/diffs/
Old Nov 23, 2009 | 06:53 PM
khamblin's Avatar
alright cool! thanks for the help everyone.
Old Nov 23, 2009 | 07:02 PM
khamblin's Avatar
one more question here. um... where can I find a set of 4.56's? do you know what years and packages those came on?
Old Nov 23, 2009 | 07:30 PM
Murakami's Avatar
a bunch of those are around. try craigslist or the for sale section here.
Old Nov 23, 2009 | 09:12 PM
Stuwy123's Avatar
I spent almost a year at PnP looking for a set out here. I finally found 'em.
This will be second gear swap this year.
4.10's to 4.56's in early summer.
4.56's to 4.88 some time soon.
Old Nov 24, 2009 | 07:41 PM
khamblin's Avatar
yeah i'm gonna have to start looking for some. i know of a couple around i'm going to look at to check the gears.
thanks
Old Nov 24, 2009 | 07:47 PM
Stuwy123's Avatar
Check the door jams, not the gear.
Old Nov 25, 2009 | 11:44 AM
khamblin's Avatar
yeah i know. but thanks in case i didn't.
Old Nov 25, 2009 | 01:32 PM
4x4runr's Avatar
i believe the v6 towing package came with 4.88
as for the 4.56, i think they were on all v6 4x4
don't qoute me on this
good luck
Old Nov 25, 2009 | 05:19 PM
khamblin's Avatar
good luck
i'm gonna quote you on it! haha. yeah i'm gonna try and find some for sure. but ya just wondering too if i want to run 31's for sure and possible 32's/33's in the future which gearing would be the best?
thanks
Old Nov 25, 2009 | 06:01 PM
streetlancer's Avatar
From what i have learned in these forums this is how it goes:
31"=4:56
33"=4:88
35"=5:29
If you plan on going to 33" tire later on you should go with the 4:88s
It should work just fine with 31" you will just experience higher rpms and quicker acceleration.
I read a forum here the other the day of someone using 4:88 gears on 31" tires.
SOMEONE CORRECT ME IF I AM WRONG
Old Nov 25, 2009 | 06:42 PM
Jody's Avatar
go for the 4.88s if you plan on running 33s, I'm currently running 4.56 behind a 3.4 and a 5 speed, and wish I had slightly lower gears. If you're still looking for 4.56s by the time I throw in my 4.88s, you can have mine for a case of beer + the shipping.
Old Nov 25, 2009 | 07:33 PM
Im interested. Will ship beer asap.
Old Nov 25, 2009 | 09:00 PM
khamblin's Avatar
ok. yeah i'll probably try and find some 4.88's for it then. because i'm gonna run at least 32's, so i'd rather have that if i can find it.
thanks for the responses.
shipping would probably be a killer on those anyways! haha.
Old Nov 25, 2009 | 10:17 PM
Jay351's Avatar
factory 4.88 gears are found on 92-95 pickups and 4runners with a 3vze, automatic and the 31" tire package from the factory.
I got mine out of a 92 "sequoia edition" 4runner.
